Issue having import OpenCV and Tensorflow. This is the error I am getting. I pull the docker image from this link. The Jtpack version is 4.6(L4T R32.6.1) on this link.
NVIDIA L4T ML | NVIDIA NGC.
Hi @jazzysehgalofficial, since you are running L4T R32.6.1, are you using the nvcr.io/nvidia/l4t-ml:r32.6.1-py3
container? Also are you starting it with --runtime nvidia
? On JetPack4, the CUDA libraries get mounted into the container from the host by the NVIDIA Container Runtime.
Can you also try running this outside of container, to make sure you have the CUDA Toolkit libraries installed on your device?
ls /usr/local/cuda/lib64
libcublasLt.so libcufft_static.a libcurand_static.a libnppial.so.10 libnppif.so.10 libnppisu.so.10 libnvgraph.so.10.2.300
libcublasLt.so.10 libcufft_static_nocallback.a libcusolver.so libnppial.so.10.2.1.300 libnppif.so.10.2.1.300 libnppisu.so.10.2.1.300 libnvgraph_static.a
libcublasLt.so.10.2.3.300 libcufftw.so libcusolver.so.10 libnppial_static.a libnppif_static.a libnppisu_static.a libnvperf_host.so
libcublasLt_static.a libcufftw.so.10 libcusolver.so.10.3.0.300 libnppicc.so libnppig.so libnppitc.so libnvperf_target.so
libcublas.so libcufftw.so.10.1.2.300 libcusolver_static.a libnppicc.so.10 libnppig.so.10 libnppitc.so.10 libnvrtc-builtins.so
libcublas.so.10 libcufftw_static.a libcusparse.so libnppicc.so.10.2.1.300 libnppig.so.10.2.1.300 libnppitc.so.10.2.1.300 libnvrtc-builtins.so.10.2
libcublas.so.10.2.3.300 libcuinj64.so libcusparse.so.10 libnppicc_static.a libnppig_static.a libnppitc_static.a libnvrtc-builtins.so.10.2.300
libcublas_static.a libcuinj64.so.10.2 libcusparse.so.10.3.1.300 libnppicom.so libnppim.so libnpps.so libnvrtc.so
libcudadevrt.a libcuinj64.so.10.2.300 libcusparse_static.a libnppicom.so.10 libnppim.so.10 libnpps.so.10 libnvrtc.so.10.2
libcudart.so libculibos.a liblapack_static.a libnppicom.so.10.2.1.300 libnppim.so.10.2.1.300 libnpps.so.10.2.1.300 libnvrtc.so.10.2.300
libcudart.so.10.2 libcupti.so libmetis_static.a libnppicom_static.a libnppim_static.a libnpps_static.a libnvToolsExt.so
libcudart.so.10.2.300 libcupti.so.10.2 libnppc.so libnppidei.so libnppist.so libnvblas.so libnvToolsExt.so.1
libcudart_static.a libcupti.so.10.2.175 libnppc.so.10 libnppidei.so.10 libnppist.so.10 libnvblas.so.10 libnvToolsExt.so.1.0.0
libcufft.so libcurand.so libnppc.so.10.2.1.300 libnppidei.so.10.2.1.300 libnppist.so.10.2.1.300 libnvblas.so.10.2.3.300 stubs
libcufft.so.10 libcurand.so.10 libnppc_static.a libnppidei_static.a libnppist_static.a libnvgraph.so
libcufft.so.10.1.2.300 libcurand.so.10.1.2.300 libnppial.so libnppif.so libnppisu.so libnvgraph.so.10
