Issue Running isaac_ros_common Repository in Docker
I’m encountering an error when trying to set up the isaac_ros_common repository using Docker.
The problem occurs when executing the following command:
cd ${ISAAC_ROS_WS}/src/isaac_ros_common &&
./scripts/run_dev.sh
Error:
Running isaac_ros_dev-x86_64-container
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error mounting "/usr/lib/x86_64-linux-gnu/libEGL_nvidia.so.525.147.05" to rootfs at "/usr/lib/x86_64-linux-gnu/libEGL_nvidia.so.525.147.05": stat /usr/lib/x86_64-linux-gnu/libEGL_nvidia.so.525.147.05: no such file or directory: unknown.
~/workspaces/isaac_ros-dev/src/isaac_ros_common
My Docker works fine when I run the “hello-world” container using the following commands:
sudo service docker start
sudo docker run hello-world
I’ve tried reinstalling the nvidia container toolkit and tried removing the isaac ros image and rebuilding it.
Please help me find a solution
docker rmi isaac_ros_dev-x86_64
Hi @sweetyleah0
Looking at your error, your x86 machine doesn’t have all libraries installed.
Check if GPU libraries are installed, running:
nvidia-smi
and check if CUDA is installed with the correct version, running:
/usr/local/cuda/bin/nvcc --version
Isaac ROS 2.0 run with: CUDA 11.8+
All system requirements are available on this page: https://nvidia-isaac-ros.github.io/getting_started/index.html
