I am getting this error to open unity sim where it immediately cuts out.
Set current directory to /home/anuj.chadha/isaac_sim_unity3d/builds
Found path: /home/anuj.chadha/isaac_sim_unity3d/builds/sample.x86_64
Mono path[0] = ‘/home/anuj.chadha/isaac_sim_unity3d/builds/sample_Data/Managed’
Mono config path = ‘/home/anuj.chadha/isaac_sim_unity3d/builds/sample_Data/MonoBleedingEdge/etc’
Preloaded ‘libSubstance.Engine.so’
Preloaded ‘libsubstance_sse2_blend.so’
Display 0 ‘0’: 1366x768 (primary device).
Display 1 ‘DELL P2419H 24"’: 1920x1080 (secondary device).
Display 2 ‘DELL P2419H 24"’: 1920x1080 (secondary device).
Unable to load player prefs
Desktop is 1366 x 768 @ 60 Hz
[Vulkan init] extensions: count=15
[Vulkan init] extensions: name=VK_KHR_device_group_creation, enabled=0
[Vulkan init] extensions: name=VK_KHR_display, enabled=1
[Vulkan init] extensions: name=VK_KHR_external_fence_capabilities, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_memory_capabilities, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_semaphore_capabilities, enabled=0
[Vulkan init] extensions: name=VK_KHR_get_physical_device_properties2, enabled=0
[Vulkan init] extensions: name=VK_KHR_get_surface_capabilities2, enabled=0
[Vulkan init] extensions: name=VK_KHR_surface, enabled=1
[Vulkan init] extensions: name=VK_KHR_xcb_surface, enabled=0
[Vulkan init] extensions: name=VK_KHR_xlib_surface, enabled=1
[Vulkan init] extensions: name=VK_EXT_acquire_xlib_display, enabled=0
[Vulkan init] extensions: name=VK_EXT_debug_report, enabled=0
[Vulkan init] extensions: name=VK_EXT_debug_utils, enabled=0
[Vulkan init] extensions: name=VK_EXT_direct_mode_display, enabled=0
[Vulkan init] extensions: name=VK_EXT_display_surface_counter, enabled=0
Vulkan detection: 0
No supported renderers found, exiting
(Filename: Line: 618)
Could you provide some advice?
