Issue where HSB multi-camera transmission terminates unexpectedly with an error
When testing HSB multi-camera streaming on the Jetson AGX Thor, I observed that the program suddenly throws an error and exits after running for a period of time. What could be the potential causes for this?
Os Version:
HSB Version: 2.7.0
While looking into this issue, I discovered that other users have encountered similar problems.
Error 5 is TIMEOUT in NvFusaCaptureExternalEnums.hpp. The FuSa capture operator waited for the CoE hardware to complete a frame. The wait is 1500 ms by default, and no complete frame arrived in that time. The error is a symptom and not necessarily the root cause.
As you found above, there are known issues around CoE multi stream so I would suggest waiting until the next JetPack release for fixes.
Hi, yosil
Thank you for your reply.
