Hello DaneLLL,
As per your request I am creating this new thread regarding the issue with decoding live interlaced source. Here is the link to the original thread:
After encoding interlaced source using 00_video_decode with our patch that simulates live decoding, we see visual artifacts in the resulting video. See attached picture.
The same code and patch built for r32.2.3 works perfect and does not produce artifacts.
We prepared a patch to 00_video_decode sample that demonstrates the issue - with 40ms live sleep.
Below is the patch and steps on how to reproduce the issue on SDK r32.6.1.
--- a/00_video_decode/video_decode_main.cpp 2021-07-26 22:37:32.000000000 +0300
+++ b/00_video_decode/video_decode_main.cpp 2021-08-24 12:59:14.271718743 +0300
@@ -135,7 +135,7 @@
buffer->planes[0].bytesused = 4;
stream_ptr += 4;
- if (ctx->copy_timestamp)
+ //if (ctx->copy_timestamp)
if (ctx->decoder_pixfmt == V4L2_PIX_FMT_H264) {
if ((IS_H264_NAL_CODED_SLICE(stream_ptr)) ||
@@ -1706,6 +1706,9 @@
v4l2_buf.m.planes[0].bytesused = buffer->planes[0].bytesused;
+ if (ctx.flag_copyts)
+ usleep(40000);
if (ctx.input_nalu && ctx.copy_timestamp && ctx.flag_copyts)
/* Update the timestamp. */
./video_decode H264 --disable-rendering -o out_nv12.raw --input-nalu sample.h264
ffmpeg -y -f rawvideo -pixel_format nv12 -s 1920x1080 -i out_nv12.raw -c:v libx264 -preset fast -crf 28 -g 300 out.ts
sample.h264 from https://github.com/maxlapshin/l4t2-demo/blob/main/video_samples/sample.h264
