The board was developed based on the jetson orin nx.
When i powered the board through the barrel jack, the input voltage is reaching 5v ic correctly. i measured 12.21v at the ic input pin, but i am only getting around 0.34v at the output instead of 5v.
could you please help me identify why the switching IC is not switching and what i should check to troubleshoot this issue?
yes, we used p3768_a04 concept and base version schematic for reference.
3.When i measured the voltage of EN pin it shows 5v
4.we manufactured 5 boards, that 5 boards have same problem.
The 5 V regulator IC’s SW pin measures only 0.34 V.
We are currently trying to debug the board and investigate the issue. However, some other tasks came up in between, so we had to put the debugging on hold for some time. That is why our response was delayed.
As part of the debugging, we captured the following waveforms:
SW (inductor side)
VDD_5V_SYS (capacitor/output side)
Please find the captured waveforms attached for your reference.
Please provide the part number (P/N) of the IC installed at U3.
Please measure the voltage at U3 pin 2 (EN) relative to GND.
Please measure FB, SW, and VDD_5V_SYS simultaneously during power-up, both with and without the SoM installed. Label the channels, measurement points, and scales, and ensure that the 0 V reference and actual voltage levels are visible.
With all power sources disconnected and the board discharged, please measure the resistance between VDD_5V_SYS and GND, both with and without the SoM installed. Include the units.
Please confirm that only L44 (3.3 µH) is populated among the inductor options, and that L42 and L43 are not populated.
Thanks for the detailed test results. The key finding is that SS (Soft-Start) pin = 0V — this pin should ramp up when the IC is enabled, and the IC cannot begin switching until SS rises. This explains why SW, FB, and PGOOD all remain near 0V.
Please check the following:
Verify the SS capacitor (C312) part number and value match the BOM.
Remove C312 and measure the SS pin voltage again — if it rises, C312 may be shorted or incorrect.
Measure the SS pin voltage on NV DevKit for comparison.
