you can use cuda_safe_call (if you don’t mind using cutil), or you can manually get and check the return values from the calls. They return a type cudaError_t, which you can then check to see if the function call succeeded or failed (and if it failed, what the error message was). A word of caution, beware of the asynchronous calls’ errors, as they can be misleading at times.
these are the possible values for cudaError_t (found in the driver_types.h file)
* CUDA error types
/*DEVICE_BUILTIN*/
enum cudaError
* The API call returned with no errors. In the case of query calls, this
* can also mean that the operation being queried is complete (see
* ::cudaEventQuery() and ::cudaStreamQuery()).
cudaSuccess = 0,
* The device function being invoked (usually via ::cudaLaunch()) was not
* previously configured via the ::cudaConfigureCall() function.
cudaErrorMissingConfiguration = 1,
* The API call failed because it was unable to allocate enough memory to
* perform the requested operation.
cudaErrorMemoryAllocation = 2,
* The API call failed because the CUDA driver and runtime could not be
* initialized.
cudaErrorInitializationError = 3,
* An exception occurred on the device while executing a kernel. Common
* causes include dereferencing an invalid device pointer and accessing
* out of bounds shared memory. The device cannot be used until
* ::cudaThreadExit() is called. All existing device memory allocations
* are invalid and must be reconstructed if the program is to continue
* using CUDA.
cudaErrorLaunchFailure = 4,
* This indicated that a previous kernel launch failed. This was previously
* used for device emulation of kernel launches.
* \deprecated
* This error return is deprecated as of CUDA 3.1. Device emulation mode was
* removed with the CUDA 3.1 release.
cudaErrorPriorLaunchFailure = 5,
* This indicates that the device kernel took too long to execute. This can
* only occur if timeouts are enabled - see the device property
* \ref ::cudaDeviceProp::kernelExecTimeoutEnabled "kernelExecTimeoutEnabled"
* for more information. The device cannot be used until ::cudaThreadExit()
* is called. All existing device memory allocations are invalid and must be
* reconstructed if the program is to continue using CUDA.
cudaErrorLaunchTimeout = 6,
* This indicates that a launch did not occur because it did not have
* appropriate resources. Although this error is similar to
* ::cudaErrorInvalidConfiguration, this error usually indicates that the
* user has attempted to pass too many arguments to the device kernel, or the
* kernel launch specifies too many threads for the kernel's register count.
cudaErrorLaunchOutOfResources = 7,
* The requested device function does not exist or is not compiled for the
* proper device architecture.
cudaErrorInvalidDeviceFunction = 8,
* This indicates that a kernel launch is requesting resources that can
* never be satisfied by the current device. Requesting more shared memory
* per block than the device supports will trigger this error, as will
* requesting too many threads or blocks. See ::cudaDeviceProp for more
* device limitations.
cudaErrorInvalidConfiguration = 9,
* This indicates that the device ordinal supplied by the user does not
* correspond to a valid CUDA device.
cudaErrorInvalidDevice = 10,
* This indicates that one or more of the parameters passed to the API call
* is not within an acceptable range of values.
cudaErrorInvalidValue = 11,
* This indicates that one or more of the pitch-related parameters passed
* to the API call is not within the acceptable range for pitch.
cudaErrorInvalidPitchValue = 12,
* This indicates that the symbol name/identifier passed to the API call
* is not a valid name or identifier.
cudaErrorInvalidSymbol = 13,
* This indicates that the buffer object could not be mapped.
cudaErrorMapBufferObjectFailed = 14,
* This indicates that the buffer object could not be unmapped.
cudaErrorUnmapBufferObjectFailed = 15,
* This indicates that at least one host pointer passed to the API call is
* not a valid host pointer.
cudaErrorInvalidHostPointer = 16,
* This indicates that at least one device pointer passed to the API call is
* not a valid device pointer.
cudaErrorInvalidDevicePointer = 17,
* This indicates that the texture passed to the API call is not a valid
* texture.
cudaErrorInvalidTexture = 18,
* This indicates that the texture binding is not valid. This occurs if you
* call ::cudaGetTextureAlignmentOffset() with an unbound texture.
cudaErrorInvalidTextureBinding = 19,
* This indicates that the channel descriptor passed to the API call is not
* valid. This occurs if the format is not one of the formats specified by
* ::cudaChannelFormatKind, or if one of the dimensions is invalid.
cudaErrorInvalidChannelDescriptor = 20,
* This indicates that the direction of the memcpy passed to the API call is
* not one of the types specified by ::cudaMemcpyKind.
cudaErrorInvalidMemcpyDirection = 21,
* This indicated that the user has taken the address of a constant variable,
* which was forbidden up until the CUDA 3.1 release.
* \deprecated
* This error return is deprecated as of CUDA 3.1. Variables in constant
* memory may now have their address taken by the runtime via
* ::cudaGetSymbolAddress().
cudaErrorAddressOfConstant = 22,
* This indicated that a texture fetch was not able to be performed.
* This was previously used for device emulation of texture operations.
* \deprecated
cudaErrorTextureFetchFailed = 23,
* This indicated that a texture was not bound for access.
* \deprecated
cudaErrorTextureNotBound = 24,
* This indicated that a synchronization operation had failed.
* This was previously used for some device emulation functions.
* \deprecated
cudaErrorSynchronizationError = 25,
* This indicates that a non-float texture was being accessed with linear
* filtering. This is not supported by CUDA.
cudaErrorInvalidFilterSetting = 26,
* This indicates that an attempt was made to read a non-float texture as a
* normalized float. This is not supported by CUDA.
cudaErrorInvalidNormSetting = 27,
* Mixing of device and device emulation code was not allowed.
* \deprecated
cudaErrorMixedDeviceExecution = 28,
* This indicated an issue with calling API functions during the unload
* process of the CUDA runtime in prior releases.
* \deprecated
* This error return is deprecated as of CUDA 3.2.
cudaErrorCudartUnloading = 29,
* This indicates that an unknown internal error has occurred.
cudaErrorUnknown = 30,
* This indicates that the API call is not yet implemented. Production
* releases of CUDA will never return this error.
cudaErrorNotYetImplemented = 31,
* This indicated that an emulated device pointer exceeded the 32-bit address
* range.
* \deprecated
cudaErrorMemoryValueTooLarge = 32,
* This indicates that a resource handle passed to the API call was not
* valid. Resource handles are opaque types like ::cudaStream_t and
* ::cudaEvent_t.
cudaErrorInvalidResourceHandle = 33,
* This indicates that asynchronous operations issued previously have not
* completed yet. This result is not actually an error, but must be indicated
* differently than ::cudaSuccess (which indicates completion). Calls that
* may return this value include ::cudaEventQuery() and ::cudaStreamQuery().
cudaErrorNotReady = 34,
* This indicates that the installed NVIDIA CUDA driver is older than the
* CUDA runtime library. This is not a supported configuration. Users should
* install an updated NVIDIA display driver to allow the application to run.
cudaErrorInsufficientDriver = 35,
* This indicates that the user has called ::cudaSetDevice(),
* ::cudaSetValidDevices(), ::cudaSetDeviceFlags(),
* ::cudaD3D9SetDirect3DDevice(), ::cudaD3D10SetDirect3DDevice,
* ::cudaD3D11SetDirect3DDevice(), * or ::cudaVDPAUSetVDPAUDevice() after
* initializing the CUDA runtime by calling non-device management operations
* (allocating memory and launching kernels are examples of non-device
* management operations). This error can also be returned if using
* runtime/driver interoperability and there is an existing ::CUcontext
* active on the host thread.
cudaErrorSetOnActiveProcess = 36,
* This indicates that the surface passed to the API call is not a valid
* surface.
cudaErrorInvalidSurface = 37,
* This indicates that no CUDA-capable devices were detected by the installed
* CUDA driver.
cudaErrorNoDevice = 38,
* This indicates that an uncorrectable ECC error was detected during
* execution.
cudaErrorECCUncorrectable = 39,
* This indicates that a link to a shared object failed to resolve.
cudaErrorSharedObjectSymbolNotFound = 40,
* This indicates that initialization of a shared object failed.
cudaErrorSharedObjectInitFailed = 41,
* This indicates that the ::cudaLimit passed to the API call is not
* supported by the active device.
cudaErrorUnsupportedLimit = 42,
* This indicates that multiple global or constant variables (across separate
* CUDA source files in the application) share the same string name.
cudaErrorDuplicateVariableName = 43,
* This indicates that multiple textures (across separate CUDA source
* files in the application) share the same string name.
cudaErrorDuplicateTextureName = 44,
* This indicates that multiple surfaces (across separate CUDA source
cudaErrorDuplicateSurfaceName = 45,
* This indicates that all CUDA devices are busy or unavailable at the current
* time. Devices are often busy/unavailable due to use of
* ::cudaComputeModeExclusive, ::cudaComputeModeProhibited or when long
* running CUDA kernels have filled up the GPU and are blocking new work
* from starting. They can also be unavailable due to memory constraints
* on a device that already has active CUDA work being performed.
cudaErrorDevicesUnavailable = 46,
* This indicates that the device kernel image is invalid.
cudaErrorInvalidKernelImage = 47,
* This indicates that there is no kernel image available that is suitable
* for the device. This can occur when a user specifies code generation
* options for a particular CUDA source file that do not include the
* corresponding device configuration.
cudaErrorNoKernelImageForDevice = 48,
* This indicates that the current context is not compatible with this
* the CUDA Runtime. This can only occur if you are using CUDA
* Runtime/Driver interoperability and have created an existing Driver
* context using the driver API. The Driver context may be incompatible
* either because the Driver context was created using an older version
* of the API, because the Runtime API call expects a primary driver
* contextand the Driver context is not primary, or because the Driver
* context has been destroyed. Please see \ref CUDART_DRIVER "Interactions
* with the CUDA Driver API" for more information.
cudaErrorIncompatibleDriverContext = 49,
* This error indicates that a call to ::cudaDeviceEnablePeerAccess() is
* trying to re-enable peer addressing on from a context which has already
* had peer addressing enabled.
cudaErrorPeerAccessAlreadyEnabled = 50,
* This error indicates that ::cudaDeviceDisablePeerAccess() is trying to
* disable peer addressing which has not been enabled yet via
* ::cudaDeviceEnablePeerAccess().
cudaErrorPeerAccessNotEnabled = 51,
* This indicates that a call tried to access an exclusive-thread device that
* is already in use by a different thread.
cudaErrorDeviceAlreadyInUse = 54,
* This indicates profiler has been disabled for this run and thus runtime
* APIs cannot be used to profile subsets of the program. This can
* happen when the application is running with external profiling tools
* like visual profiler.
cudaErrorProfilerDisabled = 55,
* This indicates profiler has not been initialized yet. cudaProfilerInitialize()
* must be called before calling cudaProfilerStart and cudaProfilerStop to
* initialize profiler.
cudaErrorProfilerNotInitialized = 56,
* This indicates profiler is already started. This error can be returned if
* cudaProfilerStart() is called multiple times without subsequent call
* to cudaProfilerStop().
cudaErrorProfilerAlreadyStarted = 57,
* This indicates profiler is already stopped. This error can be returned if
* cudaProfilerStop() is called without starting profiler using cudaProfilerStart().
cudaErrorProfilerAlreadyStopped = 58,
* This indicates an internal startup failure in the CUDA runtime.
cudaErrorStartupFailure = 0x7f,
* Any unhandled CUDA driver error is added to this value and returned via
* the runtime. Production releases of CUDA should not return such errors.
cudaErrorApiFailureBase = 10000
* CUDA Error types
/*DEVICE_BUILTIN*/
typedef enum cudaError cudaError_t;
