Issue when operating the camera in Isaac Sim
Hello, I am an Isaac Sim 2023.1.1. user. When using Isaac Sim with a camera and over 20 different environments, I experience a issue like below picture. (I am using an RTX 4090 GPU.)
Is there any way to solve this problem? If so, I would appreciate your advice.
@chanmilee.0419 i am just another user, but would it be possible to post the most recently .log in its entirety? and would lowering the number of environments impacts whether the issue’s persistency?
Which type of .log file are you referring to? Could you provide an example of a log file name? Additionally, I need to configure more than 100 environments for parallel learning.
you can find the log directory under section 1 of this section: Setup FAQ — Omniverse IsaacSim latest documentation (nvidia.com)
