Issue with interval setting in primary-gie configuration file (config_infer_primary_yoloV4.txt)
I am using DeepStream 5.0, and I am trying to set the interval parameter inside the config_infer_primary_yoloV4.txt config file to a value greater than 0 so that it will skip some of the frames in between while performing the detection. However, it seems like changing the value of interval (under properties) doesn’t have any impact on the detection and I am getting detection for all the frames.
I am using a video file (.mp4) as the source file. I was able to do this by changing the drop-frame-interval in the deepstream-app config file under source, however, I would like to do this using the gie config as well. Would you please give me sime hints in why this doesn’t work? Since based on the documentation changing the interval has to change the number of infered frames.
• DeepStream Version
• TensorRT Version
