Do you use the package listed in the below topic?
If yes, there is a TorchVision prebuilt so you don’t need to build it from the source.
For OSError: libmpi_cxx.so.20: cannot open shared object file: No such file or directory. Please run the below command to install the dependency and try it again.
$ sudo apt-get install python3-pip libopenblas-base libopenmpi-dev libomp-dev
