Issue with Adding Bus Watch in NVDSAnalytics Test App
I’m currently working with the NVDSAnalytics test app and I’m trying to add a bus watch so I can handle messages (errors or state changes). However, I’m encountering some issues.
Here’s what I’ve tried:
First, I used the following code:
GstBus *bus = gst_pipeline_get_bus(GST_PIPELINE(appCtx[0]->pipeline.pipeline));
bus_watch_id = gst_bus_add_watch(bus, bus_call, appCtx[0]->pipeline.pipeline);
But I’m getting bus_watch_id = 0.
Then, I tried this:
// Get the bus from the pipeline
// Add a signal watch to the bus
gst_bus_add_signal_watch(bus);
// Connect to the "message" signal
g_signal_connect(bus, "message", G_CALLBACK(bus_call), appCtx[0]->pipeline.pipeline);
But I’m getting the following error: GStreamer:ERROR:gstbus.c:1400:gst_bus_add_signal_watch_full: assertion failed: (!bus->priv->signal_watch).
I’m not sure how to proceed from here. How can I call the bus_call method to handle errors and state changes? Any help would be greatly appreciated.
Thank you.
• DeepStream Version
• TensorRT Version
*Hardware Platform: Jetson AGX Orin 64GB Developer Kit
*DeepStream Version: 6.3
*JetPack Version: 5.1.2.
*TensorRT Version: 8.5.2.2.
*Issue Type: cannot connect bus_call method for handling messages
*How to reproduce the issue: I’m using NVDSANALYTICS-TEST-APP from demo and I tried to add call bus_call method as described above
please refer to deepstrea-test1. the third parameter of gst_bus_add_watch is GMainLoop* , not pipeline.
