Hi @Morganh
I am using 2080TI GPU.
I am trying to write script for eye gazing model.
I was able to get the result from facial landmark model (facial landmarks, leye image,reye image) but I am unable to understand that how to pass these info to the eyegazing model. Please help me out in the scripting that how to preprocess images and facial landmarks for eye gazing model output.
FacialLandmark script.
import os
import time
import cv2
#import matplotlib.pyplot as plt
import numpy as np
import pycuda.autoinit
import pycuda.driver as cuda
import tensorrt as trt
from PIL import Image
import pdb
import codecs
import glob
import datetime
import shutil
from collections import OrderedDict
trt_engine_path = "../models/faciallandmark/faciallandmarks.etlt_b4_gpu0_int8.engine"
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
def load_engine(trt_runtime, engine_path):
with open(engine_path, "rb") as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
# Allocates all buffers required for an engine, i.e. host/device inputs/outputs.
#def allocate_buffers(engine, batch_size=-1):
inputs = []
outputs = []
bindings = []
stream = cuda.Stream()
for binding in engine:
# pdb.set_trace()
size = trt.volume(engine.get_binding_shape(binding)) * batch_size
dtype = trt.nptype(engine.get_binding_dtype(binding))
# Allocate host and device buffers
host_mem = cuda.pagelocked_empty(size, dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
# Append the device buffer to device bindings.
bindings.append(int(device_mem))
# Append to the appropriate list.
if engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
# print(f"input: shape:{engine.get_binding_shape(binding)} dtype:{engine.get_binding_dtype(binding)}")
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
# print(f"output: shape:{engine.get_binding_shape(binding)} dtype:{engine.get_binding_dtype(binding)}")
return inputs, outputs, bindings, stream
def do_model_2_inference(context, bindings, inputs, outputs, stream, batch_size=1):
# Transfer input data to the GPU.
[cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
# Run inference.
context.execute_async(
batch_size=batch_size, bindings=bindings, stream_handle=stream.handle
# Transfer predictions back from the GPU.
[cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
# Synchronize the stream
stream.synchronize()
# Return only the host outputs.
return [out.host for out in outputs]
def model_loading(trt_engine_path):
# TensorRT logger singleton
os.environ["CUDA_VISIBLE_DEVICES"] = "1"
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
# trt_engine_path = "/opt/smarg/surveillance_gateway_prod/surveillance_ai_model/x86_64/Secondary_NumberPlateClassification/lpr_us_onnx_b16.engine"
trt_runtime = trt.Runtime(TRT_LOGGER)
# pdb.set_trace()
trt_engine = load_engine(trt_runtime, trt_engine_path)
# Execution context is needed for inference
context = trt_engine.create_execution_context()
# NPR input shape
input_shape = (1,1,80,80)
context.set_binding_shape(0, input_shape)
# This allocates memory for network inputs/outputs on both CPU and GPU
inputs, outputs, bindings, stream = allocate_buffers(trt_engine)
return inputs, outputs, bindings, stream, context
inputs_model_2, outputs_model_2, bindings_model_2, stream_model_2, context_model_2 = model_loading(trt_engine_path)
def _landmark_minimax_boxes(landmarks, r):
landmarks = landmarks[r[0]:r[1]]
x0,y0 = np.min(landmarks, axis=0)
x1,y1 = np.max(landmarks, axis=0)
return [x0,y0,x1,y1]
def leye_boxes(landmarks):
return _landmark_minimax_boxes(landmarks, (42, 48))
def reye_boxes(landmarks):
return _landmark_minimax_boxes(landmarks, (36, 42))
orig_img = cv2.imread("./images/crop_face1.jpg")
orig_img_resize = cv2.resize(orig_img, (80, 80))
image = cv2.cvtColor(orig_img_resize, cv2.COLOR_BGR2GRAY)
image = [image]
# image = np.array([(cv2.resize(img, ( 80 , 80 )))/ 255.0 for img in image], dtype=np.float32)
image=np.array(image,dtype=np.float32)
np.copyto(inputs_model_2[0].host, image.ravel())
outputs = do_model_2_inference(context_model_2, bindings=bindings_model_2, inputs=inputs_model_2, outputs=outputs_model_2, stream=stream_model_2)
face_landmark_orig = (outputs[1].astype(int)).tolist()
# face_landmark = np.array([face_landmark_orig[x:x+2] for x in range(0, len(outputs[1]), 2)])
face_landmark = [face_landmark_orig[x:x+2] for x in range(0, len(outputs[1]), 2)]
print("face_landmark:",face_landmark)
print("outputs : ",len(outputs[1]))
for i in range(0,len(outputs[1]),2):
cv2.circle(orig_img_resize, (int(outputs[1][i]), int(outputs[1][i+1])), 1, (0, 0, 255 ), 1 )
leye_cord = leye_boxes(face_landmark)
reye_cord = reye_boxes(face_landmark)
cv2.rectangle(orig_img_resize, (leye_cord[0], leye_cord[1]), (leye_cord[2], leye_cord[3]), (255,0,0), 1)
cv2.rectangle(orig_img_resize, (reye_cord[0], reye_cord[1]), (reye_cord[2], reye_cord[3]), (255,0,0), 1)
leye_image = orig_img_resize[leye_cord[1]:leye_cord[3],leye_cord[0]:leye_cord[2]]
reye_image = orig_img_resize[reye_cord[1]:reye_cord[3],reye_cord[0]:reye_cord[2]]
cv2.imwrite('face_landmark.jpg',orig_img_resize)
OutputImage:
EyeGazing Script:
I would like to use eye_gazing function from facial_landmark and want to get output points returned by eye gazing model.
import os
import time
import cv2
import numpy as np
import pdb
import codecs
import glob
import datetime
import shutil
trt_engine_path = "../models/gazenet/gazenet_facegrid.etlt_b8_gpu0_fp16.engine"
def __str__(self):
def __repr__(self):
return engine
def allocate_buffers(engine, batch_size=1):
inputs = []
outputs = []
bindings = []
# pdb.set_trace()
else:
def do_model_2_inference(context, bindings, inputs, outputs, stream, batch_size=-1):
# Run inference.
# pdb.set_trace()
# NPR input shape
input_shape = (1,3,48,96)
print("inputs_model_2 : ",inputs_model_2)
def eye_gazing(face_image,leye_image,reye_image,face_landmark):
return eye_gazing_output
Please help me out. What change I can do to get the result.
