We have trained our Pytorch Unet model and converted that into TRT using the torch2trt but while feeding that into the Deepstream- 6 we are facing the errors logged below we have converted our torch2trt model on the same machine having deepstream having similar TRT version
(pytorch) nkumar@u117282:~/deepstream_trt$ deepstream-segmentation-app -t infer deepstream_tao_apps/configs/unet_tao/pgie_unet_tao_config.txt deepstream_tao_apps/***********67.11704647123835-81.03094573969791.h264
(deepstream-segmentation-app:4023651): GStreamer-WARNING **: 10:20:01.186: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
(deepstream-segmentation-app:4023651): GStreamer-WARNING **: 10:20:01.186: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(deepstream-segmentation-app:4023651): GStreamer-WARNING **: 10:20:01.187: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(deepstream-segmentation-app:4023651): GStreamer-WARNING **: 10:20:01.187: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
One element could not be created. Exiting.
Failed to create source bin. Exiting.
Can you pl help me with any reference Installation Guide for same without using Container/Docker on the Host OS Ubuntu20/18.04 running platform having Dgpu Dual A6000
In this triton docker, as at ds_triton_docker.txt (11.0 KB)
tached output log of below three commands, all the Triton relevant files, lib path env are all set correctly. If you don’t use DS Triton docker, e.g. installing DS outside of docker or using other DS non-Triton docker, you need to copy the relevant Triton files, set lib path env by himself.
ldd /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so
ls -l /opt/tritonserver/
env
