Issue of MIPI CSI-2 frame size constrains on Jetson Orin
Dear team,
We are using a sensor whose data stream transmission is based on 4 lane 1.6Gbps MIPI CSI interface.
The sensor output frame is 4096*512 RAW8 10FPS and the data is well received on Orin by v4l2-ctl.
However, when we set the frame size to 8000*216, the v4l2-ctl prompted a timeout error. (The related DTS and probe functions have also been modified)
The error log show below:
nvidia@root:~$ sudo v4l2-ctl --set-fmt-video=width=8000,height=216,pixelformat=RGGB --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=/home/nvidia/test.raw --stream-poll --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
        Width/Height               : 8000/216
        Pixel Format                 : ‘RGGB’ (8-bit Bayer RGRG/GBGB)
        Field                               : None
        Bytes per Line             : 8000
        Size Image                   : 1728000
        Colorspace                  : sRGB
        Transfer Function      : Default (maps to sRGB)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization               : Default (maps to Full Range)
        Flags                             :
                VIDIOC_REQBUFS returned 0 (Success)
                VIDIOC_QUERYBUF returned 0 (Success)
                VIDIOC_QBUF returned 0 (Success)
                VIDIOC_STREAMON returned 0 (Success)
cap dqbuf: 0 seq: 0 bytesused: 1728000 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1 bytesused: 1728000 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 2 bytesused: 1728000 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
select timeout
Strangely, data receiving works fine again when we change the frame size to “4000*216”.
We’d like to know where the problem is and how to correct receive the 8000*216 data.
Thanks a lot.
Best,
Jim
hello timelim,
may I know what’s the kernel messages reported when capture 8000x216 via v4l2-ctl?
this may due to clock configuration, please refer to Sensor Pixel Clock section to review the sensor pixel clock settings.
Thanks for your help Jerry,
We tried both
pixel_clk_hz = sensor data rate per lane (Mbps) * number of lanes / bits per pixel
and
pixel_clk_hz = sensor output size × frame rate
The problem still there.
Please check the output from dmesg when fail to read the stream :
[  134.617558] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[  134.628247] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: flags 2, err_data 0
[  134.632933] [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=163183028320 sof_ts=163183100032 gerror_code=2 gerror_data=a0 notify_bits=0"
[  137.236970] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  137.246152] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  137.256327] (NULL device *): vi_capture_control_message: NULL VI channel received
[  137.264077] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  137.274758] (NULL device *): vi_capture_control_message: NULL VI channel received
[  137.282496] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 3
[  137.293254] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
and the trace log
   v4l2-ctl-3287    [010] ....   326.955423: csi_s_power: enable : 0x1
   v4l2-ctl-3287    [010] ....   326.955518: tegra_channel_capture_setup: vnc_id 0 W 8000 H 216 fmt 5
   v4l2-ctl-3287    [011] ....   326.968478: tegra_channel_set_stream: enable : 0x1
   v4l2-ctl-3287    [011] ....   326.982766: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
   v4l2-ctl-3287    [011] ....   326.982770: csi_s_stream: enable : 0x1
   v4l2-ctl-3287    [011] ....   326.983095: tegra_channel_set_stream: SensorName 20-0063 : 0x1
kworker/4:3-134     [004] ....   326.984947: rtcpu_string: tstamp:11110304436 id:0x04010000 str:"VM0 activating."
kworker/4:3-134     [004] ....   326.984951: rtcpu_vinotify_event: tstamp:11110916985 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:355534604480 data:0x379d580010000000
kworker/4:3-134     [004] ....   326.984952: rtcpu_vinotify_event: tstamp:11110917119 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:355534610976 data:0x0000000031000001
kworker/4:3-134     [004] ....   326.984952: rtcpu_vinotify_event: tstamp:11110917269 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:355534662176 data:0x379d550010000000
kworker/4:3-134     [004] ....   326.984953: rtcpu_vinotify_event: tstamp:11110917400 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:355534668800 data:0x0000000031000002
kworker/4:3-134     [004] ....   327.040946: rtcpu_nvcsi_intr: tstamp:11111032893 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
kworker/4:3-134     [004] ....   327.040948: rtcpu_nvcsi_intr: tstamp:11111032893 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/4:3-134     [004] ....   327.040949: rtcpu_nvcsi_intr: tstamp:11111036931 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x01c00000
kworker/4:3-134     [004] ....   327.040949: rtcpu_nvcsi_intr: tstamp:11111036931 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00c00000
kworker/4:3-134     [004] ....   327.040951: rtcpu_vinotify_error: tstamp:11112050778 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355585379616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.040952: rtcpu_vinotify_error: tstamp:11112051657 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355585390304 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.040953: rtcpu_vinotify_error: tstamp:11112052530 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355585400992 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.040955: rtcpu_vinotify_event: tstamp:11112322613 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:355585317216 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.040956: rtcpu_vinotify_event: tstamp:11112322749 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:355585317888 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.040956: rtcpu_vinotify_event: tstamp:11112322907 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:355585318528 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.040957: rtcpu_vinotify_event: tstamp:11112323040 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:355585318592 data:0x0000000800000000
kworker/4:3-134     [004] ....   327.040957: rtcpu_vinotify_event: tstamp:11112323186 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:355585319168 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.040958: rtcpu_vinotify_event: tstamp:11112323313 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355585379616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.040959: rtcpu_vinotify_event: tstamp:11112323458 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355585390304 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.040959: rtcpu_vinotify_event: tstamp:11112323586 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355585400992 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.040960: rtcpu_vinotify_event: tstamp:11112323735 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:355585411616 data:0x0000000000000001
kworker/4:3-134     [004] ....   327.040960: rtcpu_vinotify_event: tstamp:11112323864 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:355585482016 data:0x0000000008020001
kworker/4:3-134     [004] ....   327.040961: rtcpu_vinotify_event: tstamp:11112324008 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:355594230912 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.040961: rtcpu_vinotify_event: tstamp:11112324135 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:355594232832 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.097092: rtcpu_vinotify_event: tstamp:11112770056 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:355594234752 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.152949: rtcpu_vinotify_error: tstamp:11115181215 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:355685319264 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.152952: rtcpu_vinotify_error: tstamp:11115182120 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355685380960 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.152953: rtcpu_vinotify_error: tstamp:11115184170 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355685391616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.152953: rtcpu_vinotify_error: tstamp:11115185039 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355685402272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.152955: rtcpu_vinotify_event: tstamp:11115191342 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:355685317920 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.152956: rtcpu_vinotify_event: tstamp:11115191490 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:355685318592 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.152956: rtcpu_vinotify_event: tstamp:11115191621 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:355685319264 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.152957: rtcpu_vinotify_event: tstamp:11115191769 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0xc1 frame:0 vi_tstamp:355685319264 data:0x0003200001000000
kworker/4:3-134     [004] ....   327.152958: rtcpu_vinotify_event: tstamp:11115191900 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:355685399680 data:0x0000000001020001
kworker/4:3-134     [004] ....   327.152958: rtcpu_vinotify_event: tstamp:11115192045 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:355685319264 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.152959: rtcpu_vinotify_event: tstamp:11115192176 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:355685319328 data:0x0000000800000000
kworker/4:3-134     [004] ....   327.152959: rtcpu_vinotify_event: tstamp:11115192325 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:355685319360 data:0x0000000800000000
kworker/4:3-134     [004] ....   327.152960: rtcpu_vinotify_event: tstamp:11115192456 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:355685319904 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.152961: rtcpu_vinotify_event: tstamp:11115192605 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355685380960 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.152961: rtcpu_vinotify_event: tstamp:11115192732 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355685391616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.152962: rtcpu_vinotify_event: tstamp:11115192880 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355685402272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.152963: rtcpu_vinotify_event: tstamp:11115193011 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:355685412960 data:0x0000000000000001
kworker/4:3-134     [004] ....   327.152963: rtcpu_vinotify_event: tstamp:11115193163 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:355685671552 data:0x0000000008020002
kworker/4:3-134     [004] ....   327.152964: rtcpu_vinotify_event: tstamp:11115193292 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:355686044416 data:0x379d580010000000
kworker/4:3-134     [004] ....   327.152964: rtcpu_vinotify_event: tstamp:11115650870 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:355686182496 data:0x0000000031000003
kworker/4:3-134     [004] ....   327.152965: rtcpu_vinotify_event: tstamp:11115651001 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:355694232224 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.152966: rtcpu_vinotify_event: tstamp:11115651148 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:355694234144 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.152966: rtcpu_vinotify_event: tstamp:11115651274 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:355694236096 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.264941: rtcpu_vinotify_error: tstamp:11118307067 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:355785319264 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.264944: rtcpu_vinotify_error: tstamp:11118308998 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355785382272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.264945: rtcpu_vinotify_error: tstamp:11118309868 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355785392960 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.264945: rtcpu_vinotify_error: tstamp:11118310733 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355785403616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.264947: rtcpu_vinotify_event: tstamp:11118312920 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:355785319264 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.264947: rtcpu_vinotify_event: tstamp:11118313055 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0xc1 frame:0 vi_tstamp:355785319264 data:0x0003200001000000
kworker/4:3-134     [004] ....   327.264948: rtcpu_vinotify_event: tstamp:11118313206 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:355785393120 data:0x0000000001020002
kworker/4:3-134     [004] ....   327.264948: rtcpu_vinotify_event: tstamp:11118313335 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:355785319264 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.264949: rtcpu_vinotify_event: tstamp:11118313486 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:355785319328 data:0x0000000800000000
kworker/4:3-134     [004] ....   327.264950: rtcpu_vinotify_event: tstamp:11118313618 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:355785319360 data:0x0000000800000000
kworker/4:3-134     [004] ....   327.264950: rtcpu_vinotify_event: tstamp:11118313766 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:355785319904 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.264951: rtcpu_vinotify_event: tstamp:11118313894 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:355785320576 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.264952: rtcpu_vinotify_event: tstamp:11118314042 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:355785321248 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.264952: rtcpu_vinotify_event: tstamp:11118314169 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355785382272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.264952: rtcpu_vinotify_event: tstamp:11118314314 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355785392960 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.264953: rtcpu_vinotify_event: tstamp:11118314441 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355785403616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.264953: rtcpu_vinotify_event: tstamp:11118776290 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:355785414304 data:0x0000000000000001
kworker/4:3-134     [004] ....   327.264954: rtcpu_vinotify_event: tstamp:11118776421 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:355785688864 data:0x0000000008020003
kworker/4:3-134     [004] ....   327.264954: rtcpu_vinotify_event: tstamp:11118776570 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:355786093024 data:0x379d550010000000
kworker/4:3-134     [004] ....   327.264954: rtcpu_vinotify_event: tstamp:11118776700 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:355786132064 data:0x0000000031000004
kworker/4:3-134     [004] ....   327.264955: rtcpu_vinotify_event: tstamp:11118776851 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:355794233536 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.264955: rtcpu_vinotify_event: tstamp:11118776980 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:355794235456 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.264955: rtcpu_vinotify_event: tstamp:11118777125 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:355794237408 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.321083: rtcpu_vinotify_error: tstamp:11121432031 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:355885320576 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.321086: rtcpu_vinotify_error: tstamp:11121434033 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355885383616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.321086: rtcpu_vinotify_error: tstamp:11121434906 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355885394272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.321087: rtcpu_vinotify_error: tstamp:11121435773 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355885415616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.321089: rtcpu_vinotify_event: tstamp:11121437640 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:355885320576 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.321089: rtcpu_vinotify_event: tstamp:11121437793 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0xc1 frame:0 vi_tstamp:355885320576 data:0x0003200001000000
kworker/4:3-134     [004] ....   327.321091: rtcpu_vinotify_event: tstamp:11121437926 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:355885394432 data:0x0000000001020003
kworker/4:3-134     [004] ....   327.321092: rtcpu_vinotify_event: tstamp:11121438076 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:355885320576 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.321092: rtcpu_vinotify_event: tstamp:11121438208 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:355885320672 data:0x0000000800000000
kworker/4:3-134     [004] ....   327.321093: rtcpu_vinotify_event: tstamp:11121438361 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:355885320704 data:0x0000000800000000
kworker/4:3-134     [004] ....   327.321094: rtcpu_vinotify_event: tstamp:11121438490 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:355885321248 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.321094: rtcpu_vinotify_event: tstamp:11121438637 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:355885321888 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.321094: rtcpu_vinotify_event: tstamp:11121438767 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:355885322560 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.377085: rtcpu_vinotify_event: tstamp:11121900682 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355885383616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.377087: rtcpu_vinotify_event: tstamp:11121900813 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355885394272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.377088: rtcpu_vinotify_event: tstamp:11121900966 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:355885404960 data:0x0000000000000001
kworker/4:3-134     [004] ....   327.377088: rtcpu_vinotify_event: tstamp:11121901097 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:355885661568 data:0x0000000008020004
kworker/4:3-134     [004] ....   327.377089: rtcpu_vinotify_event: tstamp:11121901248 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355885415616 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.377089: rtcpu_vinotify_event: tstamp:11121901377 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:355894234848 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.377090: rtcpu_vinotify_event: tstamp:11121901525 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:355894236800 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.377090: rtcpu_vinotify_event: tstamp:11121901653 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:355894238720 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.432938: rtcpu_vinotify_error: tstamp:11124554229 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:355985321920 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.432941: rtcpu_vinotify_error: tstamp:11124557531 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355985384928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.432941: rtcpu_vinotify_error: tstamp:11124558571 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355985395584 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.432942: rtcpu_vinotify_error: tstamp:11124559444 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:355985406272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.432942: rtcpu_vinotify_error: tstamp:11124560318 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355985416928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.432944: rtcpu_vinotify_event: tstamp:11124561722 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:355985321920 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.432945: rtcpu_vinotify_event: tstamp:11124561857 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0xc1 frame:0 vi_tstamp:355985321920 data:0x0004200001000000
kworker/4:3-134     [004] ....   327.432945: rtcpu_vinotify_event: tstamp:11124562010 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:355985394400 data:0x0000000001020004
kworker/4:3-134     [004] ....   327.432946: rtcpu_vinotify_event: tstamp:11124562141 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:355985321920 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.432946: rtcpu_vinotify_event: tstamp:11124562294 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:355985321984 data:0x0000000800000000
kworker/4:3-134     [004] ....   327.432947: rtcpu_vinotify_event: tstamp:11124562424 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:355985322560 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.432948: rtcpu_vinotify_event: tstamp:11124562575 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:355985323200 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.432948: rtcpu_vinotify_event: tstamp:11124562705 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:355985323904 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.489085: rtcpu_vinotify_event: tstamp:11125026577 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:355985384928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.489087: rtcpu_vinotify_event: tstamp:11125026708 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:355985395584 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.489088: rtcpu_vinotify_event: tstamp:11125026862 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:355985406272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.489088: rtcpu_vinotify_event: tstamp:11125026991 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:355985416928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.489088: rtcpu_vinotify_event: tstamp:11125027137 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:355994236192 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.489089: rtcpu_vinotify_event: tstamp:11125027264 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:355994238112 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.489090: rtcpu_vinotify_event: tstamp:11125027409 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:355994240032 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.545085: rtcpu_vinotify_error: tstamp:11127676019 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356085323168 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.545087: rtcpu_vinotify_error: tstamp:11127676910 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356085386240 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.545088: rtcpu_vinotify_error: tstamp:11127678317 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356085396928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.545088: rtcpu_vinotify_error: tstamp:11127679186 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356085407584 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.545089: rtcpu_vinotify_error: tstamp:11127680059 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356085418272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.545091: rtcpu_vinotify_event: tstamp:11127680808 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356085323168 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.545091: rtcpu_vinotify_event: tstamp:11127680957 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356085323200 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.545091: rtcpu_vinotify_event: tstamp:11127681087 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356085323840 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.545092: rtcpu_vinotify_event: tstamp:11127681233 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356085324480 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.545093: rtcpu_vinotify_event: tstamp:11127681363 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356085325152 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.545093: rtcpu_vinotify_event: tstamp:11127681512 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356085386240 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.545094: rtcpu_vinotify_event: tstamp:11127681643 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356085396928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.545094: rtcpu_vinotify_event: tstamp:11127681795 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356085407584 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.545095: rtcpu_vinotify_event: tstamp:11127681926 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356085418272 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.545096: rtcpu_vinotify_event: tstamp:11128150804 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356094237504 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.545096: rtcpu_vinotify_event: tstamp:11128150935 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356094239424 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.545097: rtcpu_vinotify_event: tstamp:11128151084 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:356094241376 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.657084: rtcpu_vinotify_error: tstamp:11130799817 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356185326528 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.657087: rtcpu_vinotify_error: tstamp:11130800707 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356185387552 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.657087: rtcpu_vinotify_error: tstamp:11130802112 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356185398240 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.657088: rtcpu_vinotify_error: tstamp:11130802984 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356185408928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.657088: rtcpu_vinotify_error: tstamp:11130803858 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356185419584 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.657090: rtcpu_vinotify_event: tstamp:11131080690 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356185324544 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.657090: rtcpu_vinotify_event: tstamp:11131080838 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356185325216 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.657091: rtcpu_vinotify_event: tstamp:11131080969 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356185325856 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.657092: rtcpu_vinotify_event: tstamp:11131081119 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356185326528 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.657092: rtcpu_vinotify_event: tstamp:11131081250 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356185326560 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.657093: rtcpu_vinotify_event: tstamp:11131081412 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356185387552 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.657094: rtcpu_vinotify_event: tstamp:11131081543 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356185398240 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.657094: rtcpu_vinotify_event: tstamp:11131081692 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356185408928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.657095: rtcpu_vinotify_event: tstamp:11131081823 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356185419584 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.657095: rtcpu_vinotify_event: tstamp:11131081972 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356194238784 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.657096: rtcpu_vinotify_event: tstamp:11131082102 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356194240704 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.657096: rtcpu_vinotify_event: tstamp:11131082250 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:356194242656 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.769084: rtcpu_vinotify_error: tstamp:11133926381 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356285327808 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.769086: rtcpu_vinotify_error: tstamp:11133927272 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356285388896 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.769087: rtcpu_vinotify_error: tstamp:11133928155 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356285399584 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.769087: rtcpu_vinotify_error: tstamp:11133929022 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356285410208 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.769088: rtcpu_vinotify_error: tstamp:11133930416 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356285420928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.769090: rtcpu_vinotify_event: tstamp:11133930925 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356285325824 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.769090: rtcpu_vinotify_event: tstamp:11134401560 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356285326464 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.769091: rtcpu_vinotify_event: tstamp:11134401691 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356285327136 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.769092: rtcpu_vinotify_event: tstamp:11134401840 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356285327808 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.769094: rtcpu_vinotify_event: tstamp:11134401971 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356285327808 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.769094: rtcpu_vinotify_event: tstamp:11134402120 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356285388896 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.769095: rtcpu_vinotify_event: tstamp:11134402249 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356285399584 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.769095: rtcpu_vinotify_event: tstamp:11134402399 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356285410208 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.769096: rtcpu_vinotify_event: tstamp:11134402526 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356285420928 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.769096: rtcpu_vinotify_event: tstamp:11134402674 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:356294156192 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.769097: rtcpu_vinotify_event: tstamp:11134402801 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356294228800 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.769098: rtcpu_vinotify_event: tstamp:11134402948 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356294230720 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.825083: rtcpu_vinotify_error: tstamp:11137052324 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:356385328480 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.825085: rtcpu_vinotify_error: tstamp:11137053204 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356385390208 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.825085: rtcpu_vinotify_error: tstamp:11137054089 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356385400896 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.825086: rtcpu_vinotify_error: tstamp:11137054956 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356385411552 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.825086: rtcpu_vinotify_error: tstamp:11137055822 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356385422240 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.825088: rtcpu_vinotify_event: tstamp:11137057661 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356385327136 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.825089: rtcpu_vinotify_event: tstamp:11137057810 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356385327808 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.825089: rtcpu_vinotify_event: tstamp:11137057937 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:356385328480 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.825090: rtcpu_vinotify_event: tstamp:11137058086 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356385328480 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.825090: rtcpu_vinotify_event: tstamp:11137058217 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356385329120 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.881083: rtcpu_vinotify_event: tstamp:11137526516 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356385390208 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.881085: rtcpu_vinotify_event: tstamp:11137526647 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356385400896 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.881085: rtcpu_vinotify_event: tstamp:11137526800 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356385411552 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.881086: rtcpu_vinotify_event: tstamp:11137526930 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356385422240 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.881087: rtcpu_vinotify_event: tstamp:11137527081 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:356394157504 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.881087: rtcpu_vinotify_event: tstamp:11137527211 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356394230112 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.881088: rtcpu_vinotify_event: tstamp:11137527356 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356394232032 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.937083: rtcpu_vinotify_error: tstamp:11140176261 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:356485329792 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.937085: rtcpu_vinotify_error: tstamp:11140177146 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356485391552 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.937086: rtcpu_vinotify_error: tstamp:11140178561 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356485402240 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.937087: rtcpu_vinotify_error: tstamp:11140179430 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356485412864 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.937087: rtcpu_vinotify_error: tstamp:11140180302 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356485423552 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.937089: rtcpu_vinotify_event: tstamp:11140181053 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356485328480 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.937090: rtcpu_vinotify_event: tstamp:11140181202 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356485329120 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.937090: rtcpu_vinotify_event: tstamp:11140181336 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:356485329792 data:0x00000000000000a0
kworker/4:3-134     [004] ....   327.937091: rtcpu_vinotify_event: tstamp:11140181485 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356485329792 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.937091: rtcpu_vinotify_event: tstamp:11140181613 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356485330464 data:0x0000000000000010
kworker/4:3-134     [004] ....   327.937092: rtcpu_vinotify_event: tstamp:11140181764 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356485391552 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.937092: rtcpu_vinotify_event: tstamp:11140181893 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356485402240 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.937093: rtcpu_vinotify_event: tstamp:11140182044 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356485412864 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.937093: rtcpu_vinotify_event: tstamp:11140182172 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356485423552 data:0x0000000000000549
kworker/4:3-134     [004] ....   327.937094: rtcpu_vinotify_event: tstamp:11140650905 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:356494158816 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.937094: rtcpu_vinotify_event: tstamp:11140651036 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356494231456 data:0x0000000000000020
kworker/4:3-134     [004] ....   327.937095: rtcpu_vinotify_event: tstamp:11140651187 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356494233344 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.049090: rtcpu_vinotify_error: tstamp:11143299869 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:356585329792 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.049092: rtcpu_vinotify_error: tstamp:11143300750 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356585392864 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.049093: rtcpu_vinotify_error: tstamp:11143302163 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356585403520 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.049093: rtcpu_vinotify_error: tstamp:11143303029 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356585414208 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.049094: rtcpu_vinotify_error: tstamp:11143303894 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356585424896 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.049095: rtcpu_vinotify_event: tstamp:11143580755 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:356585329792 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.049096: rtcpu_vinotify_event: tstamp:11143580912 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356585329792 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.049097: rtcpu_vinotify_event: tstamp:11143581040 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356585330464 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.049097: rtcpu_vinotify_event: tstamp:11143581185 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356585331104 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.049098: rtcpu_vinotify_event: tstamp:11143581312 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356585331776 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.049098: rtcpu_vinotify_event: tstamp:11143581460 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356585392864 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.049099: rtcpu_vinotify_event: tstamp:11143581587 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356585403520 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.049100: rtcpu_vinotify_event: tstamp:11143581735 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356585414208 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.049100: rtcpu_vinotify_event: tstamp:11143581862 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356585424896 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.049101: rtcpu_vinotify_event: tstamp:11143582010 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:356594160128 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.049101: rtcpu_vinotify_event: tstamp:11143582137 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356594232736 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.049102: rtcpu_vinotify_event: tstamp:11143582284 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356594234688 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.161084: rtcpu_vinotify_error: tstamp:11146425214 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:356685331136 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.161086: rtcpu_vinotify_error: tstamp:11146426652 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356685394176 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.161087: rtcpu_vinotify_error: tstamp:11146427529 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356685404864 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.161087: rtcpu_vinotify_error: tstamp:11146428397 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356685415520 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.161087: rtcpu_vinotify_error: tstamp:11146429262 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356685426208 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.161089: rtcpu_vinotify_event: tstamp:11146429782 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:356685331136 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.161090: rtcpu_vinotify_event: tstamp:11146901227 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356685331136 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.161090: rtcpu_vinotify_event: tstamp:11146901359 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356685331776 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.161091: rtcpu_vinotify_event: tstamp:11146901506 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356685332448 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.161092: rtcpu_vinotify_event: tstamp:11146901633 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356685333120 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.161092: rtcpu_vinotify_event: tstamp:11146901782 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356685394176 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.161093: rtcpu_vinotify_event: tstamp:11146901909 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356685404864 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.161093: rtcpu_vinotify_event: tstamp:11146902055 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356685415520 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.161094: rtcpu_vinotify_event: tstamp:11146902183 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356685426208 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.161094: rtcpu_vinotify_event: tstamp:11146902330 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356694245408 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.161095: rtcpu_vinotify_event: tstamp:11146902456 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:356694247328 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.161095: rtcpu_vinotify_event: tstamp:11146902601 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356694249248 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.273086: rtcpu_vinotify_error: tstamp:11149552487 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356785333760 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.273088: rtcpu_vinotify_error: tstamp:11149553373 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356785395520 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.273089: rtcpu_vinotify_error: tstamp:11149554247 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356785406176 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.273090: rtcpu_vinotify_error: tstamp:11149555113 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356785416864 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.273090: rtcpu_vinotify_error: tstamp:11149555980 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356785427552 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.273092: rtcpu_vinotify_event: tstamp:11149557827 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356785332448 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.273093: rtcpu_vinotify_event: tstamp:11149557975 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356785333120 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.273093: rtcpu_vinotify_event: tstamp:11149558103 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356785333760 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.273094: rtcpu_vinotify_event: tstamp:11149558251 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356785333760 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.273095: rtcpu_vinotify_event: tstamp:11149558378 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356785334432 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.273095: rtcpu_vinotify_event: tstamp:11150026070 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356785395520 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.273096: rtcpu_vinotify_event: tstamp:11150026198 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356785406176 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.273096: rtcpu_vinotify_event: tstamp:11150026349 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356785416864 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.273097: rtcpu_vinotify_event: tstamp:11150026478 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356785427552 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.273097: rtcpu_vinotify_event: tstamp:11150026626 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356794246720 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.273098: rtcpu_vinotify_event: tstamp:11150026753 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:356794248672 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.273099: rtcpu_vinotify_event: tstamp:11150026901 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356794250592 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.329083: rtcpu_vinotify_error: tstamp:11152676425 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356885335104 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.329085: rtcpu_vinotify_error: tstamp:11152677316 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356885396768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.329086: rtcpu_vinotify_error: tstamp:11152678722 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356885407456 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.329086: rtcpu_vinotify_error: tstamp:11152679593 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356885418144 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.329087: rtcpu_vinotify_error: tstamp:11152680455 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356885428800 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.329089: rtcpu_vinotify_event: tstamp:11152681211 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356885333760 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.329089: rtcpu_vinotify_event: tstamp:11152681359 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356885334432 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.329089: rtcpu_vinotify_event: tstamp:11152681490 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356885335104 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.329090: rtcpu_vinotify_event: tstamp:11152681635 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356885335104 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.329091: rtcpu_vinotify_event: tstamp:11152681762 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356885335744 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.329091: rtcpu_vinotify_event: tstamp:11152681910 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356885396768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.329092: rtcpu_vinotify_event: tstamp:11152682037 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356885407456 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.329092: rtcpu_vinotify_event: tstamp:11152682183 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356885418144 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.329093: rtcpu_vinotify_event: tstamp:11152682312 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356885428800 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.385084: rtcpu_vinotify_event: tstamp:11153151372 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356894248096 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.385086: rtcpu_vinotify_event: tstamp:11153151499 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356894250048 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.385086: rtcpu_vinotify_event: tstamp:11153151646 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:356894251968 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.441083: rtcpu_vinotify_error: tstamp:11155800108 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356985336416 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.441085: rtcpu_vinotify_error: tstamp:11155800992 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356985398112 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.441086: rtcpu_vinotify_error: tstamp:11155802399 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356985408800 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.441087: rtcpu_vinotify_error: tstamp:11155803265 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356985419424 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.441087: rtcpu_vinotify_error: tstamp:11155804130 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356985430112 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.441089: rtcpu_vinotify_event: tstamp:11156081223 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:356985335104 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.441089: rtcpu_vinotify_event: tstamp:11156081368 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:356985335776 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.441090: rtcpu_vinotify_event: tstamp:11156081499 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:356985336416 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.441090: rtcpu_vinotify_event: tstamp:11156081647 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:356985336416 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.441091: rtcpu_vinotify_event: tstamp:11156081774 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:356985337056 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.441092: rtcpu_vinotify_event: tstamp:11156081930 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:356985398112 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.441092: rtcpu_vinotify_event: tstamp:11156082058 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:356985408800 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.441093: rtcpu_vinotify_event: tstamp:11156082205 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:356985419424 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.441094: rtcpu_vinotify_event: tstamp:11156082333 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:356985430112 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.441094: rtcpu_vinotify_event: tstamp:11156082477 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:356994249376 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.441094: rtcpu_vinotify_event: tstamp:11156082601 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:356994251328 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.441095: rtcpu_vinotify_event: tstamp:11156082748 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:356994253248 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.553084: rtcpu_vinotify_error: tstamp:11158926709 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357085337696 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.553086: rtcpu_vinotify_error: tstamp:11158927600 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357085399424 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.553087: rtcpu_vinotify_error: tstamp:11158928483 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357085410080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.553087: rtcpu_vinotify_error: tstamp:11158929349 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357085420768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.553088: rtcpu_vinotify_error: tstamp:11158930742 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357085431456 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.553090: rtcpu_vinotify_event: tstamp:11158931254 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357085336352 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.553090: rtcpu_vinotify_event: tstamp:11159402006 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357085337024 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.553090: rtcpu_vinotify_event: tstamp:11159402138 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357085337696 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.553091: rtcpu_vinotify_event: tstamp:11159402289 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357085337696 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.553092: rtcpu_vinotify_event: tstamp:11159402417 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357085338336 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.553092: rtcpu_vinotify_event: tstamp:11159402565 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357085399424 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.553093: rtcpu_vinotify_event: tstamp:11159402692 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357085410080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.553094: rtcpu_vinotify_event: tstamp:11159402837 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357085420768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.553094: rtcpu_vinotify_event: tstamp:11159402968 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357085431456 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.553095: rtcpu_vinotify_event: tstamp:11159403112 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357094250688 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.553095: rtcpu_vinotify_event: tstamp:11159403238 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357094252640 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.553096: rtcpu_vinotify_event: tstamp:11159403383 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:357094254560 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.665084: rtcpu_vinotify_error: tstamp:11162051971 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357185337760 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.665086: rtcpu_vinotify_error: tstamp:11162052858 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357185400768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.665087: rtcpu_vinotify_error: tstamp:11162053736 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357185411424 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.665088: rtcpu_vinotify_error: tstamp:11162054602 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357185422080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.665088: rtcpu_vinotify_error: tstamp:11162055475 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357185432768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.665090: rtcpu_vinotify_event: tstamp:11162057036 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357185337760 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.665090: rtcpu_vinotify_event: tstamp:11162057183 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357185337760 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.665091: rtcpu_vinotify_event: tstamp:11162057312 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357185338400 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.665092: rtcpu_vinotify_event: tstamp:11162057457 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357185339040 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.665092: rtcpu_vinotify_event: tstamp:11162057583 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357185339712 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.665093: rtcpu_vinotify_event: tstamp:11162526887 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357185400768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.665094: rtcpu_vinotify_event: tstamp:11162527015 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357185411424 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.665096: rtcpu_vinotify_event: tstamp:11162527164 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357185422080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.665096: rtcpu_vinotify_event: tstamp:11162527290 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357185432768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.665097: rtcpu_vinotify_event: tstamp:11162527437 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357194252032 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.665097: rtcpu_vinotify_event: tstamp:11162527562 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357194253952 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.665098: rtcpu_vinotify_event: tstamp:11162527712 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:357194255872 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.720934: rtcpu_vinotify_error: tstamp:11165176515 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357285339072 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.720934: rtcpu_vinotify_error: tstamp:11165177408 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357285402080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.720935: rtcpu_vinotify_error: tstamp:11165178812 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357285412736 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.720935: rtcpu_vinotify_error: tstamp:11165179683 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357285423424 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.720935: rtcpu_vinotify_error: tstamp:11165180555 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357285434112 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.720936: rtcpu_vinotify_event: tstamp:11165181306 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357285339072 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.720936: rtcpu_vinotify_event: tstamp:11165181459 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357285339072 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.720937: rtcpu_vinotify_event: tstamp:11165181587 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357285339712 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.720937: rtcpu_vinotify_event: tstamp:11165181735 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357285340384 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.720937: rtcpu_vinotify_event: tstamp:11165181866 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357285341024 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.720938: rtcpu_vinotify_event: tstamp:11165182011 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357285402080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.720938: rtcpu_vinotify_event: tstamp:11165182140 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357285412736 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.720939: rtcpu_vinotify_event: tstamp:11165182288 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357285423424 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.720939: rtcpu_vinotify_event: tstamp:11165182417 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357285434112 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.777084: rtcpu_vinotify_event: tstamp:11165651113 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357294253344 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.777086: rtcpu_vinotify_event: tstamp:11165651245 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357294255264 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.777086: rtcpu_vinotify_event: tstamp:11165651394 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:357294257216 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.833081: rtcpu_vinotify_error: tstamp:11168300197 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357385340384 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.833083: rtcpu_vinotify_error: tstamp:11168301083 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357385403392 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.833084: rtcpu_vinotify_error: tstamp:11168302487 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357385414080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.833084: rtcpu_vinotify_error: tstamp:11168303356 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357385424768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.833085: rtcpu_vinotify_error: tstamp:11168304227 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357385435392 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.833087: rtcpu_vinotify_event: tstamp:11168580887 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357385340384 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.833087: rtcpu_vinotify_event: tstamp:11168581038 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357385340416 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.833088: rtcpu_vinotify_event: tstamp:11168581167 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357385341056 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.833088: rtcpu_vinotify_event: tstamp:11168581312 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357385341696 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.833089: rtcpu_vinotify_event: tstamp:11168581442 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357385342368 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.833089: rtcpu_vinotify_event: tstamp:11168581591 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357385403392 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.833090: rtcpu_vinotify_event: tstamp:11168581720 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357385414080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.833091: rtcpu_vinotify_event: tstamp:11168581870 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357385424768 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.833091: rtcpu_vinotify_event: tstamp:11168581998 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357385435392 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.833092: rtcpu_vinotify_event: tstamp:11168582146 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357394254688 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.833092: rtcpu_vinotify_event: tstamp:11168582275 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357394256608 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.833093: rtcpu_vinotify_event: tstamp:11168582421 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:357394258528 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.945084: rtcpu_vinotify_error: tstamp:11171425541 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357485341664 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.945086: rtcpu_vinotify_error: tstamp:11171426984 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357485404736 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.945087: rtcpu_vinotify_error: tstamp:11171427863 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357485415392 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.945087: rtcpu_vinotify_error: tstamp:11171428736 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357485426080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.945087: rtcpu_vinotify_error: tstamp:11171429609 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357485436736 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.945089: rtcpu_vinotify_event: tstamp:11171430114 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357485341664 data:0x00000000000000a0
kworker/4:3-134     [004] ....   328.945090: rtcpu_vinotify_event: tstamp:11171901332 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357485341664 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.945090: rtcpu_vinotify_event: tstamp:11171901465 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357485342304 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.945091: rtcpu_vinotify_event: tstamp:11171901618 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357485342976 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.945092: rtcpu_vinotify_event: tstamp:11171901748 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357485343648 data:0x0000000000000010
kworker/4:3-134     [004] ....   328.945092: rtcpu_vinotify_event: tstamp:11171901897 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357485404736 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.945093: rtcpu_vinotify_event: tstamp:11171902028 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357485415392 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.945093: rtcpu_vinotify_event: tstamp:11171902180 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357485426080 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.945094: rtcpu_vinotify_event: tstamp:11171902311 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357485436736 data:0x0000000000000549
kworker/4:3-134     [004] ....   328.945095: rtcpu_vinotify_event: tstamp:11171902457 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357494255936 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.945095: rtcpu_vinotify_event: tstamp:11171902584 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357494257888 data:0x0000000000000020
kworker/4:3-134     [004] ....   328.945096: rtcpu_vinotify_event: tstamp:11171902732 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:357494259808 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.056934: rtcpu_vinotify_error: tstamp:11174550715 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357585344960 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.056936: rtcpu_vinotify_error: tstamp:11174551603 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357585406048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.056936: rtcpu_vinotify_error: tstamp:11174553032 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357585416736 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.056936: rtcpu_vinotify_error: tstamp:11174553902 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357585427392 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.056936: rtcpu_vinotify_error: tstamp:11174554773 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357585438048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.056937: rtcpu_vinotify_event: tstamp:11174555279 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357585342976 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.056938: rtcpu_vinotify_event: tstamp:11174555424 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357585343648 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.056938: rtcpu_vinotify_event: tstamp:11174555553 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357585344288 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.056938: rtcpu_vinotify_event: tstamp:11174555703 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357585344960 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.056938: rtcpu_vinotify_event: tstamp:11174555834 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357585344960 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.056938: rtcpu_vinotify_event: tstamp:11175026329 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357585406048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.056938: rtcpu_vinotify_event: tstamp:11175026459 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357585416736 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.056938: rtcpu_vinotify_event: tstamp:11175026613 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357585427392 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.056939: rtcpu_vinotify_event: tstamp:11175026748 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357585438048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.056939: rtcpu_vinotify_event: tstamp:11175026897 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357594257280 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.056939: rtcpu_vinotify_event: tstamp:11175027026 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357594259200 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.056939: rtcpu_vinotify_event: tstamp:11175027172 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:357594261120 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.168937: rtcpu_vinotify_error: tstamp:11177676792 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357685346304 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.168939: rtcpu_vinotify_error: tstamp:11177677684 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357685407392 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.168939: rtcpu_vinotify_error: tstamp:11177679098 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357685418048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.168939: rtcpu_vinotify_error: tstamp:11177679969 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357685428704 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.168939: rtcpu_vinotify_error: tstamp:11177680835 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357685439392 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.168941: rtcpu_vinotify_event: tstamp:11177681585 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357685344320 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.168942: rtcpu_vinotify_event: tstamp:11177681736 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357685344960 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.168942: rtcpu_vinotify_event: tstamp:11177681867 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357685345600 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.168942: rtcpu_vinotify_event: tstamp:11177682015 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:357685346304 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.168942: rtcpu_vinotify_event: tstamp:11177682146 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357685346304 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.168943: rtcpu_vinotify_event: tstamp:11177682295 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357685407392 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.168943: rtcpu_vinotify_event: tstamp:11177682437 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357685418048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.168943: rtcpu_vinotify_event: tstamp:11177682587 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357685428704 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.168943: rtcpu_vinotify_event: tstamp:11177682714 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357685439392 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.168943: rtcpu_vinotify_event: tstamp:11178151757 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:357694174688 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.168943: rtcpu_vinotify_event: tstamp:11178151888 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357694247264 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.168943: rtcpu_vinotify_event: tstamp:11178152036 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357694249184 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.224931: rtcpu_vinotify_error: tstamp:11180800435 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:357785346944 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.224932: rtcpu_vinotify_error: tstamp:11180801316 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357785408672 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.224932: rtcpu_vinotify_error: tstamp:11180802731 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357785419360 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.224932: rtcpu_vinotify_error: tstamp:11180803601 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357785430048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.224932: rtcpu_vinotify_error: tstamp:11180804465 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357785440704 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.280934: rtcpu_vinotify_event: tstamp:11181081683 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357785345600 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.280937: rtcpu_vinotify_event: tstamp:11181081832 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357785346304 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.280937: rtcpu_vinotify_event: tstamp:11181081962 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:357785346944 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.280938: rtcpu_vinotify_event: tstamp:11181082107 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357785346944 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.280938: rtcpu_vinotify_event: tstamp:11181082237 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357785347616 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.280938: rtcpu_vinotify_event: tstamp:11181082390 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357785408672 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.280939: rtcpu_vinotify_event: tstamp:11181082520 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357785419360 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.280939: rtcpu_vinotify_event: tstamp:11181082674 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357785430048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.280939: rtcpu_vinotify_event: tstamp:11181082804 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357785440704 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.280940: rtcpu_vinotify_event: tstamp:11181082951 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:357794175968 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.280940: rtcpu_vinotify_event: tstamp:11181083081 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357794248576 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.280941: rtcpu_vinotify_event: tstamp:11181083226 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357794250496 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.337085: rtcpu_vinotify_error: tstamp:11183927045 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:357885348256 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.337088: rtcpu_vinotify_error: tstamp:11183927929 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357885410016 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.337089: rtcpu_vinotify_error: tstamp:11183928815 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357885420704 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.337089: rtcpu_vinotify_error: tstamp:11183929683 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357885431360 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.337090: rtcpu_vinotify_error: tstamp:11183931078 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357885442048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.337092: rtcpu_vinotify_event: tstamp:11183931587 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357885346944 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.337092: rtcpu_vinotify_event: tstamp:11184401556 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357885347584 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.337093: rtcpu_vinotify_event: tstamp:11184401688 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:357885348256 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.337093: rtcpu_vinotify_event: tstamp:11184401843 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357885348256 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.337094: rtcpu_vinotify_event: tstamp:11184401975 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357885348928 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.337095: rtcpu_vinotify_event: tstamp:11184402124 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357885410016 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.337095: rtcpu_vinotify_event: tstamp:11184402254 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357885420704 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.337096: rtcpu_vinotify_event: tstamp:11184402400 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357885431360 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.337096: rtcpu_vinotify_event: tstamp:11184402530 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357885442048 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.337097: rtcpu_vinotify_event: tstamp:11184402678 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:357894177312 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.337097: rtcpu_vinotify_event: tstamp:11184402805 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357894249920 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.337098: rtcpu_vinotify_event: tstamp:11184402951 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357894251840 data:0x0000000000000020
   v4l2-ctl-3287    [011] ....   329.433422: tegra_channel_close: vi-output, SensorName 20-0063
   v4l2-ctl-3287    [011] ....   329.433487: tegra_channel_set_stream: enable : 0x0
   v4l2-ctl-3287    [011] ....   329.433489: tegra_channel_set_stream: SensorName 20-0063 : 0x0
   v4l2-ctl-3287    [011] ....   329.436968: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
   v4l2-ctl-3287    [011] ....   329.436972: csi_s_stream: enable : 0x0
kworker/4:3-134     [004] ....   329.448965: rtcpu_vinotify_error: tstamp:11187052985 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:357985349600 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.448968: rtcpu_vinotify_error: tstamp:11187053868 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357985411328 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.448969: rtcpu_vinotify_error: tstamp:11187054754 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357985422016 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.448969: rtcpu_vinotify_error: tstamp:11187055620 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357985432672 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.448970: rtcpu_vinotify_error: tstamp:11187056482 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357985443360 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.448972: rtcpu_vinotify_event: tstamp:11187058317 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:357985348256 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.448972: rtcpu_vinotify_event: tstamp:11187058465 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:357985348928 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.448973: rtcpu_vinotify_event: tstamp:11187058593 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x02 frame:0 vi_tstamp:357985349600 data:0x00000000000000a0
kworker/4:3-134     [004] ....   329.448973: rtcpu_vinotify_event: tstamp:11187058742 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:357985349600 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.448974: rtcpu_vinotify_event: tstamp:11187058873 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:357985350240 data:0x0000000000000010
kworker/4:3-134     [004] ....   329.448976: rtcpu_nvcsi_intr: tstamp:11187495433 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
kworker/4:3-134     [004] ....   329.448976: rtcpu_nvcsi_intr: tstamp:11187495433 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/4:3-134     [004] ....   329.448977: rtcpu_vinotify_event: tstamp:11187526515 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:357985411328 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.448977: rtcpu_vinotify_event: tstamp:11187526648 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:357985422016 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.448977: rtcpu_vinotify_event: tstamp:11187526800 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:357985432672 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.448978: rtcpu_vinotify_event: tstamp:11187526930 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:357985443360 data:0x0000000000000549
kworker/4:3-134     [004] ....   329.448978: rtcpu_vinotify_event: tstamp:11187527081 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:357994178592 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.448979: rtcpu_vinotify_event: tstamp:11187527211 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:357994251232 data:0x0000000000000020
kworker/4:3-134     [004] ....   329.448979: rtcpu_vinotify_event: tstamp:11187527358 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:357994253152 data:0x0000000000000020
   v4l2-ctl-3287    [000] ....   329.451337: tegra_channel_set_power: SensorName 20-0063 : 0x0
   v4l2-ctl-3287    [000] ....   329.451341: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
   v4l2-ctl-3287    [000] ....   329.451346: csi_s_power: enable : 0x0
Best,
Jim
And,
the stream could rarely be read successfully, the trace log showed below
   v4l2-ctl-3080    [000] ....   234.378114: tegra_channel_open: vi-output, SensorName 20-0063
   v4l2-ctl-3080    [000] ....   234.399510: tegra_channel_set_power: SensorName 20-0063 : 0x1
   v4l2-ctl-3080    [000] ....   234.399513: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
   v4l2-ctl-3080    [000] ....   234.399515: csi_s_power: enable : 0x1
   v4l2-ctl-3080    [000] ....   234.399582: tegra_channel_capture_setup: vnc_id 0 W 8000 H 216 fmt 5
kworker/4:3-134     [004] ....   234.424955: rtcpu_string: tstamp:8218182910 id:0x04010000 str:"VM0 activating."
   v4l2-ctl-3080    [002] ....   234.427265: tegra_channel_set_stream: enable : 0x1
   v4l2-ctl-3080    [002] ....   234.455332: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
   v4l2-ctl-3080    [002] ....   234.455334: csi_s_stream: enable : 0x1
   v4l2-ctl-3080    [002] ....   234.455706: tegra_channel_set_stream: SensorName 20-0063 : 0x1
kworker/4:3-134     [004] ....   234.480939: rtcpu_vinotify_event: tstamp:8218946009 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:262993501376 data:0x379d580010000000
kworker/4:3-134     [004] ....   234.480940: rtcpu_vinotify_event: tstamp:8218946197 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:262993507872 data:0x0000000031000001
kworker/4:3-134     [004] ....   234.480941: rtcpu_vinotify_event: tstamp:8218947788 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:262993558624 data:0x379d550010000000
kworker/4:3-134     [004] ....   234.480941: rtcpu_vinotify_event: tstamp:8218947953 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:262993565216 data:0x0000000031000002
kworker/4:3-134     [004] ....   234.480943: rtcpu_nvcsi_intr: tstamp:8219551945 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
kworker/4:3-134     [004] ....   234.480944: rtcpu_nvcsi_intr: tstamp:8219551945 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/4:3-134     [004] ....   234.480944: rtcpu_nvcsi_intr: tstamp:8219555983 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x01c00000
kworker/4:3-134     [004] ....   234.480945: rtcpu_nvcsi_intr: tstamp:8219555983 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00c00000
vi-output, awr2-3082    [001] ....   234.527094: tegra_channel_capture_frame: sof:263.84209344
vi-output, awr2-3082    [001] ....   234.527096: tegra_channel_capture_frame: eof:263.92965984
kworker/4:3-134     [004] ....   234.536940: rtcpu_vinotify_error: tstamp:8221388519 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:263084198624 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.536941: rtcpu_vinotify_error: tstamp:8221389401 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:263084220000 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.536941: rtcpu_vinotify_error: tstamp:8221390275 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:263084230656 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.536942: rtcpu_vinotify_event: tstamp:8221393885 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:263084136160 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.536943: rtcpu_vinotify_event: tstamp:8221394017 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:263084136832 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.536943: rtcpu_vinotify_event: tstamp:8221394165 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:263084137504 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.536943: rtcpu_vinotify_event: tstamp:8221394297 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:263084138176 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.536944: rtcpu_vinotify_event: tstamp:8221394450 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:263084138240 data:0x0000000800000000
kworker/4:3-134     [004] ....   234.536944: rtcpu_vinotify_event: tstamp:8221394584 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:263084198624 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.536945: rtcpu_vinotify_event: tstamp:8221394733 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:263084209344 data:0x0000000000000001
kworker/4:3-134     [004] ....   234.536945: rtcpu_vinotify_event: tstamp:8221394863 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:263084237024 data:0x0000000008020001
kworker/4:3-134     [004] ....   234.536945: rtcpu_vinotify_event: tstamp:8221395012 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:263084220000 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.536946: rtcpu_vinotify_event: tstamp:8221395140 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:263084230656 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.536946: rtcpu_vinotify_event: tstamp:8221661803 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:263092941920 data:0x0000000000d70002
kworker/4:3-134     [004] ....   234.536947: rtcpu_vinotify_event: tstamp:8221661935 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:263092942752 data:0x0000000000000000
kworker/4:3-134     [004] ....   234.593092: rtcpu_vinotify_event: tstamp:8222119165 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:263092968448 data:0x0000000002020001
kworker/4:3-134     [004] ....   234.593094: rtcpu_vinotify_event: tstamp:8222119296 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:263092965856 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.593094: rtcpu_vinotify_event: tstamp:8222119449 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:263092965984 data:0x0000000800000000
kworker/4:3-134     [004] ....   234.593095: rtcpu_vinotify_event: tstamp:8222119579 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:263093024160 data:0x0000000000020001
kworker/4:3-134     [004] ....   234.593095: rtcpu_vinotify_event: tstamp:8222119729 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:263093038528 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.593096: rtcpu_vinotify_event: tstamp:8222119858 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:263093040448 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.649091: rtcpu_vinotify_error: tstamp:8224515965 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:0 vi_tstamp:263184138752 data:0x00000000000000a0
kworker/4:3-134     [004] ....   234.649094: rtcpu_vinotify_error: tstamp:8224516847 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:263184199808 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.649094: rtcpu_vinotify_error: tstamp:8224517735 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:263184210496 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.649095: rtcpu_vinotify_error: tstamp:8224519128 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:263184221120 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.649097: rtcpu_vinotify_event: tstamp:8224521338 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:263184136768 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.649097: rtcpu_vinotify_event: tstamp:8224521472 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:263184137440 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.649098: rtcpu_vinotify_event: tstamp:8224521626 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:263184137536 data:0x0000000800000000
kworker/4:3-134     [004] ....   234.649098: rtcpu_vinotify_event: tstamp:8224521756 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:263184138112 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.649099: rtcpu_vinotify_event: tstamp:8224521904 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:0 vi_tstamp:263184138752 data:0x00000000000000a0
kworker/4:3-134     [004] ....   234.649099: rtcpu_vinotify_event: tstamp:8224522032 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:263184138752 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.649100: rtcpu_vinotify_event: tstamp:8224522177 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:263184199808 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.649101: rtcpu_vinotify_event: tstamp:8224522307 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:263184210496 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.649101: rtcpu_vinotify_event: tstamp:8224522452 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:263184221120 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.649102: rtcpu_vinotify_event: tstamp:8224522584 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:263184231808 data:0x0000000000000001
kworker/4:3-134     [004] ....   234.649103: rtcpu_vinotify_event: tstamp:8224951272 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:263184351392 data:0x0000000008020002
kworker/4:3-134     [004] ....   234.649103: rtcpu_vinotify_event: tstamp:8224951403 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:263184751488 data:0x379d580010000000
kworker/4:3-134     [004] ....   234.649104: rtcpu_vinotify_event: tstamp:8224951552 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:263184790528 data:0x0000000031000003
kworker/4:3-134     [004] ....   234.649104: rtcpu_vinotify_event: tstamp:8224951682 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:263193051040 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.649105: rtcpu_vinotify_event: tstamp:8224951829 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:263193052992 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.649105: rtcpu_vinotify_event: tstamp:8224951956 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:263193054944 data:0x0000000000000020
   v4l2-ctl-3080    [002] ....   234.729260: tegra_channel_set_stream: enable : 0x0
   v4l2-ctl-3080    [002] ....   234.729262: tegra_channel_set_stream: SensorName 20-0063 : 0x0
   v4l2-ctl-3080    [002] ....   234.733425: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
   v4l2-ctl-3080    [002] ....   234.733427: csi_s_stream: enable : 0x0
   v4l2-ctl-3080    [002] ....   234.747555: tegra_channel_set_power: SensorName 20-0063 : 0x0
   v4l2-ctl-3080    [002] ....   234.747558: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
   v4l2-ctl-3080    [002] ....   234.747561: csi_s_power: enable : 0x0
kworker/4:3-134     [004] ....   234.760957: rtcpu_vinotify_error: tstamp:8227644714 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:263284139296 data:0x00000000000000a0
kworker/4:3-134     [004] ....   234.760960: rtcpu_vinotify_error: tstamp:8227645616 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:263284201056 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.760961: rtcpu_vinotify_error: tstamp:8227647517 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:263284211744 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.760962: rtcpu_vinotify_error: tstamp:8227648392 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:263284222368 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.760965: rtcpu_vinotify_event: tstamp:8227650515 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:263284137984 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.760966: rtcpu_vinotify_event: tstamp:8227650645 cch:-1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:263284138656 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.760966: rtcpu_vinotify_event: tstamp:8227650795 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x03 frame:0 vi_tstamp:263284139296 data:0x00000000000000a0
kworker/4:3-134     [004] ....   234.760967: rtcpu_vinotify_event: tstamp:8227650926 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0xc1 frame:0 vi_tstamp:263284139296 data:0x0003200001000000
kworker/4:3-134     [004] ....   234.760967: rtcpu_vinotify_event: tstamp:8227651075 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:263284219744 data:0x0000000001020002
kworker/4:3-134     [004] ....   234.760968: rtcpu_vinotify_event: tstamp:8227651202 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:263284139296 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.760969: rtcpu_vinotify_event: tstamp:8227651353 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:263284139392 data:0x0000000800000000
kworker/4:3-134     [004] ....   234.760970: rtcpu_vinotify_event: tstamp:8227651484 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:263284139392 data:0x0000000800000000
kworker/4:3-134     [004] ....   234.760971: rtcpu_vinotify_event: tstamp:8227651635 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:263284139968 data:0x0000000000000010
kworker/4:3-134     [004] ....   234.760971: rtcpu_vinotify_event: tstamp:8227651765 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:263284201056 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.760974: rtcpu_nvcsi_intr: tstamp:8227987735 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000088
kworker/4:3-134     [004] ....   234.760975: rtcpu_nvcsi_intr: tstamp:8227987735 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/4:3-134     [004] ....   234.760975: rtcpu_vinotify_event: tstamp:8228076810 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:263284211744 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.760976: rtcpu_vinotify_event: tstamp:8228076940 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:263284222368 data:0x0000000000000549
kworker/4:3-134     [004] ....   234.760977: rtcpu_vinotify_event: tstamp:8228077093 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:263284233088 data:0x0000000000000001
kworker/4:3-134     [004] ....   234.760977: rtcpu_vinotify_event: tstamp:8228077224 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:263284499040 data:0x0000000008020003
kworker/4:3-134     [004] ....   234.760978: rtcpu_vinotify_event: tstamp:8228077378 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:263284897056 data:0x379d550010000000
kworker/4:3-134     [004] ....   234.760978: rtcpu_vinotify_event: tstamp:8228077507 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:263284936096 data:0x0000000031000004
kworker/4:3-134     [004] ....   234.760979: rtcpu_vinotify_event: tstamp:8228077653 cch:-1 vi:0 tag:FE channel:0x02 frame:0 vi_tstamp:263293052288 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.760979: rtcpu_vinotify_event: tstamp:8228077780 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:263293054208 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.760980: rtcpu_vinotify_event: tstamp:8228077924 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:263293056128 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.760980: rtcpu_vinotify_event: tstamp:8228767871 cch:-1 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:263312669440 data:0x0000000000000020
kworker/4:3-134     [004] ....   234.760981: rtcpu_vinotify_event: tstamp:8228768123 cch:-1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0xc1 frame:0 vi_tstamp:263312669472 data:0x0003200001000000
kworker/4:3-134     [004] ....   234.760981: rtcpu_vinotify_event: tstamp:8228768334 cch:-1 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:263312669472 data:0x0000000800000000
   v4l2-ctl-3080    [002] ....   234.767884: tegra_channel_close: vi-output, SensorName 20-0063
kworker/4:3-134     [004] ....   240.936972: rtcpu_string: tstamp:8421480376 id:0x04010000 str:"VM0 deactivating."
For more information, we always connect 4 same sensor to Orin by SerDes, we already made sure that the bandwidth and serdes_pix_clk(1.6G) is enough to receive 4 stream at same time.
When we only connect one sensor to Orin, it always working well.
Thank you.
hello timelim,
according to SerDes Pixel Clock section, skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
may I know which Jetpack release version you’re now using. it looks like a deskew timeout issue that we’ve experienced before r35.3.1
