Issue when probing devices
Iam currently facing an issue when i probe my two devices. I want to enable virtual channels, here are my specs:
  • Imager: AR0820
  • Serializer: MAX9295
  • Deserializer: MAX9296
  • Jetson AGX Orin
  • Jetpack 5.1.3 / L4T 35.5.0
I use proxy addresses for my devices 0x1b and 0x1c with a physical address of 0x10.
The issue is that when i probe the first device 0x1b , it choses well the right device which is ar0820 30-001b. Here is a print of the logs to clarify :
Now the issue is with the second device 0x1c, it detects a sensor ar0820 30-001b to probe for ar0820 30-001c . As shown in the logs here :
For media-ctl seems to be good :
And for v4l2-ctl not setting the devices well:
My question is that why we do have this mismatch between v4l2-ctl and media-ctl ?
My device tree :
tegra234-p3737-0000-camera-ar0820-a00.dtsi.txt (5.8 KB)
tegra234-camera-ar0820-a00.dtsi.txt (18.2 KB)
hello ikram.el.moussaoui,
please examine the device tree from your system.
for instance, /proc/device-tree/i2c@3180000/tca9546@70/i2c@0/
do you have those two camera nodes (ar0820_a@1b and ar0820_b@1c) declare to the device-tree hierarchy correctly?
besides, are you able to fetch the stream?
Thanks for the reply.
As shown on my device tree above, i use both nodes (ar0820_a@1b and ar0820_b@1c )
For the stream, iam not able to fetch it.
please share the complete logs for reference.
besides, please check with Applications Using V4L2 IOCTL Directly to use V4L2 IOCTL to verify basic camera functionality.
Hello @JerryChang
Here is the output of both commands
had you verified this on previous Jetpack release version?
please gather the complete kernel logs, (i.e. $ dmesg > klogs.txt) and, attach it as single text file for reference.
besides,
please refer to Topic 284939 to apply pre-built update to enable infinite timeout property.
you may see-also developer guide, for the steps running with infinite timeouts while waiting for camera frames.
Hello @JerryChang ,
For the previous Jetpack version, did not try it because we already switched to the new version * Jetpack 5.1.3 / L4T 35.5.0
Here are the logs :
logs.txt (127.5 KB)
trace_argus.txt (21.9 KB)
you’ve two camera node register to linux kernel according to the logs.
[   12.722131] tegra-camrtc-capture-vi tegra-capture-vi: subdev ar0820 30-001b bound
[   12.731865] ar0820 30-001b: Detected AR0820 sensor
[   12.879845] tegra-camrtc-capture-vi tegra-capture-vi: subdev ar0820 30-001c bound
[   12.888868] ar0820 30-001c: Detected AR0820 sensor
there’re lots of logs for register writing when you’ve camera enabled.
I don’t see any error reported, then, you’ve terminate the stream, i.e. ar0820 30-001c: ar0820_power_off
besides, by checking your tracing logs, it might be issue on GMSL chip. since there’s no SOF nor EOF has detected.
