hi there
I am new to Omniverse !
so I have a problem which is that whenever I try to set up the wizard tool to put my modelled car “in blender” into animation, the tires rotate around the wizard tires instead rotating around its own axis ! I set the geomertry to its origin and i made sure the tires rotate around itself before making any progress …but I ended up with the same results !
Hello @Massinissa! I’ve shared your post with the dev team for further assistance.
Since you are new, I recommend that you join our discord server at discord.gg/nvidiaomniverse where we have 1,000’s of members, industry professionals, and developers ready to assist you with any questions you may have!
Hello @Massinissa! Suggestion from the dev team:
You may have an additional translation or “offset” in the hierarchy of your tire. Try to “zero out” any additional translations before childing the tire to the wizard tire.
Let me know if this helps you along, if not, can you either attach your USD file or email it to me here: omniversecommunity@nvidia-omniverse.atlassian.net
thanks
it worked as I set translation to 0 !
