Hi All,
I find the similar issue in TX1 dev board.
The usb device has those interfaces:
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/5p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/7p, 480M
|__ Port 6: Dev 4, If 0, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 6: Dev 4, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 6: Dev 4, If 2, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 6: Dev 4, If 3, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 6, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Playing pipeline is:
gst-launch-1.0 audiotestsrc ! audio/x-raw,format=S16LE,layout=interleaved,rate=48000,channels=2 ! audioconvert ! audio/x-raw,format=S24LE,layout=interleaved,rate=48000,channels=2 ! alsasink device=front:2 sync=0 async=0
Recording pipeline is:
gst-launch-1.0 alsasrc device=front:2 ! capsfilter caps=audio/x-raw,format=S24LE,layout=interleaved,rate=48000,channels=2 ! wavenc ! filesink location=file.wav sync=0 async=0
The recording pipeline can generate audio bytes properly but the speaker produce noise when I start both the two pipeline.
This issue happened in L4T r28.3.2 but was fixed in L4T r28.4.
This issue could be fixed if I copy the file “/lib/firmware/tegra21x_xusb_firmware” of L4T r28.4 to L4T r28.3.2.
So I think maybe this issue in TK1 can be fixed by upgrading the xusb firmware.
Could Nvidia look what has changed in these two versions of tx1 xusb Firmware? Could these changes be applied to TK1?
