Issue Pulling Extensions on Kit 110
Operating System:
Windows
Linux
Kit Version:
110 (Kit App Template)
109 (Kit App Template)
108 (Kit App Template)
107 (Kit App Template)
106 (Kit App Template)
105 (Launcher)
Kit Template:
USD Composer
USD Explorer
USD Viewer
Custom
GPU Hardware:
A series (Blackwell)
A series (ADA)
A series
50 series
40 series
30 series
GPU Driver:
Latest
Recommended (573.xx)
Other
Work Flow: Building the base kit–app-template
Main Issue: Fails to pull dependencies
Reproduction Steps: Just create a new app with repo template and build using repo build. It works fine with Kit 109. All Kit 110 versions produce this error.
Error Code:
2026-06-01T17:45:11Z [1,945ms] [Error] [omni.kit.registry.nucleus.index_v2.index_sync] Syncing registry index failed for url: ‘https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/110/shared/v2’. Exception: Traceback (most recent call last):
File “d:/public-repos/kit-app-template/_build/windows-x86_64/release/kit/extscore/omni.kit.registry.nucleus/omni/kit/registry/nucleus/index_v2/index_sync.py”, line 129, in _task
self._task_uncaught()
File “d:/public-repos/kit-app-template/_build/windows-x86_64/release/kit/extscore/omni.kit.registry.nucleus/omni/kit/registry/nucleus/index_v2/index_sync.py”, line 149, in _task_uncaught
self._registry_file = RegistryFile(self._local_path)
File “d:/public-repos/kit-app-template/build/windows-x86_64/release/kit/extscore/omni.kit.registry.nucleus/omni/kit/registry/nucleus/index_v2/registry_file.py", line 28, in init
data = json.loads(f.read())
File "d:\public-repos\kit-app-template_build\windows-x86_64\release\kit\python\Lib\json_init
.py”, line 346, in loads
return _default_decoder.decode(s)
File “d:\public-repos\kit-app-template_build\windows-x86_64\release\kit\python\Lib\json\decoder.py”, line 338, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “d:\public-repos\kit-app-template_build\windows-x86_64\release\kit\python\Lib\json\decoder.py”, line 356, in raw_decode
raise JSONDecodeError(“Expecting value”, s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
2026-06-01T17:45:14Z [4,122ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
  • No versions of omni.anim.curve.bundle that satisfies: my_company.my_usd_composer-0.1.0 depends on omni.anim.curve.bundle version *
    • Available packages for omni.anim.curve.bundle version *:
      (none found)
      Synced registries:
    • kit/default : found 0 packages (couldn’t connect or empty)
    • kit/sdk : found 386 packages
    • kit/community : found 600 packages
2026-06-01T17:45:14Z [4,122ms] [Error] [omni.kit.app.plugin] Failed to generate version file, kit file: my_company.my_usd_composer-0.1.0 failed to resolve dependencies.
2026-06-01T17:45:14Z [4,123ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure…
Hmm, that is strange. I have not seen or heard of this error for 110. What is exact version? 110.1?
My recommendation is to do a hard flush or the OV folder in your users folder and start fresh. That will clear out any stale issues. I just built 110, so I know it ok
Ah, I should have tried another machine. Something corrupted my cached extensions. Deleted it and re-built. It’s working fine now.
Good to hear
