Issue with Custom Sequence Preprocess library in combination with SGIE
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0 (docker image: nvcr.io/nvidia/deepstream:7.0-triton-multiarch )
• NVIDIA GPU Driver Version (valid for GPU only) 535.171.04
I’ve been working on modifying the deepstream-3d-action-recognition sample application located at /opt/nvidia/deepstream/deepstream/apps/sample_apps/deepstream-3d-action-recognition/. My goal was to integrate the 3D ActionRecognitionNet model as a Secondary GIE (SGIE) within the pipeline.
To achieve this, I made the following modifications:
  1. Pipeline Modification: I modified the pipeline by adding a primary inference detector and a tracker before the action recognition model. You can view the updated pipeline graph here:
    deepstream-3d-action-recognition_graph.zip (7.6 KB)
  2. Code Changes: I modified the the main function in the deepstream_3d_action_recognition.cpp file to incorporate the primary inference detector and the tracker. You can view the updated main function here:
int main(int argc, char *argv[])
  g_setenv("GST_DEBUG_DUMP_DOT_DIR", "/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-3d-action-recognition", TRUE);
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
             *preprocess = NULL, *queue1 = NULL, *queue2 = NULL,
             *queue3 = NULL, *queue4 = NULL, *queue5 = NULL, *queue6 = NULL,
             *nvvidconv = NULL, *nvosd = NULL, *tiler = NULL;
  GstElement *queue_detector=NULL, *pgie_detector = NULL, *tracker = NULL;
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *pgie_src_pad = NULL;
  guint i, num_sources;
  guint tiler_rows, tiler_columns;
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  /* Standard GStreamer initialization */
  gst_init(&argc, &argv);
    /* setup signal handler */
  _intr_setup();
    /* Check input arguments */
  if (argc < 3 || strncmp(argv[1], "-c", 3))
    g_printerr("Usage: %s -c <action_recognition_config.txt>\n", argv[0]);
    return -1;
  if (!parse_action_config(argv[2], gActionConfig)) {
    g_printerr("parse config file: %s failed.\n", argv[2]);
    return -1;
  if (gActionConfig.debug >= kDebugVerbose) {
    setenv(ENV_CUSTOM_SEQUENC_DEBUG, "1", 1);
  } else {
    unsetenv(ENV_CUSTOM_SEQUENC_DEBUG);
  num_sources = gActionConfig.uri_list.size();
  loop = g_main_loop_new(NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new("preprocess-test-pipeline");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux)
    g_printerr("One element could not be created. Exiting.\n");
    return -1;
  gst_bin_add(GST_BIN(pipeline), streammux);
  for (i = 0; i < num_sources; i++)
    GstPad *sinkpad, *srcpad;
    gchar pad_name[16] = {};
    GstElement *source_bin = create_source_bin(i, gActionConfig.uri_list[i].c_str());
    if (!source_bin)
      g_printerr("Failed to create source bin. Exiting.\n");
      return -1;
    gst_bin_add(GST_BIN(pipeline), source_bin);
    g_snprintf(pad_name, 15, "sink_%u", i);
    sinkpad = gst_element_request_pad_simple(streammux, pad_name);
    if (!sinkpad)
      g_printerr("Streammux request sink pad failed. Exiting.\n");
      return -1;
    srcpad = gst_element_get_static_pad(source_bin, "src");
    if (!srcpad)
      g_printerr("Failed to get src pad of source bin. Exiting.\n");
      return -1;
    if (gst_pad_link(srcpad, sinkpad) != GST_PAD_LINK_OK)
      g_printerr("Failed to link source bin to stream muxer. Exiting.\n");
      return -1;
    gst_object_unref(srcpad);
    gst_object_unref(sinkpad);
  queue_detector = gst_element_factory_make("queue", "queue-detector");
  pgie_detector = gst_element_factory_make("nvinfer", "primary-detector");
  tracker = gst_element_factory_make ("nvtracker", "tracker");
  if (!pgie_detector || !tracker)
    return -1;
  g_object_set(G_OBJECT(pgie_detector),
    "config-file-path", "dstest1_pgie_config.yml",
    NULL);
  g_object_set(G_OBJECT(tracker),
    "ll-config-file", "/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml",
    "ll-lib-file", "/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so",
    NULL);
  /* to preprocess the rois and form a raw tensor for inferencing */
  preprocess = gst_element_factory_make("nvdspreprocess", "preprocess-plugin");
  /* Create inference plugin to inference batched frames. */
  if (!gActionConfig.triton_infer_config.empty()) {
    pgie = gst_element_factory_make("nvinferserver", "primary-triton-nvinference");
  } else {
    pgie = gst_element_factory_make("nvinfer", "primary-nvinference-engine");
  /* Add queue elements between every two elements */
  queue1 = gst_element_factory_make("queue", "queue1");
  queue2 = gst_element_factory_make("queue", "queue2");
  queue3 = gst_element_factory_make("queue", "queue3");
  if (!preprocess || !pgie || !queue1 || !queue2 || !queue3)
    return -1;
  if (gActionConfig.useFakeSink) {
    sink = gst_element_factory_make("fakesink", "nvvideo-sink");
    if (!sink)
      g_printerr("element fakesink could not be created. Exiting.\n");
      return -1;
  } else {
    queue4 = gst_element_factory_make("queue", "queue4");
    queue5 = gst_element_factory_make("queue", "queue5");
    queue6 = gst_element_factory_make("queue", "queue6");
    /* Use nvtiler to composite the batched frames into a 2D tiled array based
    * on the source of the frames. */
    tiler = gst_element_factory_make("nvmultistreamtiler", "nvtiler");
    /* Use convertor to convert from NV12 to RGBA as required by nvosd */
    nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
    /* Create OSD to draw on the converted RGBA buffer */
    nvosd = gst_element_factory_make("nvdsosd", "nv-onscreendisplay");
    /* Finally render the osd output */
    if (prop.integrated)
      sink = gst_element_factory_make("nv3dsink", "nv3d-sink");
    } else {
#ifdef __aarch64__
      sink = gst_element_factory_make ("nv3dsink", "nvvideo-renderer");
#else
      sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
#endif
    if (!tiler || !nvvidconv || !nvosd || !sink)
      return -1;
    tiler_rows = (guint)sqrt(num_sources);
    tiler_columns = (guint)ceil(1.0 * num_sources / tiler_rows);
    /* we set the tiler properties here */
    g_object_set(G_OBJECT(tiler), "rows", tiler_rows, "columns", tiler_columns,
                "width", gActionConfig.tiler_width, "height", gActionConfig.tiler_height, NULL);
    g_object_set(G_OBJECT(nvosd), "process-mode", OSD_PROCESS_MODE,
                "display-text", OSD_DISPLAY_TEXT, NULL);
  g_object_set(G_OBJECT(streammux), "batch-size", num_sources, NULL);
  g_object_set(G_OBJECT(streammux), "width", gActionConfig.muxer_width, "height",
               gActionConfig.muxer_height,
               "batched-push-timeout", gActionConfig.muxer_batch_timeout, NULL);
  g_object_set(G_OBJECT(preprocess), "config-file", gActionConfig.preprocess_config.c_str(), NULL);
  /* Configure the nvinfer element using the nvinfer config file. */
  g_object_set(G_OBJECT(pgie), "input-tensor-meta", TRUE,
               "config-file-path",
               (!gActionConfig.triton_infer_config.empty() ?
                 gActionConfig.triton_infer_config.c_str() :
                 gActionConfig.infer_config.c_str()), NULL);
  g_print("num-sources = %d\n", num_sources);
  g_object_set(G_OBJECT(sink), "qos", 0, "sync", gActionConfig.display_sync, NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
  bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
  gst_object_unref(bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
    gst_bin_add_many(GST_BIN(pipeline), queue_detector, pgie_detector, tracker,
                     queue1, preprocess, queue2, pgie, queue3, sink, NULL);
    /* we link the elements together
    * nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
    if (!gst_element_link_many(streammux, queue_detector, pgie_detector, tracker,
                               queue1, preprocess, queue2, pgie, queue3, sink, NULL))
      g_printerr("Elements could not be linked. Exiting.\n");
      return -1;
  else
                     queue1, preprocess, queue2, pgie, queue3, tiler,
                     queue4, nvvidconv, queue5, nvosd, queue6, sink, NULL);
                               queue4, nvvidconv, queue5, nvosd, queue6, sink, NULL))
      return -1;
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  pgie_src_pad = gst_element_get_static_pad(pgie, "src");
  if (!pgie_src_pad)
    g_print("Unable to get pgie src pad\n");
  else
    gst_pad_add_probe(pgie_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
                      pgie_src_pad_buffer_probe, NULL, NULL);
  gst_object_unref(pgie_src_pad);
  /* Set the pipeline to "playing" state */
  g_print("Now playing:");
    g_print(" %s,", gActionConfig.uri_list[i].c_str());
  g_print("\n");
  GST_DEBUG_BIN_TO_DOT_FILE(GST_BIN(pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "pipeline");
  gst_element_set_state(pipeline, GST_STATE_PLAYING);
  gPipeline = pipeline;
  /* Wait till pipeline encounters an error or EOS */
  g_print("Running...\n");
  g_main_loop_run(loop);
  gPipeline = nullptr;
  /* Out of the main loop, clean up nicely */
  g_print("Returned, stopping playback\n");
  gst_element_set_state(pipeline, GST_STATE_NULL);
  g_print("Deleting pipeline\n");
  gst_object_unref(GST_OBJECT(pipeline));
  g_source_remove(bus_watch_id);
  g_main_loop_unref(loop);
  return 0;
  1. Primary Detector Configuration: For the primary detector, I used the configuration file dstest1_config.yml from /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1. The only change I made was setting the gie-unique-id to 2.
  2. Preprocessing Configuration: I adjusted the config_preprocess_3d_custom.txt file to perform preprocessing on object ROIs instead of entire frames. Here’s the modified configuration:
[property]
enable=1
target-unique-ids=1
    # 0=process on objects 1=process on frames
process-on-frame=0
    # network-input-shape: batch, channel, sequence, height, width
# 3D sequence of 32 images
network-input-shape= 1;3;32;224;224
    # 0=RGB, 1=BGR, 2=GRAY
network-color-format=0
    # 0=NCHW, 1=NHWC, 2=CUSTOM
network-input-order=2
    # 0=FP32, 1=UINT8, 2=INT8, 3=UINT32, 4=INT32, 5=FP16
tensor-data-type=0
tensor-name=input_rgb
processing-width=224
processing-height=224
    # 0=NVBUF_MEM_DEFAULT 1=NVBUF_MEM_CUDA_PINNED 2=NVBUF_MEM_CUDA_DEVICE
    # 3=NVBUF_MEM_CUDA_UNIFIED  4=NVBUF_MEM_SURFACE_ARRAY(Jetson)
scaling-pool-memory-type=0
    # 0=NvBufSurfTransformCompute_Default 1=NvBufSurfTransformCompute_GPU
    # 2=NvBufSurfTransformCompute_VIC(Jetson)
scaling-pool-compute-hw=0
    # Scaling Interpolation method
    # 0=NvBufSurfTransformInter_Nearest 1=NvBufSurfTransformInter_Bilinear 2=NvBufSurfTransformInter_Algo1
    # 3=NvBufSurfTransformInter_Algo2 4=NvBufSurfTransformInter_Algo3 5=NvBufSurfTransformInter_Algo4
    # 6=NvBufSurfTransformInter_Default
scaling-filter=0
    # model input tensor pool size
tensor-buf-pool-size=8
custom-lib-path=/opt/nvidia/deepstream/deepstream/lib/libnvds_custom_sequence_preprocess.so
custom-tensor-preparation-function=CustomSequenceTensorPreparation
# 3D conv custom params
[user-configs]
channel-scale-factors=0.007843137;0.007843137;0.007843137
channel-mean-offsets=127.5;127.5;127.5
stride=1
subsample=0
[group-0]
src-ids=0
process-on-roi=0
#process only person
operate-on-class-ids=2
process-on-all-objects=1
  1. Input Source: I used a single input source and set the debug level to verbose in deepstream_action_recognition_config.txt:
# stream/file source list
uri-list=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_walk.mov
# Log debug level. 0: disabled. 1: debug. 2: verbose.
debug=2
  1. Batch Size: I also set the batch size to 1 in the config_infer_primary_3d_action.txt file.
Issue Encountered:
After running the application, it freezes after processing just a few frames.
To diagnose the problem, I compiled and ran the code in debug mode and discovered that the issue lies within the custom_sequence_preprocess library. Specifically, the process hangs after a few iterations of the BufferManager::addRoi function in the sequence_image_process.cpp file, particularly at line 158 during the call to newBlock->buf = _allocator->acquire();.
Could anyone provide insights or suggestions on how to resolve this issue?
Thanks in advance.
Could you try to debug it further within the preprocess source code?
sources\gst-plugins\gst-nvdspreprocess
NvDsPreProcessCustomBuf* NvDsPreProcessAcquirerImpl::acquire()
Or you can use gdb tool first to check where it’s frozen.
thanks for your help.
The freeze occurs during the call to the following GStreamer function:
  flow_ret =
      gst_buffer_pool_acquire_buffer (m_gstpool, &gstbuf,
      nullptr);
at line 2211 of the file:
sources\gst-plugins\gst-nvdspreprocess\gstnvdspreprocess.cpp
Could you try to set the operate-on-gie-id=2 in the preprocess config file?
We can try to narrow down this issue by using the fakesink plugin. Could you also try the 3 pipelines below?
  1. …pgie->tracker->preprocess->sgie->fakesink
  2. …pgie->tracker->preprocess->fakesink
  3. …pgie->tracker->faksink
I set operate-on-gie-id=2 in the preprocess config file as you suggested.
I tested the three different pipelines using the fakesink plugin.
Pipelines 1 and 2 still exhibit the same freeze issue.
Pipeline 3 works without any problems.
Would you be able to try reproducing the modifications I made to deepstream-3d-action-recognition to integrate the 3D ActionRecognitionNet model as SGIE?
Thanks for your assistance.
Yes. You can get the modifications that I used below. It worked normally on my side.
deepstream_action_recognition_config.txt (2.0 KB)
deepstream_3d_action_recognition.cpp (22.9 KB)
dstest1_pgie_config.txt (2.8 KB)
Thanks for sharing your code and configuration.
However, it looks like the configuration files for the sequence preprocessing (the modified config_preprocess_3d_custom.txt) and the 3D ActionRecognitionNet model’s nvinfer configuration (the modified config_infer_primary_3d_action.txt) are missing.
These files are crucial for enabling the model to function as a secondary inference engine, performing inference on sequences of cropped object regions.
Could you please provide these files as well?
It would greatly help in understanding how to properly set up the model for this specific use case.
I just posted the files that I had changed, and the others were unchanged. You can get that from our demo sources\apps\sample_apps\deepstream-3d-action-recognition.
I understand your point, but without modifying the config_preprocess_3d_custom.txt and config_infer_primary_3d_action.txt files, you aren’t utilizing the 3D ActionRecognitionNet model as a Secondary GIE (SGIE).
By default, these configuration files—when unchanged from their original versions in sources\apps\sample_apps\deepstream-3d-action-recognition—are set up to create a sequence of full frames in the preprocessing plugin. As a result, the 3D ActionRecognitionNet model performs inference on this sequence of full frames, effectively operating as Primary GIE (PGIE).
As I mentioned earlier, I adjusted the config_preprocess_3d_custom.txt file to modify the preprocessing behavior. Specifically, I configured it to generate a sequence of object ROIs (Regions of Interest) instead of entire frames. The goal here is to create sequences based on object bounding boxes. This way, the 3D ActionRecognitionNet can operate as an SGIE, performing inference on a sequence of object ROIs rather than on the whole frames.
The key parameters that need to be changed are:
and:
In summary, modifying both the config_preprocess_3d_custom.txt and config_infer_primary_3d_action.txt files is crucial. Without these changes, even with the addition of a detector and tracker in the pipeline, the 3D ActionRecognitionNet will still act as a PGIE by continuing to perform inference on entire frames.
Could you try implementing these modifications to fully integrate the 3D ActionRecognitionNet model as an SGIE?
Any updates on this? Appreciate any help!
We are trying to reproduce the issue and analyze. We’ll promptly notify you as soon as we reach a conclusion.
Hi @alfonso-corrado , the preprocess of this demo cannot support your scenario. The rootcause of the hang issue is that we cannot collect the buffers with the existing preprocess implementation. Cause the demo is used to support the ROI instead of the object from the PGIE. The _readyPendings below is always 0.
bool
BufferManager::popReady(ReadyResult& res)
    if (!_readyPendings.size()) {
        return false;
You can refer to our another demo which has the similar scenario with yours to implement your own preprocess.
