Issue pulling CLARA
This may be related general NGC cloud i am getting following error trying to login using docker
docker login nvcr.io
Username: $oauthtoken
Password:
Error response from daemon: Get https://nvcr.io/v2/: read tcp 10.138.42.100:37544->52.9.91.71:443: read: connection reset by peer
FYI i was able to login to NGC and generate key fine
Resolved
This is due to proxy issue. Docker-ce using uppercase environment variables. you can configure proxy correctly using the documentation below.
I also encountered the same problem, can you describe the solution in more detail, thank you very much
Hi 184699599,
If your system has proxy settings, you may see some settings when you execute the following command:
$ printenv | grep -i proxy
http_proxy=http://proxy.example.com:80/
https_proxy=http://proxy.example.com:80/
no_proxy=127.0.0.1
What prakashmsa is saying is that docker is taking uppercase environment variables for proxy settings so user need to setup environment with uppercase variable names.
export HTTP_PROXY=http://proxy.example.com:80/
export HTTPS_PROXY=http://proxy.example.com:80/
export NO_PROXY=127.0.0.1
You can make it permanent by using the instruction at https://docs.docker.com/config/daemon/systemd/ or by referring to the answer here (method 3 for proxy settings on Clara Deploy SDK) : https://devtalk.nvidia.com/default/topic/1069612/clara-deploy-sdk-new-/pipeline-cannot-connect-to-tensorrt-server/post/5420268/#5420268
It was written for proxy setting on Kubernetes, but it is also applied to the general docker proxy setting.
Reference:
FYI, you can download/install the latest version (0.4.1, 12/10/2019) from the following links:
https://ngc.nvidia.com/catalog/model-scripts/nvidia:clara_deploy_sdk/setup
https://docs.nvidia.com/clara/deploy/ClaraInstallation.html
Thank you very much for your answer
