• Hardware Platform (RTX A5000 and 3080 GPU) in laptop • DeepStream Version: 5.0 & 6.0
deepstream docker image version: nvcr.io/nvidia/deepstream:6.0-devel
CUDA: 11.4
cuDNN: 8.2+
TensorRT: 8.0.1
Driver: R470.63.01+ • NVIDIA GPU Driver Version (valid for GPU only): 470 & 510 • Issue Type( questions, new requirements, bugs):
when run docker run --gpus ‘“‘device=0’”’ -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY…
gui x window is black and command line message shows “cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1”
this problem occurs in RTX A5000 and 3080 laptop. The OS is ubuntu 20.04.
there is no these issues in my personal computer and the graphic card is gtx 1660.
reproduce the issue in RTX A5000 or RTX3080 laptop and OS is ubuntu 20.04,
nvidia driver is 470 or 510, install docker ce and nvidia-docker.
docker pull deepstream 5.0 or 6.0
when run deepstream-app, the x window is black.
command line message shows “cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1” • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
But when I run “sudo nvidia-xconfig” and /etc/X11/xorg.conf can be prodused, my laptop cannot boot into desktop any more. I have to boot from ubuntu 20.04 usb drive and remove the /etc/X11/xorg.conf, then my notebook can boot into desktop.
I Check my OpenGL version via “sudo glxinfo | grep OpenGL”.
And run “sudo apt-get install mesa-common-dev libgl1-mesa-dev libglu1-mesa-dev”.
The big problem is solved.
Thanks your help very much.
