Hi eveyone,
I’m currently working on building an agent using NVIDIA Jetson AGX Orin in Agent Studio, and I’m encountering issues when adding a video source with VideoSource.
Here’s what happens:
- When I try to use a camera device, the application freezes completely. Logs:
[gstreamer] gstCamera – attempting to create device v4l2:///dev/video0
**Opening in BLOCKING MODE **
Fatal Python error: Segmentation fault
Thread 0x0000fffeacadf120 (most recent call first):
** File “/usr/lib/python3.10/ssl.py”, line 1161 in read**
** File “/usr/lib/python3.10/ssl.py”, line 1288 in recv**
** File “/usr/local/lib/python3.10/dist-packages/websockets/sync/connection.py”, line 561 in recv_events**
** File “/usr/local/lib/python3.10/dist-packages/websockets/sync/server.py”, line 196 in recv_events**
** File “/usr/lib/python3.10/threading.py”, line 953 in run**
** File “/usr/lib/python3.10/threading.py”, line 1016 in _bootstrap_inner**
** File “/usr/lib/python3.10/threading.py”, line 973 in _bootstrap**
Current thread 0x0000fffead2ef120 (most recent call first):
** File “/opt/NanoLLM/nano_llm/plugins/video/video_source.py”, line 67 in init**
** File “/opt/NanoLLM/nano_llm/plugins/dynamic_plugin.py”, line 35 in new**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 65 in add_plugin**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 58 in add_plugin**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 414 in invoke_handler**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 432 in on_message**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 442 in on_websocket**
** File “/opt/NanoLLM/nano_llm/web/server.py”, line 193 in on_message**
** File “/opt/NanoLLM/nano_llm/web/server.py”, line 393 in websocket_listener**
** File “/opt/NanoLLM/nano_llm/web/server.py”, line 314 in on_websocket**
** File “/usr/local/lib/python3.10/dist-packages/websockets/sync/server.py”, line 575 in conn_handler**
Thread 0x0000fffeae30f120 (most recent call first):
** File “/usr/lib/python3.10/selectors.py”, line 416 in select**
** File “/usr/lib/python3.10/socketserver.py”, line 232 in serve_forever**
** File “/usr/local/lib/python3.10/dist-packages/werkzeug/serving.py”, line 817 in serve_forever**
** File “/usr/local/lib/python3.10/dist-packages/werkzeug/serving.py”, line 1123 in run_simple**
** File “/usr/local/lib/python3.10/dist-packages/flask/app.py”, line 625 in run**
** File “/opt/NanoLLM/nano_llm/web/server.py”, line 120 in **
Thread 0x0000fffeaeb1f120 (most recent call first):
** File “/usr/lib/python3.10/selectors.py”, line 469 in select**
** File “/usr/local/lib/python3.10/dist-packages/websockets/sync/server.py”, line 260 in serve_forever**
** File “/opt/NanoLLM/nano_llm/web/server.py”, line 119 in **
Thread 0x0000fffeaf32f120 (most recent call first):
** File “/usr/local/lib/python3.10/dist-packages/psutil/init.py”, line 1805 in cpu_percent**
** File “/opt/NanoLLM/nano_llm/plugins/tegrastats.py”, line 58 in read**
** File “/opt/NanoLLM/nano_llm/plugins/tegrastats.py”, line 96 in run**
Thread 0x0000ffff9855c6c0 (most recent call first):
** File “/usr/lib/python3.10/threading.py”, line 1116 in _wait_for_tstate_lock**
** File “/usr/lib/python3.10/threading.py”, line 1096 in join**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 495 in run**
** File “/opt/NanoLLM/nano_llm/studio.py”, line 17 in **
** File “/usr/lib/python3.10/runpy.py”, line 86 in _run_code**
** File “/usr/lib/python3.10/runpy.py”, line 196 in _run_module_as_main**
Extension modules: numpy.core._multiarray_umath, numpy.core._multiarray_tests, numpy.linalg._umath_linalg, numpy.fft._pocketfft_internal, numpy.random._common, numpy.random.bit_generator, numpy.random._bounded_integers, numpy.random._mt19937, numpy.random.mtrand, numpy.random._philox, numpy.random._pcg64, numpy.random._sfc64, numpy.random._generator, torch._C, torch._C._fft, torch._C._linalg, torch._C._nested, torch._C._nn, torch._C._sparse, torch._C._special, zstandard.backend_c, charset_normalizer.md, yaml._yaml, sentencepiece._sentencepiece, psutil._psutil_linux, psutil._psutil_posix, PIL._imaging, PIL._imagingft, google.protobuf.pyext._message, jetson_utils_python, cuda._lib.utils, cuda._cuda.ccuda, cuda.ccuda, cuda.cuda, cuda._cuda.cnvrtc, cuda.cnvrtc, cuda.nvrtc, cuda._lib.ccudart.utils, cuda._lib.ccudart.ccudart, cuda.ccudart, cuda.cudart, _cffi_backend, pyaudio._portaudio, markupsafe._speedups, websockets.speedups, regex._regex, scipy._lib._ccallback_c, numba.core.typeconv._typeconv, numba._helperlib, numba._dynfunc, numba._dispatcher, numba.core.runtime._nrt_python, numba.np.ufunc._internal, numba.experimental.jitclass._box, h5py._errors, h5py.defs, h5py._objects, h5py.h5, h5py.utils, h5py.h5t, h5py.h5s, h5py.h5ac, h5py.h5p, h5py.h5r, h5py._proxy, h5py._conv, h5py.h5z, h5py.h5a, h5py.h5d, h5py.h5ds, h5py.h5g, h5py.h5i, h5py.h5f, h5py.h5fd, h5py.h5pl, h5py.h5o, h5py.h5l, h5py._selector, grpc._cython.cygrpc (total: 79)
- If I use an RTSP stream or an MP4 file the adition of the source fails, but the program doesn’t crash. Logs:
**(gst-plugin-scanner:71): GStreamer-CRITICAL : 11:56:54.868: gst_element_register: assertion ‘g_type_is_a (type, GST_TYPE_ELEMENT)’ failed
sh: 1: lsmod: not found
sh: 1: modprobe: not found
[gstreamer] initialized gstreamer, version 1.20.3.0
[gstreamer] gstDecoder – creating decoder for /data/JETSON AI LAB _ Agent Studio - Multimodal VLM Function-calling LLM.mp4
**NvMMLiteOpen : Block : BlockType = 261 **
**NvMMLiteBlockCreate : Block : BlockType = 261 **
**(python3:1): GStreamer-CRITICAL : 11:56:56.149: gst_debug_log_valist: assertion ‘category != NULL’ failed
[gstreamer] gstDecoder – discovered video resolution: 640x360 (framerate 30.000000 Hz)
[gstreamer] gstDecoder – discovered video caps: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3, profile=(string)main, width=(int)640, height=(int)360, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, colorimetry=(string)bt709, parsed=(boolean)true
[gstreamer] gstDecoder – pipeline string:
[gstreamer] filesrc location=/data/JETSON AI LAB _ Agent Studio - Multimodal VLM Function-calling LLM.mp4 ! qtdemux ! queue ! h264parse ! nvv4l2decoder name=decoder enable-max-performance=1 ! nvvidconv name=vidconv ! video/x-raw, width=(int)640, height=(int)480, format=(string)NV12 ! appsink name=mysink
[gstreamer] gstDecoder – failed to create pipeline
[gstreamer] (no element “AI”)
[gstreamer] failed to create decoder pipeline
[gstreamer] gstDecoder – failed to create decoder for file:///data/JETSON AI LAB _ Agent Studio - Multimodal VLM Function-calling LLM.mp4
11:56:56 | ERROR | Exception occurred handling websocket message:
{ ‘add_plugin’: { ‘layout_node’: {‘x’: 10, ‘y’: 10},
** ‘name’: ‘VideoSource’,**
** ‘return_copy’: ‘true’,**
** ‘return_tensors’: ‘cuda’,**
** ‘type’: ‘VideoSource’,**
** ‘video_input’: '/data/JETSON AI LAB _ Agent Studio - '**
** ‘Multimodal VLM Function-calling LLM.mp4’,**
** ‘video_input_height’: 480,**
** ‘video_input_width’: 640}}**
** File “/opt/NanoLLM/nano_llm/web/server.py”, line 193, in on_message**
** callback(payload, payload_size=payload_size, msg_type=msg_type, msg_id=msg_id,**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 442, in on_websocket**
** on_message(self, message)**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 432, in on_message**
** if invoke_handler(obj, key, msg):**
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 414, in invoke_handler**
** response = func(msg)
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 58, in add_plugin**
** threading.Thread(target=self.add_plugin, kwargs={‘type’: type, ‘wait’: True, ‘state_dict’: state_dict, ‘layout_node’: layout_node, kwargs}).run()
** File “/usr/lib/python3.10/threading.py”, line 953, in run**
** self._target(self._args, self._kwargs)
** File “/opt/NanoLLM/nano_llm/agents/dynamic_agent.py”, line 65, in add_plugin*
** plugin = DynamicPlugin(type, init_kwargs)
** File “/opt/NanoLLM/nano_llm/plugins/dynamic_plugin.py”, line 35, in new**
** instance = plugin(args, kwargs)
** File “/opt/NanoLLM/nano_llm/plugins/video/video_source.py”, line 67, in init*
** self.stream = videoSource(video_input, options=options)**
Exception: jetson.utils – failed to create videoSource device
Has anyone faced similar issues? If so, do you have any insights or suggestions on resolving this?
Thank you in advance for your help!
