Issue of cannot read stream from radar sensor with SerDes
Dear team,
We use Jetson Orin to receive a video stream from a radar sensor that sends raw data in MIPI CSI-2 format. The layout of the devices are shown below:
A SerDes is used to allow more radar sensors, and we have already configured the SerDes to have the correct parameters with the hlep of TI.
We cannot got the stream when we use the script below to read the stream:
sudo v4l2-ctl --set-fmt-video=width=5000,height=512,pixelformat=RGGB --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=/home/user/stream.raw --stream-poll --verbose
The most likely reason is that we have configured some error parameters in Orin, or that we have omitted some configurations.
Please check the trace log below for details:
# tracer: nop
# entries-in-buffer/entries-written: 285/285   #P:12
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
        v4l2-ctl-3288    [000] ....   347.171122: tegra_channel_open: vi-output, awr2243 20-0060
        v4l2-ctl-3288    [000] ....   347.173983: tegra_channel_set_power: awr2243 20-0060 : 0x1
        v4l2-ctl-3288    [000] ....   347.173986: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3288    [000] ....   347.173987: csi_s_power: enable : 0x1
        v4l2-ctl-3288    [000] ....   347.174374: tegra_channel_capture_setup: vnc_id 0 W 4096 H 512 fmt 5
        v4l2-ctl-3288    [010] ....   347.175084: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-3288    [010] ....   347.187934: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3288    [010] ....   347.193151: csi_s_stream: enable : 0x1
        v4l2-ctl-3288    [010] ....   347.193578: tegra_channel_set_stream: awr2243 20-0060 : 0x1
     kworker/4:2-213     [004] ....   347.242031: rtcpu_vinotify_event: tstamp:11728863212 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:375307235808 data:0x379d580010000000
     kworker/4:2-213     [004] ....   347.242034: rtcpu_vinotify_event: tstamp:11728863366 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:375307242272 data:0x0000000031000001
     kworker/4:2-213     [004] ....   347.242035: rtcpu_vinotify_event: tstamp:11728863517 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:375307287584 data:0x379d550010000000
     kworker/4:2-213     [004] ....   347.242036: rtcpu_vinotify_event: tstamp:11728863648 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:375307294112 data:0x0000000031000002
     kworker/4:2-213     [004] ....   347.242038: rtcpu_nvcsi_intr: tstamp:11728931526 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
     kworker/4:2-213     [004] ....   347.242038: rtcpu_nvcsi_intr: tstamp:11728931526 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
     kworker/4:2-213     [004] ....   347.298042: rtcpu_vinotify_event: tstamp:11731033467 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:375392329760 data:0x0000000000000010
     kworker/4:2-213     [004] ....   347.298044: rtcpu_vinotify_event: tstamp:11731033603 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:375392329856 data:0x0000000800000000
     kworker/4:2-213     [004] ....   347.298045: rtcpu_vinotify_event: tstamp:11731033755 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:375392395136 data:0x0000000000000001
     kworker/4:2-213     [004] ....   347.298045: rtcpu_vinotify_event: tstamp:11731033885 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:375392406016 data:0x0000000008020001
     kworker/4:2-213     [004] ....   347.298046: rtcpu_vinotify_event: tstamp:11732118390 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:375415406208 data:0x0000000001ff0002
     kworker/4:2-213     [004] ....   347.298047: rtcpu_vinotify_event: tstamp:11732118524 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:375415407200 data:0x0000000000000000
     kworker/4:2-213     [004] ....   347.298048: rtcpu_vinotify_event: tstamp:11732118680 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:375415432064 data:0x0000000002020001
     kworker/4:2-213     [004] ....   347.298049: rtcpu_vinotify_event: tstamp:11732118810 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:375415408000 data:0x0000000000000020
     kworker/4:2-213     [004] ....   347.298049: rtcpu_vinotify_event: tstamp:11732118965 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:375415408000 data:0x0000200000000000
     kworker/4:2-213     [004] ....   347.298050: rtcpu_vinotify_event: tstamp:11732119096 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:375415506784 data:0x0000000001020001
     kworker/4:2-213     [004] ....   347.298051: rtcpu_vinotify_event: tstamp:11732119249 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:375415408096 data:0x0000000800000000
     kworker/4:2-213     [004] ....   347.410166: rtcpu_vinotify_event: tstamp:11734139166 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:375492332160 data:0x0000000000000010
     kworker/4:2-213     [004] ....   347.410167: rtcpu_vinotify_event: tstamp:11734668143 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:375492332224 data:0x0000000800000000
     kworker/4:2-213     [004] ....   347.410168: rtcpu_vinotify_event: tstamp:11734668278 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:375492398208 data:0x0000000000000001
     kworker/4:2-213     [004] ....   347.410169: rtcpu_vinotify_event: tstamp:11735210210 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:375515409248 data:0x0000000001ff0002
     kworker/4:2-213     [004] ....   347.410169: rtcpu_vinotify_event: tstamp:11735210344 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:375515410240 data:0x0000000000000000
     kworker/4:2-213     [004] ....   347.410170: rtcpu_vinotify_event: tstamp:11735210495 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:375515411040 data:0x0000000000000020
     kworker/4:2-213     [004] ....   347.410170: rtcpu_vinotify_event: tstamp:11735210629 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:375515411072 data:0x0000200000000000
     kworker/4:2-213     [004] ....   347.410171: rtcpu_vinotify_event: tstamp:11735210783 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:375515411136 data:0x0000000800000000
     kworker/4:2-213     [004] ....   347.470016: rtcpu_vinotify_error: tstamp:11737266483 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375592401248 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.470017: rtcpu_vinotify_event: tstamp:11737380656 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:375592335136 data:0x0000000000000010
     kworker/4:2-213     [004] ....   347.470018: rtcpu_vinotify_event: tstamp:11737380809 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375592401248 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.526039: rtcpu_vinotify_event: tstamp:11738465748 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:375615414016 data:0x0000000000000020
     kworker/4:2-213     [004] ....   347.582161: rtcpu_vinotify_error: tstamp:11740391577 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375692404288 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.582164: rtcpu_vinotify_event: tstamp:11740636196 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:375692338304 data:0x0000000000000010
     kworker/4:2-213     [004] ....   347.582165: rtcpu_vinotify_event: tstamp:11740636329 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375692404288 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.642022: rtcpu_vinotify_event: tstamp:11741178322 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:375715417088 data:0x0000000000000020
     kworker/4:2-213     [004] ....   347.698160: rtcpu_vinotify_error: tstamp:11743516673 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375792407296 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.698163: rtcpu_vinotify_event: tstamp:11743890625 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:375792341344 data:0x0000000000000010
     kworker/4:2-213     [004] ....   347.698164: rtcpu_vinotify_event: tstamp:11743890775 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375792407296 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.698164: rtcpu_vinotify_event: tstamp:11744234764 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:375815420224 data:0x0000000000000020
     kworker/4:2-213     [004] ....   347.810036: rtcpu_vinotify_error: tstamp:11746641771 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375892410432 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.810040: rtcpu_vinotify_event: tstamp:11746658310 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:375892344352 data:0x0000000000000010
     kworker/4:2-213     [004] ....   347.810040: rtcpu_vinotify_event: tstamp:11746658443 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375892410432 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.810040: rtcpu_vinotify_event: tstamp:11747743366 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:375915423232 data:0x0000000000000020
     kworker/4:2-213     [004] ....   347.866027: rtcpu_vinotify_error: tstamp:11749766870 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375992413472 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.866029: rtcpu_vinotify_event: tstamp:11749912789 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:375992347424 data:0x0000000000000010
     kworker/4:2-213     [004] ....   347.866029: rtcpu_vinotify_event: tstamp:11749912942 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:375992413472 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.922166: rtcpu_vinotify_event: tstamp:11750997883 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376015426304 data:0x0000000000000020
     kworker/4:2-213     [004] ....   347.978162: rtcpu_vinotify_error: tstamp:11752891959 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376092416512 data:0x0000000000000549
     kworker/4:2-213     [004] ....   347.978165: rtcpu_vinotify_event: tstamp:11753168323 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376092350528 data:0x0000000000000010
     kworker/4:2-213     [004] ....   347.978166: rtcpu_vinotify_event: tstamp:11753168457 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376092416512 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.038021: rtcpu_vinotify_event: tstamp:11753711556 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376115429312 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.094161: rtcpu_vinotify_error: tstamp:11756017057 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376192419552 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.094164: rtcpu_vinotify_event: tstamp:11756423846 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376192353568 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.094165: rtcpu_vinotify_event: tstamp:11756423999 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376192419552 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.094165: rtcpu_vinotify_event: tstamp:11756965970 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376215432384 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.206027: rtcpu_vinotify_error: tstamp:11759142147 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376292422560 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.206030: rtcpu_vinotify_event: tstamp:11759679353 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376292356608 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.206031: rtcpu_vinotify_event: tstamp:11759679487 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376292422560 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.206031: rtcpu_vinotify_event: tstamp:11760221492 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376315435424 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.266023: rtcpu_vinotify_error: tstamp:11762267947 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376392425696 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.266024: rtcpu_vinotify_event: tstamp:11762268300 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376392359616 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.322022: rtcpu_vinotify_event: tstamp:11762771791 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376392425696 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.322023: rtcpu_vinotify_event: tstamp:11763313925 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376415438464 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.378173: rtcpu_vinotify_error: tstamp:11765392343 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376492428736 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.378176: rtcpu_vinotify_event: tstamp:11765484359 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376492362656 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.378176: rtcpu_vinotify_event: tstamp:11765484494 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376492428736 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.434163: rtcpu_vinotify_event: tstamp:11766569445 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376515441472 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.490170: rtcpu_vinotify_error: tstamp:11768517439 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376592431776 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.490174: rtcpu_vinotify_event: tstamp:11768739889 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376592365760 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.490174: rtcpu_vinotify_event: tstamp:11768740044 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376592431776 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.490175: rtcpu_vinotify_event: tstamp:11769282011 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376615444640 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.602164: rtcpu_vinotify_error: tstamp:11771642531 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376692434784 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.602167: rtcpu_vinotify_event: tstamp:11771994310 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376692368768 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.602167: rtcpu_vinotify_event: tstamp:11771994444 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376692434784 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.602168: rtcpu_vinotify_event: tstamp:11772537548 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376715447648 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.714019: rtcpu_vinotify_error: tstamp:11774767628 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376792437888 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.714022: rtcpu_vinotify_event: tstamp:11775249847 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376792371808 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.714023: rtcpu_vinotify_event: tstamp:11775250000 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376792437888 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.714024: rtcpu_vinotify_event: tstamp:11775791985 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376815450688 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.770170: rtcpu_vinotify_error: tstamp:11777893046 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376892440896 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.770175: rtcpu_vinotify_event: tstamp:11777893619 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376892374848 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.770175: rtcpu_vinotify_event: tstamp:11777893753 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376892440896 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.826162: rtcpu_vinotify_event: tstamp:11778614191 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:376915453728 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.882170: rtcpu_vinotify_error: tstamp:11781017819 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376992443936 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.882173: rtcpu_vinotify_event: tstamp:11781326468 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:376992377984 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.882174: rtcpu_vinotify_event: tstamp:11781326618 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:376992443936 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.938170: rtcpu_vinotify_event: tstamp:11781868589 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377015456736 data:0x0000000000000020
     kworker/4:2-213     [004] ....   348.994168: rtcpu_vinotify_error: tstamp:11784142911 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377092446944 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.994172: rtcpu_vinotify_event: tstamp:11784581998 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377092380992 data:0x0000000000000010
     kworker/4:2-213     [004] ....   348.994173: rtcpu_vinotify_event: tstamp:11784582130 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377092446944 data:0x0000000000000549
     kworker/4:2-213     [004] ....   348.994173: rtcpu_vinotify_event: tstamp:11785124125 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377115459872 data:0x0000000000000020
     kworker/4:2-213     [004] ....   349.106163: rtcpu_vinotify_error: tstamp:11787268011 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377192450112 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.106166: rtcpu_vinotify_event: tstamp:11787294559 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377192384064 data:0x0000000000000010
     kworker/4:2-213     [004] ....   349.106167: rtcpu_vinotify_event: tstamp:11787294712 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377192450112 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.106167: rtcpu_vinotify_event: tstamp:11788379659 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377215462912 data:0x0000000000000020
     kworker/4:2-213     [004] ....   349.162040: rtcpu_vinotify_error: tstamp:11790393106 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377292453152 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.218031: rtcpu_vinotify_event: tstamp:11790550117 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377292387040 data:0x0000000000000010
     kworker/4:2-213     [004] ....   349.218034: rtcpu_vinotify_event: tstamp:11790550250 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377292453152 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.218035: rtcpu_vinotify_event: tstamp:11791635188 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377315465952 data:0x0000000000000020
     kworker/4:2-213     [004] ....   349.274024: rtcpu_vinotify_error: tstamp:11793518203 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377392456160 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.274026: rtcpu_vinotify_event: tstamp:11793804519 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377392390208 data:0x0000000000000010
     kworker/4:2-213     [004] ....   349.274026: rtcpu_vinotify_event: tstamp:11793804673 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377392456160 data:0x0000000000000549
        v4l2-ctl-3288    [010] ....   349.296655: tegra_channel_close: vi-output, awr2243 20-0060
     kworker/4:2-213     [004] ....   349.330037: rtcpu_vinotify_event: tstamp:11794236378 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377415468960 data:0x0000000000000020
     kworker/4:2-213     [004] ....   349.386025: rtcpu_vinotify_error: tstamp:11796643294 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377492459168 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.386029: rtcpu_vinotify_event: tstamp:11796680433 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377492393248 data:0x0000000000000010
     kworker/4:2-213     [004] ....   349.386029: rtcpu_vinotify_event: tstamp:11796680565 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377492459168 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.442016: rtcpu_vinotify_event: tstamp:11797765514 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377515472064 data:0x0000000000000020
     kworker/4:2-213     [004] ....   349.502022: rtcpu_vinotify_error: tstamp:11799768393 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377592462336 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.502023: rtcpu_vinotify_event: tstamp:11799935957 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377592396256 data:0x0000000000000010
     kworker/4:2-213     [004] ....   349.502024: rtcpu_vinotify_event: tstamp:11799936110 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377592462336 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.502024: rtcpu_vinotify_event: tstamp:11801021049 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377615475104 data:0x0000000000000020
     kworker/4:2-213     [004] ....   349.614170: rtcpu_vinotify_error: tstamp:11802893485 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377692465376 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.614172: rtcpu_vinotify_event: tstamp:11803190396 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377692399296 data:0x0000000000000010
     kworker/4:2-213     [004] ....   349.614173: rtcpu_vinotify_event: tstamp:11803190529 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377692465376 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.614173: rtcpu_vinotify_event: tstamp:11803733615 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377715478112 data:0x0000000000000020
     kworker/4:2-213     [004] ....   349.670172: rtcpu_vinotify_error: tstamp:11806018581 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377792468416 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.726230: rtcpu_vinotify_event: tstamp:11806445918 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377792402400 data:0x0000000000000010
     kworker/4:2-213     [004] ....   349.726232: rtcpu_vinotify_event: tstamp:11806446068 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377792468416 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.726233: rtcpu_vinotify_event: tstamp:11806988038 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377815481120 data:0x0000000000000020
     kworker/4:2-213     [004] ....   349.786021: rtcpu_vinotify_error: tstamp:11809143675 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377892471424 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.786023: rtcpu_vinotify_event: tstamp:11809158476 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:377892405408 data:0x0000000000000010
     kworker/4:2-213     [004] ....   349.786023: rtcpu_vinotify_event: tstamp:11809158609 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:377892471424 data:0x0000000000000549
     kworker/4:2-213     [004] ....   349.842025: rtcpu_vinotify_event: tstamp:11810243566 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:377915484288 data:0x000000000000002
Trace above is from deserializer output rate is set to 800Mbps and below trace log is when configed as 1.6Gbps:
# tracer: nop
# entries-in-buffer/entries-written: 371/371   #P:12
#                                _-----=> irqs-off
#                              ||| /     delay
     kworker/4:0-35      [004] ....   102.126011: rtcpu_nvcsi_intr: tstamp:4074137302 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.126014: rtcpu_nvcsi_intr: tstamp:4074137302 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.242002: rtcpu_nvcsi_intr: tstamp:4077262384 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.242004: rtcpu_nvcsi_intr: tstamp:4077262384 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.302010: rtcpu_nvcsi_intr: tstamp:4080387467 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.302012: rtcpu_nvcsi_intr: tstamp:4080387467 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.417996: rtcpu_nvcsi_intr: tstamp:4083512547 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.417997: rtcpu_nvcsi_intr: tstamp:4083512547 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.537998: rtcpu_nvcsi_intr: tstamp:4086637634 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.538000: rtcpu_nvcsi_intr: tstamp:4086637634 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.593999: rtcpu_nvcsi_intr: tstamp:4089762716 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.594000: rtcpu_nvcsi_intr: tstamp:4089762716 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.706003: rtcpu_nvcsi_intr: tstamp:4092887800 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.706004: rtcpu_nvcsi_intr: tstamp:4092887800 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.822007: rtcpu_nvcsi_intr: tstamp:4096012883 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.822011: rtcpu_nvcsi_intr: tstamp:4096012883 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.934015: rtcpu_nvcsi_intr: tstamp:4099137966 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.934018: rtcpu_nvcsi_intr: tstamp:4099137966 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   102.990027: rtcpu_nvcsi_intr: tstamp:4102263048 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   102.990031: rtcpu_nvcsi_intr: tstamp:4102263048 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.102005: rtcpu_nvcsi_intr: tstamp:4105388132 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.102007: rtcpu_nvcsi_intr: tstamp:4105388132 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.214036: rtcpu_nvcsi_intr: tstamp:4108513215 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.214040: rtcpu_nvcsi_intr: tstamp:4108513215 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.326021: rtcpu_nvcsi_intr: tstamp:4111638295 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.326022: rtcpu_nvcsi_intr: tstamp:4111638295 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.438008: rtcpu_nvcsi_intr: tstamp:4114763382 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.438010: rtcpu_nvcsi_intr: tstamp:4114763382 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.494023: rtcpu_nvcsi_intr: tstamp:4117888464 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.494027: rtcpu_nvcsi_intr: tstamp:4117888464 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.606165: rtcpu_nvcsi_intr: tstamp:4121013547 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.606168: rtcpu_nvcsi_intr: tstamp:4121013547 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.718002: rtcpu_nvcsi_intr: tstamp:4124138627 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.718005: rtcpu_nvcsi_intr: tstamp:4124138627 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.834017: rtcpu_nvcsi_intr: tstamp:4127263714 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.834019: rtcpu_nvcsi_intr: tstamp:4127263714 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   103.890005: rtcpu_nvcsi_intr: tstamp:4130388796 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   103.890007: rtcpu_nvcsi_intr: tstamp:4130388796 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.002008: rtcpu_nvcsi_intr: tstamp:4133513880 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.002010: rtcpu_nvcsi_intr: tstamp:4133513880 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.117997: rtcpu_nvcsi_intr: tstamp:4136638963 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.117999: rtcpu_nvcsi_intr: tstamp:4136638963 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.230001: rtcpu_nvcsi_intr: tstamp:4139764046 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.230003: rtcpu_nvcsi_intr: tstamp:4139764046 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.342193: rtcpu_nvcsi_intr: tstamp:4142889128 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.342197: rtcpu_nvcsi_intr: tstamp:4142889128 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.398189: rtcpu_nvcsi_intr: tstamp:4146014208 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.398193: rtcpu_nvcsi_intr: tstamp:4146014208 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.510009: rtcpu_nvcsi_intr: tstamp:4149139295 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.510012: rtcpu_nvcsi_intr: tstamp:4149139295 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.622178: rtcpu_nvcsi_intr: tstamp:4152264374 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.622181: rtcpu_nvcsi_intr: tstamp:4152264374 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.734008: rtcpu_nvcsi_intr: tstamp:4155389460 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.734011: rtcpu_nvcsi_intr: tstamp:4155389460 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.790017: rtcpu_nvcsi_intr: tstamp:4158514544 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.790020: rtcpu_nvcsi_intr: tstamp:4158514544 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   104.902004: rtcpu_nvcsi_intr: tstamp:4161639623 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   104.902006: rtcpu_nvcsi_intr: tstamp:4161639623 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.022009: rtcpu_nvcsi_intr: tstamp:4164764710 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.022012: rtcpu_nvcsi_intr: tstamp:4164764710 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.138001: rtcpu_nvcsi_intr: tstamp:4167889793 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.138002: rtcpu_nvcsi_intr: tstamp:4167889793 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.197999: rtcpu_nvcsi_intr: tstamp:4171014876 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.198000: rtcpu_nvcsi_intr: tstamp:4171014876 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.317998: rtcpu_nvcsi_intr: tstamp:4174139959 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.318000: rtcpu_nvcsi_intr: tstamp:4174139959 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.433995: rtcpu_nvcsi_intr: tstamp:4177265041 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.433996: rtcpu_nvcsi_intr: tstamp:4177265041 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.489995: rtcpu_nvcsi_intr: tstamp:4180390125 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.489995: rtcpu_nvcsi_intr: tstamp:4180390125 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.609995: rtcpu_nvcsi_intr: tstamp:4183515205 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.609996: rtcpu_nvcsi_intr: tstamp:4183515205 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.722007: rtcpu_nvcsi_intr: tstamp:4186640292 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.722008: rtcpu_nvcsi_intr: tstamp:4186640292 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.838003: rtcpu_nvcsi_intr: tstamp:4189765373 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.838007: rtcpu_nvcsi_intr: tstamp:4189765373 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   105.894000: rtcpu_nvcsi_intr: tstamp:4192890458 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   105.894001: rtcpu_nvcsi_intr: tstamp:4192890458 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.013998: rtcpu_nvcsi_intr: tstamp:4196015540 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.013999: rtcpu_nvcsi_intr: tstamp:4196015540 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.129996: rtcpu_nvcsi_intr: tstamp:4199140620 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.129997: rtcpu_nvcsi_intr: tstamp:4199140620 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.245997: rtcpu_nvcsi_intr: tstamp:4202265702 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.245998: rtcpu_nvcsi_intr: tstamp:4202265702 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.302021: rtcpu_nvcsi_intr: tstamp:4205390789 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.302022: rtcpu_nvcsi_intr: tstamp:4205390789 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.414012: rtcpu_nvcsi_intr: tstamp:4208515869 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.414015: rtcpu_nvcsi_intr: tstamp:4208515869 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.530000: rtcpu_nvcsi_intr: tstamp:4211640956 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.530001: rtcpu_nvcsi_intr: tstamp:4211640956 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.589998: rtcpu_nvcsi_intr: tstamp:4214766035 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.589999: rtcpu_nvcsi_intr: tstamp:4214766035 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.706006: rtcpu_nvcsi_intr: tstamp:4217891121 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.706008: rtcpu_nvcsi_intr: tstamp:4217891121 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.818186: rtcpu_nvcsi_intr: tstamp:4221016201 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.818189: rtcpu_nvcsi_intr: tstamp:4221016201 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   106.930024: rtcpu_nvcsi_intr: tstamp:4224141284 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   106.930028: rtcpu_nvcsi_intr: tstamp:4224141284 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   107.042026: rtcpu_nvcsi_intr: tstamp:4227266367 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   107.042030: rtcpu_nvcsi_intr: tstamp:4227266367 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   107.098024: rtcpu_string: tstamp:4229385204 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-3113    [001] ....   109.576446: tegra_channel_open: vi-output, awr2243 20-0060
        v4l2-ctl-3113    [001] ....   109.579257: tegra_channel_set_power: awr2243 20-0060 : 0x1
        v4l2-ctl-3113    [001] ....   109.579260: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3113    [001] ....   109.579262: csi_s_power: enable : 0x1
        v4l2-ctl-3113    [001] ....   109.579334: tegra_channel_capture_setup: vnc_id 0 W 4096 H 512 fmt 5
        v4l2-ctl-3113    [001] ....   109.585389: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-3113    [001] ....   109.597621: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3113    [001] ....   109.602858: csi_s_stream: enable : 0x1
        v4l2-ctl-3113    [001] ....   109.603350: tegra_channel_set_stream: awr2243 20-0060 : 0x1
     kworker/4:0-35      [004] ....   109.634018: rtcpu_string: tstamp:4308367113 id:0x04010000 str:"VM0 activating."
     kworker/4:0-35      [004] ....   109.634022: rtcpu_vinotify_event: tstamp:4309000428 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:137871722528 data:0x379d580010000000
     kworker/4:0-35      [004] ....   109.634023: rtcpu_vinotify_event: tstamp:4309000567 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:137871729504 data:0x0000000031000001
     kworker/4:0-35      [004] ....   109.634023: rtcpu_vinotify_event: tstamp:4309000721 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:137871780832 data:0x379d550010000000
     kworker/4:0-35      [004] ....   109.634024: rtcpu_vinotify_event: tstamp:4309000854 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:137871787488 data:0x0000000031000002
     kworker/4:0-35      [004] ....   109.634025: rtcpu_nvcsi_intr: tstamp:4309054343 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
     kworker/4:0-35      [004] ....   109.634026: rtcpu_nvcsi_intr: tstamp:4309054343 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
     kworker/4:0-35      [004] ....   109.634027: rtcpu_nvcsi_intr: tstamp:4309059344 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   109.634028: rtcpu_nvcsi_intr: tstamp:4309059344 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   109.690034: rtcpu_vinotify_event: tstamp:4311170672 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:137949513760 data:0x0000000000000010
     kworker/4:0-35      [004] ....   109.690035: rtcpu_vinotify_event: tstamp:4311170811 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:137949513856 data:0x0000000800000000
     kworker/4:0-35      [004] ....   109.690036: rtcpu_vinotify_event: tstamp:4311170964 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:137949579264 data:0x0000000000000001
     kworker/4:0-35      [004] ....   109.690036: rtcpu_vinotify_event: tstamp:4311171094 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:137949590112 data:0x0000000008020001
     kworker/4:0-35      [004] ....   109.690037: rtcpu_nvcsi_intr: tstamp:4311643610 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   109.690037: rtcpu_nvcsi_intr: tstamp:4311643610 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   109.690038: rtcpu_vinotify_event: tstamp:4311712683 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:137972590144 data:0x0000000001ff0002
     kworker/4:0-35      [004] ....   109.690038: rtcpu_vinotify_event: tstamp:4311712817 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:137972591104 data:0x0000000000000000
     kworker/4:0-35      [004] ....   109.690039: rtcpu_vinotify_event: tstamp:4311712967 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:137972616000 data:0x0000000002020001
     kworker/4:0-35      [004] ....   109.690039: rtcpu_vinotify_event: tstamp:4311713097 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:137972591904 data:0x0000000000000020
     kworker/4:0-35      [004] ....   109.690040: rtcpu_vinotify_event: tstamp:4311713247 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:137972591936 data:0x0000200000000000
     kworker/4:0-35      [004] ....   109.690040: rtcpu_vinotify_event: tstamp:4311713378 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:137972690752 data:0x0000000001020001
     kworker/4:0-35      [004] ....   109.690040: rtcpu_vinotify_event: tstamp:4311713530 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:137972592000 data:0x0000000800000000
     kworker/4:0-35      [004] ....   109.802024: rtcpu_vinotify_event: tstamp:4314051157 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138049515840 data:0x0000000000000010
     kworker/4:0-35      [004] ....   109.802025: rtcpu_vinotify_event: tstamp:4314588828 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:138049515936 data:0x0000000800000000
     kworker/4:0-35      [004] ....   109.802026: rtcpu_vinotify_event: tstamp:4314588963 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:138049581856 data:0x0000000000000001
     kworker/4:0-35      [004] ....   109.802027: rtcpu_nvcsi_intr: tstamp:4314768696 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   109.802028: rtcpu_nvcsi_intr: tstamp:4314768696 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   109.802028: rtcpu_vinotify_event: tstamp:4315130882 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:138072592832 data:0x0000000001ff0002
     kworker/4:0-35      [004] ....   109.802029: rtcpu_vinotify_event: tstamp:4315131013 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:138072593824 data:0x0000000000000000
     kworker/4:0-35      [004] ....   109.802030: rtcpu_vinotify_event: tstamp:4315131162 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138072594560 data:0x0000000000000020
     kworker/4:0-35      [004] ....   109.802031: rtcpu_vinotify_event: tstamp:4315131295 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:138072594592 data:0x0000200000000000
     kworker/4:0-35      [004] ....   109.802032: rtcpu_vinotify_event: tstamp:4315131446 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:138072594656 data:0x0000000800000000
     kworker/4:0-35      [004] ....   109.914152: rtcpu_vinotify_error: tstamp:4317178461 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138149584544 data:0x0000000000000549
     kworker/4:0-35      [004] ....   109.914154: rtcpu_vinotify_event: tstamp:4317301327 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138149518432 data:0x0000000000000010
     kworker/4:0-35      [004] ....   109.914155: rtcpu_vinotify_event: tstamp:4317301479 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138149584544 data:0x0000000000000549
     kworker/4:0-35      [004] ....   109.914157: rtcpu_nvcsi_intr: tstamp:4317893779 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   109.914157: rtcpu_nvcsi_intr: tstamp:4317893779 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   109.914158: rtcpu_vinotify_event: tstamp:4318386415 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138172597248 data:0x0000000000000020
     kworker/4:0-35      [004] ....   109.970153: rtcpu_vinotify_error: tstamp:4320303543 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138249587136 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.026152: rtcpu_vinotify_event: tstamp:4320556868 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138249521120 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.026154: rtcpu_vinotify_event: tstamp:4320557000 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138249587136 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.026156: rtcpu_nvcsi_intr: tstamp:4321018859 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.026156: rtcpu_nvcsi_intr: tstamp:4321018859 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.026157: rtcpu_vinotify_event: tstamp:4321098990 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138272599840 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.082009: rtcpu_vinotify_error: tstamp:4323428625 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138349589824 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.082012: rtcpu_vinotify_event: tstamp:4323811302 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138349523744 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.082012: rtcpu_vinotify_event: tstamp:4323811453 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138349589824 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.138009: rtcpu_nvcsi_intr: tstamp:4324143942 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.138010: rtcpu_nvcsi_intr: tstamp:4324143942 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.138013: rtcpu_vinotify_event: tstamp:4324146754 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138372602496 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.194016: rtcpu_vinotify_error: tstamp:4326553709 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138449592416 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.194019: rtcpu_vinotify_event: tstamp:4326578980 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138449526496 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.194020: rtcpu_vinotify_event: tstamp:4326579111 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138449592416 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.194021: rtcpu_nvcsi_intr: tstamp:4327269028 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.194022: rtcpu_nvcsi_intr: tstamp:4327269028 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.249998: rtcpu_vinotify_event: tstamp:4327664072 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138472605216 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.306025: rtcpu_vinotify_error: tstamp:4329678791 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138549595072 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.306026: rtcpu_vinotify_event: tstamp:4329833400 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138549529088 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.306027: rtcpu_vinotify_event: tstamp:4329833553 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138549595072 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.306028: rtcpu_nvcsi_intr: tstamp:4330394108 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.306029: rtcpu_nvcsi_intr: tstamp:4330394108 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.306030: rtcpu_vinotify_event: tstamp:4330918486 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138572607808 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.418001: rtcpu_vinotify_error: tstamp:4332803876 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138649597760 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.418002: rtcpu_vinotify_event: tstamp:4333088933 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138649531712 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.418003: rtcpu_vinotify_event: tstamp:4333089066 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138649597760 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.418003: rtcpu_nvcsi_intr: tstamp:4333519195 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.418004: rtcpu_nvcsi_intr: tstamp:4333519195 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.418004: rtcpu_vinotify_event: tstamp:4333631053 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138672610592 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.474005: rtcpu_vinotify_error: tstamp:4335928959 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138749600384 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.530014: rtcpu_vinotify_event: tstamp:4336344457 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138749534432 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.530017: rtcpu_vinotify_event: tstamp:4336344609 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138749600384 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.530019: rtcpu_nvcsi_intr: tstamp:4336644277 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.530020: rtcpu_nvcsi_intr: tstamp:4336644277 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.530020: rtcpu_vinotify_event: tstamp:4336886584 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138772613184 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.585999: rtcpu_vinotify_error: tstamp:4339054173 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138849603136 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.586001: rtcpu_vinotify_event: tstamp:4339058150 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138849537056 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.586001: rtcpu_vinotify_event: tstamp:4339058281 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138849603136 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.642002: rtcpu_nvcsi_intr: tstamp:4339769357 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.642004: rtcpu_nvcsi_intr: tstamp:4339769357 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.642005: rtcpu_vinotify_event: tstamp:4340142123 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138872615776 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.697999: rtcpu_vinotify_error: tstamp:4342179823 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138949605760 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.698000: rtcpu_vinotify_event: tstamp:4342180172 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:138949539712 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.698001: rtcpu_vinotify_event: tstamp:4342692446 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:138949605760 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.698001: rtcpu_nvcsi_intr: tstamp:4342894439 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.698001: rtcpu_nvcsi_intr: tstamp:4342894439 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.698002: rtcpu_vinotify_event: tstamp:4343234553 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:138972618464 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.810154: rtcpu_vinotify_error: tstamp:4345304208 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139049608416 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.810157: rtcpu_vinotify_event: tstamp:4345405019 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139049542336 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.810158: rtcpu_vinotify_event: tstamp:4345405152 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139049608416 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.810159: rtcpu_nvcsi_intr: tstamp:4346019523 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.810160: rtcpu_nvcsi_intr: tstamp:4346019523 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.810160: rtcpu_vinotify_event: tstamp:4346490078 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139072621088 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.866151: rtcpu_vinotify_error: tstamp:4348429290 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139149611040 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.922155: rtcpu_vinotify_event: tstamp:4348659414 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139149545088 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.922158: rtcpu_vinotify_event: tstamp:4348659567 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139149611040 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.922161: rtcpu_nvcsi_intr: tstamp:4349144608 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   110.922161: rtcpu_nvcsi_intr: tstamp:4349144608 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   110.922162: rtcpu_vinotify_event: tstamp:4349202647 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139172623808 data:0x0000000000000020
     kworker/4:0-35      [004] ....   110.978154: rtcpu_vinotify_error: tstamp:4351554373 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139249613760 data:0x0000000000000549
     kworker/4:0-35      [004] ....   110.978158: rtcpu_vinotify_event: tstamp:4351914934 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139249547680 data:0x0000000000000010
     kworker/4:0-35      [004] ....   110.978158: rtcpu_vinotify_event: tstamp:4351915067 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139249613760 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.034156: rtcpu_nvcsi_intr: tstamp:4352269689 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.034159: rtcpu_nvcsi_intr: tstamp:4352269689 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.034161: rtcpu_vinotify_event: tstamp:4352458175 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139272626432 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.090146: rtcpu_vinotify_error: tstamp:4354679584 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139349616384 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.090150: rtcpu_vinotify_event: tstamp:4355170476 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139349550432 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.090151: rtcpu_vinotify_event: tstamp:4355170627 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139349616384 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.090152: rtcpu_nvcsi_intr: tstamp:4355394775 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.090153: rtcpu_nvcsi_intr: tstamp:4355394775 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.146154: rtcpu_vinotify_event: tstamp:4355712598 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139372629184 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.202155: rtcpu_vinotify_error: tstamp:4357804868 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139449619008 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.202159: rtcpu_vinotify_event: tstamp:4357805440 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139449553056 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.202160: rtcpu_vinotify_event: tstamp:4357805571 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139449619008 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.202162: rtcpu_nvcsi_intr: tstamp:4358519858 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.202162: rtcpu_nvcsi_intr: tstamp:4358519858 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.202163: rtcpu_vinotify_event: tstamp:4358533696 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139472631776 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.314146: rtcpu_vinotify_error: tstamp:4360929639 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139549621728 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.314151: rtcpu_vinotify_event: tstamp:4361247106 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139549555648 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.314151: rtcpu_vinotify_event: tstamp:4361247255 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139549621728 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.314153: rtcpu_nvcsi_intr: tstamp:4361644939 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.314153: rtcpu_nvcsi_intr: tstamp:4361644939 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.314154: rtcpu_vinotify_event: tstamp:4361789235 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139572634464 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.370022: rtcpu_vinotify_error: tstamp:4364054706 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139649624320 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.426009: rtcpu_vinotify_event: tstamp:4364502652 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139649558336 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.426011: rtcpu_vinotify_event: tstamp:4364502787 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139649624320 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.426012: rtcpu_nvcsi_intr: tstamp:4364770021 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.426013: rtcpu_nvcsi_intr: tstamp:4364770021 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.426013: rtcpu_vinotify_event: tstamp:4365044776 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139672637056 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.482002: rtcpu_vinotify_error: tstamp:4367179788 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139749627008 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.482003: rtcpu_vinotify_event: tstamp:4367215222 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139749560960 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.482004: rtcpu_vinotify_event: tstamp:4367215373 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139749627008 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.538156: rtcpu_nvcsi_intr: tstamp:4367895104 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.538159: rtcpu_nvcsi_intr: tstamp:4367895104 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.538161: rtcpu_vinotify_event: tstamp:4368300306 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139772639680 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.594010: rtcpu_vinotify_error: tstamp:4370304999 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139849629632 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.594014: rtcpu_vinotify_event: tstamp:4370469645 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139849563680 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.594015: rtcpu_vinotify_event: tstamp:4370469776 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139849629632 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.594016: rtcpu_nvcsi_intr: tstamp:4371020191 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.594017: rtcpu_nvcsi_intr: tstamp:4371020191 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.650026: rtcpu_vinotify_event: tstamp:4371554723 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139872642400 data:0x0000000000000020
        v4l2-ctl-3113    [001] ....   111.699917: tegra_channel_close: vi-output, awr2243 20-0060
     kworker/4:0-35      [004] ....   111.706011: rtcpu_vinotify_error: tstamp:4373429956 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139949632384 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.706012: rtcpu_vinotify_event: tstamp:4373725172 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:139949566272 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.706013: rtcpu_vinotify_event: tstamp:4373725322 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:139949632384 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.706014: rtcpu_nvcsi_intr: tstamp:4374145270 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.706015: rtcpu_nvcsi_intr: tstamp:4374145270 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.706015: rtcpu_vinotify_event: tstamp:4374148084 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:139972645024 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.818220: rtcpu_vinotify_error: tstamp:4376555035 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140049634976 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.818223: rtcpu_vinotify_event: tstamp:4376601170 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:140049569024 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.818224: rtcpu_vinotify_event: tstamp:4376601301 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140049634976 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.818226: rtcpu_nvcsi_intr: tstamp:4377270357 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.818226: rtcpu_nvcsi_intr: tstamp:4377270357 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.818227: rtcpu_vinotify_event: tstamp:4377686288 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:140072647744 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.874153: rtcpu_vinotify_error: tstamp:4379680122 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140149637728 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.874156: rtcpu_vinotify_event: tstamp:4379855603 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:140149571616 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.874157: rtcpu_vinotify_event: tstamp:4379855758 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140149637728 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.930020: rtcpu_nvcsi_intr: tstamp:4380395437 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.930023: rtcpu_nvcsi_intr: tstamp:4380395437 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   111.930025: rtcpu_vinotify_event: tstamp:4380398840 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:140172650368 data:0x0000000000000020
     kworker/4:0-35      [004] ....   111.989999: rtcpu_vinotify_error: tstamp:4382805205 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140249640320 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.990000: rtcpu_vinotify_event: tstamp:4383111136 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:140249574304 data:0x0000000000000010
     kworker/4:0-35      [004] ....   111.990001: rtcpu_vinotify_event: tstamp:4383111271 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140249640320 data:0x0000000000000549
     kworker/4:0-35      [004] ....   111.990001: rtcpu_nvcsi_intr: tstamp:4383520522 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   111.990002: rtcpu_nvcsi_intr: tstamp:4383520522 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.046001: rtcpu_vinotify_event: tstamp:4383653260 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:140272653024 data:0x0000000000000020
     kworker/4:0-35      [004] ....   112.102013: rtcpu_vinotify_error: tstamp:4385930423 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140349642944 data:0x0000000000000549
     kworker/4:0-35      [004] ....   112.102016: rtcpu_vinotify_event: tstamp:4386366659 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:140349576896 data:0x0000000000000010
     kworker/4:0-35      [004] ....   112.102017: rtcpu_vinotify_event: tstamp:4386366813 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140349642944 data:0x0000000000000549
     kworker/4:0-35      [004] ....   112.102018: rtcpu_nvcsi_intr: tstamp:4386645603 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.102018: rtcpu_nvcsi_intr: tstamp:4386645603 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.102019: rtcpu_vinotify_event: tstamp:4386908791 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:140372655648 data:0x0000000000000020
     kworker/4:0-35      [004] ....   112.217999: rtcpu_vinotify_error: tstamp:4389055370 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140449645600 data:0x0000000000000549
     kworker/4:0-35      [004] ....   112.218002: rtcpu_vinotify_event: tstamp:4389079239 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:140449579552 data:0x0000000000000010
     kworker/4:0-35      [004] ....   112.218002: rtcpu_vinotify_event: tstamp:4389079372 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:140449645600 data:0x0000000000000549
     kworker/4:0-35      [004] ....   112.218003: rtcpu_nvcsi_intr: tstamp:4389770689 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.218003: rtcpu_nvcsi_intr: tstamp:4389770689 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.218004: rtcpu_vinotify_event: tstamp:4390164326 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:140472658400 data:0x0000000000000020
 vi-output, awr2-3115    [003] ....   112.276850: tegra_channel_capture_setup: vnc_id 0 W 4096 H 512 fmt 5
        v4l2-ctl-3113    [001] ....   112.286931: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-3113    [001] ....   112.286932: tegra_channel_set_stream: awr2243 20-0060 : 0x0
        v4l2-ctl-3113    [001] ....   112.291089: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3113    [001] ....   112.291091: csi_s_stream: enable : 0x0
        v4l2-ctl-3113    [001] ....   112.310790: tegra_channel_set_power: awr2243 20-0060 : 0x0
        v4l2-ctl-3113    [001] ....   112.310793: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3113    [001] ....   112.310794: csi_s_power: enable : 0x0
     kworker/4:0-35      [004] ....   112.330015: rtcpu_nvcsi_intr: tstamp:4392895772 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.330018: rtcpu_nvcsi_intr: tstamp:4392895772 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.330018: rtcpu_nvcsi_intr: tstamp:4392916511 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
     kworker/4:0-35      [004] ....   112.330019: rtcpu_nvcsi_intr: tstamp:4392916511 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
     kworker/4:0-35      [004] ....   112.330019: rtcpu_nvcsi_intr: tstamp:4392921512 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.330021: rtcpu_nvcsi_intr: tstamp:4392921512 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.442015: rtcpu_nvcsi_intr: tstamp:4396020851 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.442018: rtcpu_nvcsi_intr: tstamp:4396020851 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.498039: rtcpu_nvcsi_intr: tstamp:4399145930 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.498042: rtcpu_nvcsi_intr: tstamp:4399145930 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.610009: rtcpu_nvcsi_intr: tstamp:4402271017 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.610010: rtcpu_nvcsi_intr: tstamp:4402271017 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.722022: rtcpu_nvcsi_intr: tstamp:4405396100 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.722024: rtcpu_nvcsi_intr: tstamp:4405396100 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.834023: rtcpu_nvcsi_intr: tstamp:4408521183 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.834025: rtcpu_nvcsi_intr: tstamp:4408521183 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   112.890035: rtcpu_nvcsi_intr: tstamp:4411646263 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   112.890039: rtcpu_nvcsi_intr: tstamp:4411646263 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.002024: rtcpu_nvcsi_intr: tstamp:4414771350 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.002029: rtcpu_nvcsi_intr: tstamp:4414771350 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.114014: rtcpu_nvcsi_intr: tstamp:4417896431 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.114018: rtcpu_nvcsi_intr: tstamp:4417896431 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.234004: rtcpu_nvcsi_intr: tstamp:4421021516 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.234008: rtcpu_nvcsi_intr: tstamp:4421021516 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.290005: rtcpu_nvcsi_intr: tstamp:4424146599 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.290006: rtcpu_nvcsi_intr: tstamp:4424146599 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.402016: rtcpu_nvcsi_intr: tstamp:4427271681 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.402019: rtcpu_nvcsi_intr: tstamp:4427271681 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.514018: rtcpu_nvcsi_intr: tstamp:4430396764 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.514021: rtcpu_nvcsi_intr: tstamp:4430396764 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.626011: rtcpu_nvcsi_intr: tstamp:4433521848 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.626014: rtcpu_nvcsi_intr: tstamp:4433521848 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.742009: rtcpu_nvcsi_intr: tstamp:4436646931 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.742011: rtcpu_nvcsi_intr: tstamp:4436646931 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.798025: rtcpu_nvcsi_intr: tstamp:4439772017 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.798026: rtcpu_nvcsi_intr: tstamp:4439772017 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   113.910029: rtcpu_nvcsi_intr: tstamp:4442897097 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   113.910033: rtcpu_nvcsi_intr: tstamp:4442897097 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.022014: rtcpu_nvcsi_intr: tstamp:4446022181 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.022019: rtcpu_nvcsi_intr: tstamp:4446022181 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.134033: rtcpu_nvcsi_intr: tstamp:4449147263 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.134046: rtcpu_nvcsi_intr: tstamp:4449147263 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.190041: rtcpu_nvcsi_intr: tstamp:4452272350 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.190046: rtcpu_nvcsi_intr: tstamp:4452272350 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.302046: rtcpu_nvcsi_intr: tstamp:4455397429 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.302057: rtcpu_nvcsi_intr: tstamp:4455397429 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.414012: rtcpu_nvcsi_intr: tstamp:4458522516 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.414015: rtcpu_nvcsi_intr: tstamp:4458522516 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.526003: rtcpu_nvcsi_intr: tstamp:4461647598 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.526005: rtcpu_nvcsi_intr: tstamp:4461647598 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.638022: rtcpu_nvcsi_intr: tstamp:4464772682 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.638024: rtcpu_nvcsi_intr: tstamp:4464772682 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.697999: rtcpu_nvcsi_intr: tstamp:4467897761 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.698000: rtcpu_nvcsi_intr: tstamp:4467897761 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.810036: rtcpu_nvcsi_intr: tstamp:4471022848 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.810044: rtcpu_nvcsi_intr: tstamp:4471022848 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   114.922036: rtcpu_nvcsi_intr: tstamp:4474147931 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   114.922047: rtcpu_nvcsi_intr: tstamp:4474147931 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.034044: rtcpu_nvcsi_intr: tstamp:4477273015 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.034055: rtcpu_nvcsi_intr: tstamp:4477273015 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.090049: rtcpu_nvcsi_intr: tstamp:4480398098 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.090061: rtcpu_nvcsi_intr: tstamp:4480398098 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.202045: rtcpu_nvcsi_intr: tstamp:4483523180 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.202050: rtcpu_nvcsi_intr: tstamp:4483523180 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.318013: rtcpu_nvcsi_intr: tstamp:4486648263 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.318018: rtcpu_nvcsi_intr: tstamp:4486648263 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.434013: rtcpu_nvcsi_intr: tstamp:4489773343 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.434016: rtcpu_nvcsi_intr: tstamp:4489773343 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.494030: rtcpu_nvcsi_intr: tstamp:4492898429 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.494042: rtcpu_nvcsi_intr: tstamp:4492898429 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.606027: rtcpu_nvcsi_intr: tstamp:4496023512 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.606031: rtcpu_nvcsi_intr: tstamp:4496023512 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.718349: rtcpu_nvcsi_intr: tstamp:4499148596 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.718354: rtcpu_nvcsi_intr: tstamp:4499148596 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:0-35      [004] ....   115.830021: rtcpu_nvcsi_intr: tstamp:4502273679 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:0-35      [004] ....   115.830025: rtcpu_nvcsi_intr: tstamp:4502273679 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
We also noticed that there are many exposure control parameters required by the Tegra Camera Framework (TCF), whereas the radar sensor does not have this functionality. How to set there parameters?
Could you please help me to solve the problem of reading the stream?
Any idea would be helpful.
Thanks a lot!
Best,
Lee.
hello timelim,
here shows PHY interrupt errors.
this is due to DPHY deskew calibration not complete, it happened when the calibration sequence length is not long enough.
you may have a try to configure cil_settletime, and please also review the serdes_pix_clk_hz settings.
please see-also similar discussion thread, Topic 168715.
thanks
Hi Jerry,
We changed the "serdes_pix_clk_hz "to 800MHz which is the maximumu data rate of UB960(referred to here).
And the “cil_settletime” is always set as 0.
Just like lines blow:
serdes_pix_clk_hz = "800000000";
cil_settletime = "0";
Please check the current trace log
# tracer: nop
# entries-in-buffer/entries-written: 26/26   #P:12
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
        v4l2-ctl-3202    [009] ....   123.112280: tegra_channel_open: vi-output, awr2243 20-0060
        v4l2-ctl-3202    [009] ....   123.115343: tegra_channel_set_power: awr2243 20-0060 : 0x1
        v4l2-ctl-3202    [009] ....   123.115347: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3202    [009] ....   123.115350: csi_s_power: enable : 0x1
        v4l2-ctl-3202    [000] ....   123.115771: tegra_channel_capture_setup: vnc_id 0 W 4096 H 512 fmt 5
        v4l2-ctl-3202    [000] ....   123.116474: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-3202    [000] ....   123.130335: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3202    [000] ....   123.135560: csi_s_stream: enable : 0x1
        v4l2-ctl-3202    [000] ....   123.135981: tegra_channel_set_stream: awr2243 20-0060 : 0x1
     kworker/3:4-149     [003] ....   123.165809: rtcpu_vinotify_event: tstamp:4732205580 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:151416456352 data:0x379d580010000000
     kworker/3:4-149     [003] ....   123.165810: rtcpu_vinotify_event: tstamp:4732205728 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:151416462784 data:0x0000000031000001
     kworker/3:4-149     [003] ....   123.165811: rtcpu_vinotify_event: tstamp:4732205878 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:151416508096 data:0x379d550010000000
     kworker/3:4-149     [003] ....   123.165811: rtcpu_vinotify_event: tstamp:4732206007 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:151416515040 data:0x0000000031000002
     kworker/3:4-149     [003] ....   123.165813: rtcpu_nvcsi_intr: tstamp:4732371402 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
     kworker/3:4-149     [003] ....   123.165813: rtcpu_nvcsi_intr: tstamp:4732371402 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
        v4l2-ctl-3202    [000] ....   125.142918: tegra_channel_close: vi-output, awr2243 20-0060
 vi-output, awr2-3204    [003] ....   125.688436: tegra_channel_capture_setup: vnc_id 0 W 4096 H 512 fmt 5
        v4l2-ctl-3202    [000] ....   125.698172: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-3202    [000] ....   125.698174: tegra_channel_set_stream: awr2243 20-0060 : 0x0
        v4l2-ctl-3202    [000] ....   125.701812: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3202    [000] ....   125.701814: csi_s_stream: enable : 0x0
        v4l2-ctl-3202    [000] ....   125.720651: tegra_channel_set_power: awr2243 20-0060 : 0x0
        v4l2-ctl-3202    [000] ....   125.720655: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3202    [000] ....   125.720664: csi_s_power: enable : 0x0
     kworker/3:4-149     [003] ....   125.753824: rtcpu_nvcsi_intr: tstamp:4812439942 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
     kworker/3:4-149     [003] ....   125.753827: rtcpu_nvcsi_intr: tstamp:4812439942 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
It seems to stopped completely at “LP sequence error detected”.
I’m not sure if the value is reasonable and if the deskew calibration is complete for now.
Thanks,
Lee
LP sequence error is the very early stage failure. please examine the sensor signaling, it should follow the MIPI spec.
Hi Jerry,
We got stream now and it could be saved to file.
But some errors still could be found from trace log:
# tracer: nop
# entries-in-buffer/entries-written: 53/53   #P:12
#                                _-----=> irqs-off
#                              ||| /     delay
     kworker/1:5-213     [001] ....   140.838022: rtcpu_string: tstamp:5279951319 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-3369    [006] ....   145.716569: tegra_channel_open: vi-output, awr2243 20-0060
        v4l2-ctl-3369    [006] ....   145.723783: tegra_channel_set_power: awr2243 20-0060 : 0x1
        v4l2-ctl-3369    [006] ....   145.723786: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3369    [006] ....   145.723788: csi_s_power: enable : 0x1
        v4l2-ctl-3369    [006] ....   145.723862: tegra_channel_capture_setup: vnc_id 0 W 4096 H 512 fmt 5
        v4l2-ctl-3369    [006] ....   145.734577: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-3369    [006] ....   145.749240: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3369    [006] ....   145.754517: csi_s_stream: enable : 0x1
        v4l2-ctl-3369    [006] ....   145.754954: tegra_channel_set_stream: awr2243 20-0060 : 0x1
     kworker/1:5-213     [001] ....   145.762000: rtcpu_string: tstamp:5433755508 id:0x04010000 str:"VM0 activating."
     kworker/1:5-213     [001] ....   145.762003: rtcpu_vinotify_event: tstamp:5434431280 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:173887034496 data:0x379d580010000000
     kworker/1:5-213     [001] ....   145.762004: rtcpu_vinotify_event: tstamp:5434431417 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:173887040960 data:0x0000000031000001
     kworker/1:5-213     [001] ....   145.762004: rtcpu_vinotify_event: tstamp:5434431570 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:173887091232 data:0x379d550010000000
     kworker/1:5-213     [001] ....   145.762004: rtcpu_vinotify_event: tstamp:5434431701 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:173887097792 data:0x0000000031000002
     kworker/1:5-213     [001] ....   145.762006: rtcpu_nvcsi_intr: tstamp:5434613361 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x01c00000
     kworker/1:5-213     [001] ....   145.762006: rtcpu_nvcsi_intr: tstamp:5434613361 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00c00000
 vi-output, awr2-3371    [005] ....   145.859332: tegra_channel_capture_frame: sof:173.988084480
 vi-output, awr2-3371    [005] ....   145.859335: tegra_channel_capture_frame: eof:174.11097472
     kworker/1:5-213     [001] ....   145.874010: rtcpu_vinotify_event: tstamp:5437360840 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:173988019136 data:0x0000000000000010
     kworker/1:5-213     [001] ....   145.874012: rtcpu_vinotify_event: tstamp:5437360979 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:173988019232 data:0x0000000800000000
     kworker/1:5-213     [001] ....   145.874013: rtcpu_vinotify_event: tstamp:5437361132 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:173988084480 data:0x0000000000000001
     kworker/1:5-213     [001] ....   145.874013: rtcpu_vinotify_event: tstamp:5437361263 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:173988094272 data:0x0000000008020001
     kworker/1:5-213     [001] ....   145.874014: rtcpu_vinotify_event: tstamp:5437854647 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:174011095584 data:0x0000000001ff0002
     kworker/1:5-213     [001] ....   145.874014: rtcpu_vinotify_event: tstamp:5437854778 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:174011096512 data:0x0000000000000000
     kworker/1:5-213     [001] ....   145.874015: rtcpu_vinotify_event: tstamp:5437854929 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:174011117504 data:0x0000000002020001
     kworker/1:5-213     [001] ....   145.874015: rtcpu_vinotify_event: tstamp:5437855058 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:174011097376 data:0x0000000000000020
     kworker/1:5-213     [001] ....   145.874015: rtcpu_vinotify_event: tstamp:5437855210 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:174011097472 data:0x0000000800000000
     kworker/1:5-213     [001] ....   145.874016: rtcpu_vinotify_event: tstamp:5437855340 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:174011158080 data:0x0000000000020001
 vi-output, awr2-3371    [005] ....   145.959224: tegra_channel_capture_frame: sof:174.88087744
 vi-output, awr2-3371    [005] ....   145.959227: tegra_channel_capture_frame: eof:174.111100704
        v4l2-ctl-3369    [006] ....   145.959407: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-3369    [006] ....   145.959408: tegra_channel_set_stream: awr2243 20-0060 : 0x0
        v4l2-ctl-3369    [006] ....   145.963577: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3369    [006] ....   145.963581: csi_s_stream: enable : 0x0
        v4l2-ctl-3369    [000] ....   145.982436: tegra_channel_set_power: awr2243 20-0060 : 0x0
        v4l2-ctl-3369    [000] ....   145.982439: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3369    [000] ....   145.982442: csi_s_power: enable : 0x0
     kworker/1:5-213     [001] ....   145.990013: rtcpu_vinotify_event: tstamp:5440257915 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:174088021728 data:0x0000000000000010
     kworker/1:5-213     [001] ....   145.990015: rtcpu_vinotify_event: tstamp:5440258051 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:174088021824 data:0x0000000800000000
     kworker/1:5-213     [001] ....   145.990016: rtcpu_vinotify_event: tstamp:5440730341 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:174088087744 data:0x0000000000000001
     kworker/1:5-213     [001] ....   145.990017: rtcpu_vinotify_event: tstamp:5440730472 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:174088113152 data:0x0000000008020002
     kworker/1:5-213     [001] ....   145.990017: rtcpu_vinotify_event: tstamp:5440730621 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:174088350272 data:0x379d580010000000
     kworker/1:5-213     [001] ....   145.990018: rtcpu_vinotify_event: tstamp:5440730749 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:174088389280 data:0x0000000031000003
     kworker/1:5-213     [001] ....   145.990020: rtcpu_nvcsi_intr: tstamp:5440998353 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
     kworker/1:5-213     [001] ....   145.990021: rtcpu_nvcsi_intr: tstamp:5440998353 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
     kworker/1:5-213     [001] ....   145.990022: rtcpu_vinotify_event: tstamp:5441187781 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:174111098848 data:0x0000000001ff0002
     kworker/1:5-213     [001] ....   145.990022: rtcpu_vinotify_event: tstamp:5441187916 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:174111099744 data:0x0000000000000000
     kworker/1:5-213     [001] ....   145.990023: rtcpu_vinotify_event: tstamp:5441188069 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:174111120768 data:0x0000000002020002
     kworker/1:5-213     [001] ....   145.990024: rtcpu_vinotify_event: tstamp:5441188200 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:174111100608 data:0x0000000000000020
     kworker/1:5-213     [001] ....   145.990024: rtcpu_vinotify_event: tstamp:5441188353 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:174111100704 data:0x0000000800000000
     kworker/1:5-213     [001] ....   145.990025: rtcpu_vinotify_event: tstamp:5441188484 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:174111161344 data:0x0000000000020002
        v4l2-ctl-3369    [000] ....   146.006625: tegra_channel_close: vi-output, awr2243 20-0060
I was wondering if these errors could be ignored?
Thanks a lot,
Lee
hello timelim,
these are messages to indicate start-of-frame, end-of-frame, frame-done…etc
they’re printed also with normal captures, so, you may ignore those if you’re able to capture the frames, and your camera functionality works normally.
