Issue while placing wifi card
Hello
While placing the Wifi card Ax200NGW on Jetson developer kit B01 version. The connection gets terminated.I found below issue by connecting it monitor. I am using latest 4.9.253-tegra version. Moreover, when I am using without card there no problem. Can anyone help me on this.
Use ctrl +alt + F1~6 to switch to console to operate.
Then dump the /var/log/Xorg.0.log when you connect the wifi card and hit the error.
BTW, this error is just desktop GUI missing, the system itself shall still work. That is why you shall be able to operate with console.
When I am connecting to any of the Wifi routers it’s getting restart for every 30secs. I can not able lo login into system. In case, if I removed the card it is working fine.
So are you able to try what I said or not?
I was not able to login into the system with wifi card for more than 30 secs. So I haven’t tried what you said.
Then please dump the log with uart console.
If your saw the system reboot, probably means kernel panic happened.
