Issue when using Ossrs, RTMP and hardware encoders
• Hardware Platform (Jetson / GPU): Quadro P620
• Building docker container based on: nvcr.io/nvidia/deepstream:6.2-devel
• NVIDIA GPU Driver Version (valid for GPU only): 535.54.03
• Ossrs docker image: ossrs/srs:5
I use Ossrs with the attached config file below to create http flash video.
By using the code (attached below), I see:
  • With SW enc like x264enc, I can successfully publish rtmp url and display it by using VLC or ffplay, and also can display it by using Ossrs at port 18080 (192.168.1.86:18080) with input URL http://192.168.1.86:18080/2/stream.flv (this URL is published by Ossrs and the rtmpsink’s “location” property).
  • However, with HW enc like nvv4l2h264enc, it can be displayed by VLC or ffplay but lagging (VLC logs errors like the attached image), can not be displayed by Ossrs and http flash video.
“Cannot be displayed by Ossrs and htttp flash video” Image:
VLC logging:
VLC media player 3.0.9.2 Vetinari (revision 3.0.9.2-0-gd4c1aefe4d)
[0000563456703630] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[0000563456798220] main playlist: playlist is empty
libva info: VA-API version 1.7.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_7
libva info: va_openDriver() returns 0
[00007f85fcc7b6f0] avcodec decoder: Using Intel iHD driver for Intel(R) Gen Graphics - 20.1.1 () for hardware decoding
[00007f85f8000c80] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 1000 ms)
[00007f85f8000c80] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 1306 ms)
[00007f85f8000c80] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 1355 ms)
[00007f85f8000c80] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 1405 ms)
Config file for Ossrs:
# docker config for srs.
# @see full.conf for detail config.
listen              11935;
max_connections     1000;
# For docker, please use docker logs to manage the logs of SRS.
# See https://docs.docker.com/config/containers/logging/
srs_log_tank        console;
daemon              off;
http_api {
    enabled         on;
    listen          11985;
http_server {
    enabled         on;
    listen          18080;
    # dir             ./objs/nginx/html;
vhost __defaultVhost__ {
    http_remux {
        enabled     on;
        mount       [vhost]/[app]/[stream].flv;
    dvr {
        enabled         off;
    http_static {
        enabled     off;
    http_hooks {
        enabled         off;
And my main.py code:
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2021 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GstRtspServer", "1.0")
from gi.repository import Gst, GLib
import pyds
import sys
import math
from ctypes import *
import platform
import argparse
def bus_call(bus, message, user_data):
    loop = user_data
    t = message.type
    if t == Gst.MessageType.EOS:
        sys.stdout.write('DEBUG: EOS\n')
        loop.quit()
    elif t == Gst.MessageType.WARNING:
        err, debug = message.parse_warning()
        sys.stderr.write('WARNING: %s: %s\n' % (err, debug))
    elif t == Gst.MessageType.ERROR:
        err, debug = message.parse_error()
        sys.stderr.write('ERROR: %s: %s\n' % (err, debug))
        loop.quit()
    return True
def is_aarch64():
    return platform.uname()[4] == 'aarch64'
def cb_newpad(decodebin, decoder_src_pad, data):
    print("In cb_newpad\n")
    caps = decoder_src_pad.get_current_caps()
    gststruct = caps.get_structure(0)
    gstname = gststruct.get_name()
    source_bin = data
    features = caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=", gstname)
    if gstname.find("video") != -1:
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=", features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad = source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write(
                    "Failed to link decoder src pad to source bin ghost pad\n"
        else:
            sys.stderr.write(
                " Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
    print("Decodebin child added:", name, "\n")
    if name.find("decodebin") != -1:
        Object.connect("child-added", decodebin_child_added, user_data)
    if name.find('nvv4l2decoder') != -1:
        Object.set_property('drop-frame-interval', 0)
        Object.set_property('num-extra-surfaces', 1)
        if is_aarch64():
            Object.set_property('enable-max-performance', 1)
        else:
            Object.set_property('cudadec-memtype', 0)
            Object.set_property('gpu-id', 0)
def create_source_bin(index, uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name = "source-bin-%02d" % index
    print(bin_name)
    nbin = Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri", uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added", cb_newpad, nbin)
    uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin, uri_decode_bin)
    bin_pad = nbin.add_pad(
        Gst.GhostPad.new_no_target(
            "src", Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
# osd_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
def osd_sink_pad_buffer_probe(pad,info,u_data):
    global frame_number # Get number of frames
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    # Acquiring a display meta object. The memory ownership remains in
    # the C code so downstream plugins can still access it. Otherwise
    # the garbage collector will claim it when this probe function exits.
    display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number+=1
        #### Display text on stream ~~~~~~~~~~
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        # Setting display text to be shown on screen
        # Note that the pyds module allocates a buffer for the string, and the
        # memory will not be claimed by the garbage collector.
        # Reading the display_text field here will return the C address of the
        # allocated string. Use pyds.get_string() to get the string content.
        py_nvosd_text_params.display_text = "Frame Number={}".format(frame_number)
        # Now set the offsets where the string should appear
        py_nvosd_text_params.x_offset = 10
        py_nvosd_text_params.y_offset = 12
        # Font, font-color and font-size
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        # set(red, green, blue, alpha); set to White
        py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
        # Text background color
        py_nvosd_text_params.set_bg_clr = 1
        # set(red, green, blue, alpha); set to Black
        py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
def main(args):
    # Check input arguments
    number_sources = len(args)
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ", i, " \n ")
        uri_name = args[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname = "sink_%u" % i
        sinkpad = streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad = source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    # ****** Create video filter to convert frames to RGBA ************
    print("Creating filter1")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter = Gst.ElementFactory.make("capsfilter", "filter")
    if not filter:
        sys.stderr.write(" Unable to get the caps filter \n")
    filter.set_property("caps", caps1)
    print("Creating tiler \n ")
    tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvvidconv_postosd = Gst.ElementFactory.make(
        "nvvideoconvert", "convertor_postosd")
    if not nvvidconv_postosd:
        sys.stderr.write(" Unable to create nvvidconv_postosd \n")
    encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
    # encoder = Gst.ElementFactory.make("x264enc", "encoder")
    if not encoder:
        sys.stderr.write(" Unable to create encoder")
    # Make parser
    parser = Gst.ElementFactory.make("h264parse", "h264parse")
    if not parser:
        sys.stderr.write(" Unable to create h264parse")
    # Make matroskamux
    muxer = Gst.ElementFactory.make("flvmux", "flvmux")
    if not muxer:
        sys.stderr.write(" Unable to create flvmux")
    # Make queue
    queue = Gst.ElementFactory.make("queue", "queue")
    if not queue:
        sys.stderr.write(" Unable to create queue")
    # Make the file sink to save video
    sink = Gst.ElementFactory.make("rtmpsink", "rtmpsink")
    if not sink:
        sys.stderr.write(" Unable to create rtmpsink")
    sink.set_property("location", "rtmp://192.168.1.86:11935/2/stream")
    sink.set_property("sync", False)
    sink.set_property("async", True)
    streammux.set_property("width", 640)
    streammux.set_property("height", 480)
    streammux.set_property("batch-size", 1)
    streammux.set_property("batched-push-timeout", 4000000)
    print("Adding elements to Pipeline \n")
    tiler_rows = int(math.sqrt(number_sources))
    tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
    tiler.set_property("rows", tiler_rows)
    tiler.set_property("columns", tiler_columns)
    tiler.set_property("width", 640)
    tiler.set_property("height", 480)
    pipeline.add(tiler)
    pipeline.add(filter)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(nvvidconv_postosd)
    pipeline.add(encoder)
    pipeline.add(parser)
    pipeline.add(muxer)
    pipeline.add(queue)
    pipeline.add(sink)
    streammux.link(nvvidconv)
    nvvidconv.link(filter)
    filter.link(tiler)
    tiler.link(nvosd)
    nvosd.link(nvvidconv_postosd)
    nvvidconv_postosd.link(encoder)
    encoder.link(queue)
    queue.link(parser)
    parser.link(muxer)
    muxer.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    # Lets add probe to get informed of the meta data generated, we add probe to
    # the sink pad of the osd element, since by that time, the buffer would have
    # had got all the metadata.
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        sys.stderr.write(" Unable to get sink pad of nvosd \n")
    osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
    # start play back and listen to events
    print("Starting pipeline \n")
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except BaseException:
        pass
    # cleanup
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = argparse.ArgumentParser(description='RTSP Output Sample Application Help ')
    parser.add_argument("-i", "--input",
                  help="Path to input H264 elementry stream", nargs="+", default=["a"], required=True)
    if len(sys.argv)==1:
        parser.print_help(sys.stderr)
        sys.exit(1)
    args = parser.parse_args()
    global stream_path
    global frame_number
    frame_number = 0
    stream_path = args.input
    return stream_path
if __name__ == '__main__':
    stream_path = parse_args()
    sys.exit(main(stream_path))
Please upgrade to DeepStream 6.3.
Please try to set “idrinterval” property of nvv4l2h264enc to make the stream can be start in suitable position.
Hi @Fiona.Chen ,
I’ve tried DS63 (nvcr.io/nvidia/deepstream:6.3-samples) and it works succesfully, thank you.
Do you mean I should try to set “idrinterval” for this error? If yes, it doesn’t work for me. I don’t know I should increase or decrease, but I did try both.
Btw, I’m still facing the issue that the streaming on Ossrs (port 18080) is trying to load the video all the time. It’s kind of displaying a few seconds, then lagging, trying to load buffers, and displaying a few seconds again (spinning the loading circle).
If I use VLC, it will log the main input error: ES_OUT_SET_(GROUP_)PCR is called too late error.
Input is a rtsp url from my IP camera. If I use a file input (ex: sample_720p.h264), it works normally.
Could you mind giving me some advises, pls?
This VLC error means there are lots of corruptions in the stream, maybe it is caused by the package lost.
Please set a shorter IDR interval.
I try setting shorter idrinterval values, but the issue still remains.
Btw, I use this command instead of python codes and it displays normally on Ossrs 18080:
gst-launch-1.0 nvstreammux name=mux width=1920 height=1080 batch-size=1 ! nvstreamdemux name=demux uridecodebin uri=rtsp://IP_CAMERA ! nvvideoconvert ! "video/x-raw(memory:NVMM)" ! nvv4l2h264enc ! h264parse ! flvmux ! rtmpsink location=rtmp://192.168.1.86:11935/2/stream
Here is demo.zip containing 2 videos about launching the pipeline by using gst-launch (normal) and python codes (loading issue).
demo.zip (5.5 MB)
I don’t think the python language will involve extra network delay. Please check whether your code is exactly the same as the gst-launch pipeline.
I try simplifying the pipeline in python so that it can be similar to the gst-launch pipeline above, but it still doesn’t work.
Could you mind helping me check it, pls ? Maybe something is not correct at cb_newpad(), decodebin_child_added() or create_source_bin() functions. I haven’t known how they work in background yet.
import gi
import pyds
import sys
import math
import platform
import argparse
    loop = user_data
    t = message.type
        loop.quit()
        loop.quit()
    return True
def is_aarch64():
    source_bin = data
    # audio.
                sys.stderr.write(
        else:
            sys.stderr.write(
        if is_aarch64():
        else:
    # pipeline
    print(bin_name)
    if not nbin:
    # src pad.
    if not bin_pad:
        return None
    return nbin
    if not gst_buffer:
        return
        try:
            # it alone.
            break
        frame_number+=1
        try:
            break
def main(args):
    Gst.init(None)
    is_live = False
    if not pipeline:
    if not streammux:
        uri_name = args[i]
            is_live = True
        if not source_bin:
        if not sinkpad:
        if not srcpad:
    # caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM)")
    if not filter:
    if not tiler:
    if not nvvidconv:
    if not nvosd:
    if not encoder:
    # encoder.set_property("bitrate", 2048)
    # encoder.set_property("idrinterval", 5)
    # encoder.set_property("iframeinterval", 1024)
    # Make parser
    if not parser:
    # Make matroskamux
    if not muxer:
    # Make queue
    if not queue:
    if not sink:
    streammux.set_property("width", 1920)
    streammux.set_property("height", 1080)
    tiler.set_property("width", 1920)
    tiler.set_property("height", 1080)
    pipeline.add(tiler)
    pipeline.add(nvosd)
    pipeline.add(muxer)
    pipeline.add(queue)
    pipeline.add(sink)
    # nvvidconv.link(filter)
    # filter.link(tiler)
    # tiler.link(nvosd)
    # nvosd.link(nvvidconv_postosd)
    nvvidconv.link(encoder)
    encoder.link(queue)
    queue.link(parser)
    parser.link(muxer)
    muxer.link(sink)
    # osdsinkpad = nvosd.get_static_pad("sink")
    # if not osdsinkpad:
    #     sys.stderr.write(" Unable to get sink pad of nvosd \n")
    # osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
    try:
        loop.run()
        pass
    # cleanup
def parse_args():
        sys.exit(1)
    global stream_path
    global frame_number
    frame_number = 0
    # stream_path = ["file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264"]
    return stream_path
