I am trying to install JetPack 6.0 on my Jetson Orin Nano using VMware Ubuntu.
After successfully flashing the device, I encountered an issue when trying to install the SDK components. (See attached image.)
I have tried both USB and Ethernet connections, but neither worked.
When selecting USB, should the Jetson be in Recovery Mode?
I have attempted installation in both Recovery Mode and normal mode, but the issue persists.
Any guidance on resolving this issue would be greatly appreciated.
We do not support to use VM, and suggest to use the native Ubuntu host machine.
But you can refer to below topic if you only can use VM to see if can help:
