• Network Type (Classification)
• TLT Version (2.0 )
• Hardware [Jetson: TX-2]
• Deepstream (5.0)
• Jetpack (4.4)
We are learning TLT and trying to prototype a simple image classification model with Deepstream. JPG images (width=28 x height=62 x channel=3) are classified into: green, yellow and red.
After collecting some training images and saving in dataset/test/green, dataset/test/yellow, … dataset/val/green, .etc …, we started to use TLT 2.0 to train.
tlt-train, tlt-evaluate, tlt-infer and tlt-export all work well and we got test.etlt to deploy.
Then we use the following gst-launch script to test:
gst-launch-1.0 filesrc location="data/input.jpg" ! jpegparse ! nvv4l2decoder ! queue ! nvstreammux0.sink_0 nvstreammux name=nvstreammux0 width=28 height=62 batch-size=1 batched-push-timeout=40000 live-source=TRUE ! queue ! nvvideoconvert ! queue ! nvinfer config-file-path="test.txt" ! queue ! nvdsosd process-mode=HW_MODE ! queue ! nvoverlaysink sync=false
and we got this error below. As it suggested, we got stuck on the number 1536 and 3072. Wondering this issue is on the TLT side or deepstream. So any tip or guidance is really appreciated. Thanks a lot.
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
0:00:00.198450599 31688 0x555a3ce130 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
ERROR: [TRT]: predictions/MatMul: kernel weights has count 1536 but 3072 was expected
ERROR: [TRT]: UffParser: Parser error: predictions/BiasAdd: The input to the Scale Layer is required to have a minimum of 3 dimensions.
parseModel: Failed to parse UFF model
The model is resnet-10 and the tail shows
block_4a_relu (Activation) (None, 512, 2, 4) 0 add_4[0][0]
__________________________________________________________________________________________________
avg_pool (AveragePooling2D) (None, 512, 1, 1) 0 block_4a_relu[0][0]
flatten (Flatten) (None, 512) 0 avg_pool[0][0]
predictions (Dense) (None, 3) 1539 flatten[0][0]
Total params: 4,917,443
Trainable params: 4,824,323
Non-trainable params: 93,120
The training specs file:
model_config {
# Model architecture can be chosen from:
# ['resnet', 'vgg', 'googlenet', 'alexnet', 'mobilenet_v1', 'mobilenet_v2', 'squeezenet', 'darknet', 'googlenet']
arch: "resnet"
# for resnet --> n_layers can be [10, 18, 34, 50, 101]
# for vgg --> n_layers can be [16, 19]
# for darknet --> n_layers can be [19, 53]
n_layers: 10
use_bias: False
use_batch_norm: True
all_projections: True
use_pooling: False
freeze_bn: False
freeze_blocks: 0
freeze_blocks: 1
# image size should be "3, X, Y", where X,Y >= 16
input_image_size: "3,28,62"
train_config {
train_dataset_path: "/workspace/dataset/train"
val_dataset_path: "/workspace/dataset/val"
# optimizer can be chosen from ['adam', 'sgd']
optimizer: "sgd"
batch_size_per_gpu: 32
n_epochs: 10
n_workers: 2
# regularizer
reg_config {
type: "L2"
scope: "Conv2D,Dense"
weight_decay: 0.00005
# learning_rate
lr_config {
# "step" and "soft_anneal" are supported.
scheduler: "soft_anneal"
# "soft_anneal" stands for soft annealing learning rate scheduler.
# the following 4 parameters should be specified if "soft_anneal" is used.
learning_rate: 0.005
soft_start: 0.056
annealing_points: "0.3, 0.6, 0.8"
annealing_divider: 10
# "step" stands for step learning rate scheduler.
# the following 3 parameters should be specified if "step" is used.
# learning_rate: 0.006
# step_size: 10
# gamma: 0.1
# "cosine" stands for soft start cosine learning rate scheduler.
# the following 2 parameters should be specified if "cosine" is used.
# learning_rate: 0.05
# soft_start: 0.01
nvinfer config file test.txt
[property]
gpu-id=0
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=0
labelfile-path=test_labels.txt
tlt-encoded-model=test.etlt
tlt-model-key=[my_key]
infer-dims=3;62;28
uff-input-blob-name=input_1
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
interval=0
gie-unique-id=1
#0=Detection 1=Classification 2=Segmentation
network-type=1
scaling-filter=1
scaling-compute-hw=1
output-blob-names=predictions/Softmax
classifier-threshold=0.5
