I was working in NVIDIA TX1 board.the board came with per-build Linux OS-14.04. now i want to install cuda-toolkit and opencv4Tegra…to my target. i have downloaded jet pack 2.3.1 in host PC (Ubuntu 14.04) and i followed the steps given in the manual(from NVIDIA website)…it has been successfully installed in host machine but while moving the packages from host machine to target machine…the OS has been upgraded to Ubuntu 16.04 and am getting error like…
Get:1 Index of /ubuntu-ports xenial InRelease
Err:1 Index of /ubuntu-ports xenial InRelease
Clearsigned file isn’t valid, got ‘NOSPLIT’ (does the network require authentication?)
Get:2 Index of /ubuntu-ports xenial-updates InRelease
Err:2 Index of /ubuntu-ports xenial-updates InRelease
Get:3 Index of /ubuntu-ports xenial-backports InRelease
Err:3 Index of /ubuntu-ports xenial-backports InRelease
Get:4 Index of /ubuntu-ports xenial-security InRelease
Err:4 Index of /ubuntu-ports xenial-security InRelease
Fetched 780 B in 0s (5,212 B/s)
Reading package lists… Done
W: Target Packages (universe/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:17
W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:17
W: Target Translations (universe/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:17
W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:17
W: Target DEP-11 (universe/dep11/Components-arm64.yml) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:17
W: Target DEP-11-icons (universe/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:17
W: Target Packages (universe/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list:9 and /etc/apt/sources.list:19
W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:9 and /etc/apt/sources.list:19
W: Target Translations (universe/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:9 and /etc/apt/sources.list:19
W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:9 and /etc/apt/sources.list:19
W: Target DEP-11 (universe/dep11/Components-arm64.yml) is configured multiple times in /etc/apt/sources.list:9 and /etc/apt/sources.list:19
W: Target DEP-11-icons (universe/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:9 and /etc/apt/sources.list:19
W: Target Packages (universe/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list:30 and /etc/apt/sources.list:32
W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:30 and /etc/apt/sources.list:32
W: Target Translations (universe/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:30 and /etc/apt/sources.list:32
W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:30 and /etc/apt/sources.list:32
W: Target DEP-11 (universe/dep11/Components-arm64.yml) is configured multiple times in /etc/apt/sources.list:30 and /etc/apt/sources.list:32
W: Target DEP-11-icons (universe/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:30 and /etc/apt/sources.list:32
W: Target Packages (multiverse/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list:30 and /etc/apt/sources.list:34
i have followed the same steps only…i preferred - “custom”
The board came with per-build OS (14.04)…but now it is upgraded to 16.04…and am not able to move the package from host to target…its showing the error…
i don’t know whether it might be due to Internet problem or due OS problem (16.04)
I don’t understand why you need move the package from host to target?
When you install JetPack with custom, you can select the Jetson Developer Kit you would like to develop for to customize the installation components for each device.
I see the issue always mentions file “/etc/apt/sources.list”. If you create a new reply, then hovering the mouse over the quote key of your reply will show a paper clip icon for attaching files. Rename “sources.list” to “sources.list.txt” and attach a copy so that file can be viewed.
I’ll attach one which has most of the commented out entries uncommented and activated. Note that after any change to this file you should run “apt update”. There may be other additions to what repository is checked via some of the files in subdirectories of “/etc/apt/”. sources.list.txt (1.91 KB)
i have installed jet-pack 2.3.1 in host machine… running in Ubuntu 14.04 (64bit)…i have followed the instruction from the manual and i tried the same… Need to install the packages like CUDA-toolkit, CudaDNN, opencv4tegra, visionworks.on NVIDIA TX1. While running jet-pack 2.3.1, all the packages are downloaded. Next a terminal appears which shows, CUDA is copied from host to target but not able to install CUDA on target board(NVIDIA). Jetson TX1 is flashed with Ubuntu 16.04 64 bit. Kernel Version- 3.10.96… Below are the errors we are getting. Also attached the log.
connection to 10.9.68.164 is closed.
dkpg-query: package :cuda-toolkit-8.0 is not installed and no information is available.
error:cuda cannot be installed…
I don’t know where am doing mistake…please help me regarding this…
