hello guys.
im using jetpack 4.5.1 and cloned the jetbot repo.
when i type the docker run command: ```
sudo docker run -it -d --restart always --runtime nvidia --network host --privileged --device /dev/video* --volume /dev/bus/usb:/dev/bus/usb --volume /tmp/argus_socket:/tmp/argus_socket --privileged --name=jetbot_camera jetbot/jetbot:camera-0.4.3-32.5.0
it creates the container just fine without issue, but the container keeps restarting over and over again
and if just type the command:
docker run -ti jetbot/jetbot:camera-0.4.3-32.5.0
i have tons of errors:
nvbuf_utils: Could not get EGL display connection0
nvarguscamerasrc sensor-mode=0 ! video/x-raw(memory:NVMM), width=816, height=616, format=(string)NV12, framerate=(fraction)21/1 ! nvvidconv ! video/x-raw, width=(int)224, height=(int)224, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink name=sink
starting camera
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 201)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 102)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:639 Failed to create CameraProvider
(python3:6): GStreamer-CRITICAL **: 20:54:34.689: gst_mini_object_set_qdata: assertion 'object != NULL' failed
iĀ“ve tried with jetpack 4.6, 4.5.1, jetbot 4.4, 4.3 and the same result
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
bd14a3aad52f jetbot/jetbot:camera-0.4.2-32.4.4 "/bin/sh -c 'cd ${JEā¦" 14 seconds ago Restarting (0) 1 second ago jetbot_camera
56ab2923e573 jetbot/jetbot:jupyter-0.4.2-32.4.4 "/bin/sh -c 'cd $JUPā¦" 9 months ago Up 9 minutes jetbot_jupyter
daae838838e3 jetbot/jetbot:display-0.4.2-32.4.4 "/bin/sh -c 'python3ā¦" 9 months ago Up 9 minutes jetbot_display
thanks in advance
