HI Lhuang-- Thank you for reply please se below logs -
Issac sim Error logs
root@ip-172-31-7-67:/workspace/Sim-to-Real-SO-101-Workshop# lerobot_agent --task Lerobot-So101-Teleop-Vials-To-Rack-DR
[INFO][AppLauncher]: Using device: cuda:0
[INFO][AppLauncher]: Loading experience file: /workspace/isaaclab/apps/isaaclab.python.rendering.kit
[Info] [carb] Logging to file: /isaac-sim/kit/logs/Kit/Isaac-Sim/5.1/kit_20260520_220711.log
| Driver Version: 595.58.03 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA L40S | Yes: 0 | | 46068 MB | 10de | 0 |
| | | | | | 26b9 | 8b39e995.. |
| | | | | | 34 | |
| OS: 24.04.2 LTS (Noble Numbat) ubuntu, Version: 24.04.2, Kernel: 6.8.0-1008-aws
| XServer Vendor: The X.Org Foundation, XServer Version: 12101011 (1.21.1.11)
| Processor: AMD EPYC 7R13 Processor
| Cores: 8 | Logical Cores: 16
| Total Memory (MB): 127096 | Free Memory: 123831
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
cat: ‘/sys/devices/system/cpu/cpu*/cpufreq/scaling_governor’: No such file or directory
2026-05-20T22:07:18Z [7,180ms] [Warning] [gpu.foundation.plugin] ECC is enabled on physical device 0
2026-05-20T22:07:18Z [7,182ms] [Warning] [gpu.foundation.plugin] PCIe link width current (8) and maximum (16) for device 0 don’t match.
2026-05-20T22:07:24Z [12,932ms] [Warning] [omni.log] Source: omni.hydra was already registered.
2026-05-20T22:07:28Z [16,916ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [omni::physx::IPhysxBenchmarks v1.0] (plugin: ), by client: omni.physics.physx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
2026-05-20T22:07:29Z [17,564ms] [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
2026-05-20T22:07:36Z [25,457ms] [Warning] [pxr.Semantics] pxr.Semantics is deprecated - please use Semantics instead
2026-05-20T22:07:38Z [27,121ms] [Warning] [omni.graph.core.plugin] Found duplicate of category ‘Replicator’ - was ‘Annotators’, adding ‘Fabric Reader’
2026-05-20T22:07:38Z [27,121ms] [Warning] [omni.graph.core.plugin] Category ‘Replicator’ not accepted on node type ‘omni.replicator.core.FabricReader’ in extension ‘omni.replicator.core’
2026-05-20T22:07:38Z [27,129ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
2026-05-20T22:07:47Z [35,754ms] [Warning] [omni.fabric.plugin] Warning: attribute viewPickingId not found for bucket id 9
2026-05-20T22:07:47Z [35,804ms] [Warning] [omni.kit.window.filepicker.collections.collection_item] Failed to add ‘/root/Documents’: ‘/root/Documents/’ as dupliated path in ‘Documents’
2026-05-20T22:07:48Z [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2026-05-20T22:07:48Z [102ms] [Error] [carb.crashreporter-breakpad.plugin] ‘crashreport.gui’ exited with code 2
2026-05-20T22:07:48Z [106ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘/isaac-sim/kit/data/Kit/Isaac-Sim/5.1/011825be-e929-45c6-fa1a08a8-0ade0d25.dmp’
2026-05-20T22:07:48Z [107ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] preventing upload of minidump due to user opt-out: ‘/isaac-sim/kit/data/Kit/Isaac-Sim/5.1/011825be-e929-45c6-fa1a08a8-0ade0d25.dmp’
2026-05-20T22:07:48Z [108ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] dump file size is 3679704 bytes, file is readable.
2026-05-20T22:07:48Z [112ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 32 thread 37
2026-05-20T22:07:48Z [113ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2026-05-20T22:07:48Z [113ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] BuildGitlabJobID = ‘209507876’
2026-05-20T22:07:48Z [114ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘206.6+release.9587.07f17b1b.gl’
2026-05-20T22:07:48Z [115ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Wed May 20 22:07:48 2026 GMT’
2026-05-20T22:07:48Z [116ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2026-05-20T22:07:48Z [118ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘011825be-e929-45c6-fa1a08a8-0ade0d25’
2026-05-20T22:07:48Z [119ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] LastUploadStatus = ‘0’
2026-05-20T22:07:48Z [121ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2026-05-20T22:07:48Z [122ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy’ successfully wrote info to ‘/isaac-sim/kit/data/Kit/Isaac-Sim/5.1/011825be-e929-45c6-fa1a08a8-0ade0d25.py.txt’’
2026-05-20T22:07:48Z [124ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2026-05-20T22:07:48Z [127ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1779314831’
2026-05-20T22:07:48Z [129ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2026-05-20T22:07:48Z [131ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘37’
2026-05-20T22:07:48Z [133ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2026-05-20T22:07:48Z [136ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui’ exited with code 2’
2026-05-20T22:07:48Z [138ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘107.3.3+production.229672.69cbf6ad.gl’
2026-05-20T22:07:48Z [141ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_enabled = ‘1’
2026-05-20T22:07:48Z [143ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_flags = ‘3’
2026-05-20T22:07:48Z [146ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_status = ‘auto-enabled’
2026-05-20T22:07:48Z [149ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_version = ‘2024.1’
2026-05-20T22:07:48Z [151ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Isaac-Sim’
2026-05-20T22:07:48Z [154ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘started’
2026-05-20T22:07:48Z [156ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘5.1.0’
2026-05-20T22:07:48Z [159ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘’
2026-05-20T22:07:48Z [162ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘production’
2026-05-20T22:07:48Z [165ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘gl’
2026-05-20T22:07:48Z [167ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildConfig = ‘release’
2026-05-20T22:07:49Z [170ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobName = ‘kit-build-release-linux-x86_64’
2026-05-20T22:07:49Z [173ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobStage = ‘kit-build’
2026-05-20T22:07:49Z [176ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabPipelineID = ‘34875094’
2026-05-20T22:07:49Z [179ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘69cbf6ad’
2026-05-20T22:07:49Z [181ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘107’
2026-05-20T22:07:49Z [184ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘3’
2026-05-20T22:07:49Z [187ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘229672’
2026-05-20T22:07:49Z [190ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘3’
2026-05-20T22:07:49Z [192ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘107.3.3’
2026-05-20T22:07:49Z [195ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteFrameworkVersion = ‘206.6+release.9587.07f17b1b.gl’
2026-05-20T22:07:49Z [198ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteSdkVersion = ‘206.6+release.9587.07f17b1b.gl’
2026-05-20T22:07:49Z [201ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘/workspace/isaaclab/_isaac_sim/kit/python/bin/python3 /workspace/isaaclab/_isaac_sim/kit/python/bin/lerobot_agent --task Lerobot-So101-Teleop-Vials-To-Rack-DR’
2026-05-20T22:07:49Z [203ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuCoreLimited = ‘16’
2026-05-20T22:07:49Z [206ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuId = ‘Intel64 Family 25 Model 1 Stepping 1’
2026-05-20T22:07:49Z [209ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuLogicalCoresBareMetal = ‘16’
2026-05-20T22:07:49Z [212ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuName = ‘AMD EPYC 7R13 Processor’
2026-05-20T22:07:49Z [215ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuPhysicalCoresBareMetal = ‘8’
2026-05-20T22:07:49Z [218ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuUsageQuota = ‘-1.000000’
2026-05-20T22:07:49Z [220ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuVendor = ‘AuthenticAMD’
2026-05-20T22:07:49Z [223ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopOrigin = ‘(0, 0)’
2026-05-20T22:07:49Z [226ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopSize = ‘1536x688’
2026-05-20T22:07:49Z [229ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayCount = ‘1’
2026-05-20T22:07:49Z [232ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayRes_0 = ‘1536x688x32bit@60Hz’
2026-05-20T22:07:49Z [235ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘Individual’
2026-05-20T22:07:49Z [237ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] externalBuild = ‘1’
2026-05-20T22:07:49Z [240ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_0 = ‘595.58’
2026-05-20T22:07:49Z [243ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_0 = ‘48305799168’
2026-05-20T22:07:49Z [246ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_0 = ‘NVIDIA L40S’
2026-05-20T22:07:49Z [249ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] kitRendererDriverVersion = ‘595.58’
2026-05-20T22:07:49Z [251ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommand = ‘ChangeSetting(path=/persistent/exts/omni.kit.viewport.menubar.camera/expand,value=False,prev=True)’
2026-05-20T22:07:49Z [254ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommands = ‘SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=),ChangeSetting(path=/persistent/exts/omni.kit.viewport.menubar.camera/expand,value=False,prev=True)’
2026-05-20T22:07:49Z [257ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildBranch = ‘release’
2026-05-20T22:07:49Z [260ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildDate = ‘Fri Oct 17 03:55:10 2025 +0000’
2026-05-20T22:07:49Z [263ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildHash = ‘9c81211’
2026-05-20T22:07:49Z [266ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildRepo = ‘https://gitlab-master.nvidia.com/omniverse/isaac/omni_isaac_sim.git’
2026-05-20T22:07:49Z [268ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildVersion = ‘5.1.0-rc.19’
2026-05-20T22:07:49Z [271ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildBranch = ‘HEAD’
2026-05-20T22:07:49Z [274ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildDate = ‘Oct-03-2025’
2026-05-20T22:07:49Z [277ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildHash = ‘3a61992’
2026-05-20T22:07:49Z [280ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildRepo = ‘gitlab-master.nvidia.com/omniverse/physics’
2026-05-20T22:07:49Z [282ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildVersion = ‘107.3.26’
2026-05-20T22:07:49Z [285ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 119.072/124.117GB, Swap: 0/0GB, VM: 1.71799e+10/1.71799e+10GB’
2026-05-20T22:07:49Z [288ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = ’
==============NVSMI LOG==============
Timestamp : Wed May 20 22:07:18 2026
Driver Version : 595.58.03
CUDA Version : 13.2
Attached GPUs : 1
GPU 00000000:34:00.0
Product Name : NVIDIA L40S
Product Brand : NVIDIA
Product Architecture : Ada Lovelace
Display Mode : Requested functionality has been deprecated
Display Attached : Yes
Display Active : Disabled
Persistence Mode : Disabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : 1652224094594
GPU UUID : GPU-8b39e995-519d-1039-01fc-72e46dd8ef56
GPU PDI : 0xe8e3dd4426fe56ee
Minor Number : 0
VBIOS Version : 95.02.66.00.15
MultiGPU Board : No
Board ID : 0x3400
Board Part Number : 900-2G133-A880-000
GPU Part Number : 26B9-896-A1
FRU Part Number : N/A
Platform Info
Chassis Serial Number : N/A
Slot Number : N/A
Tray Index : N/A
Host ID : N/A
Peer Type : N/A
Module Id : 1
GPU Fabric GUID : N/A
Inforom Version
Image Version : G133.0242.00.03
OEM Object : 2.1
ECC Object : 6.16
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : Pass-Through
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Recovery Action : None
GSP Firmware Version : 595.58.03
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x34
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x2
Device Id : 0x26B910DE
Bus Id : 00000000:34:00.0
Sub System Id : 0x185110DE
GPU Link Info
PCIe Generation
Max : 4
Current : 4
Device Current : 4
Device Max : 4
Host Max : N/A
Link Width
Max : 16x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 439 KB/s
Rx Throughput : 20019 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : N/A
Performance State : P0
Clocks Event Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Clocks Event Reasons Counters
SW Power Capping : 0 us
Sync Boost : 0 us
SW Thermal Slowdown : 0 us
HW Thermal Slowdown : 0 us
HW Power Braking : 0 us
Sparse Operation Mode : N/A
FB Memory Usage
Total : 46068 MiB
Reserved : 609 MiB
Used : 1706 MiB
Free : 43755 MiB
BAR1 Memory Usage
Total : 65536 MiB
Used : 1719 MiB
Free : 63817 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
GPU : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 1
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
DRAM Encryption Mode
Current : N/A
Pending : N/A
ECC Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
SRAM Correctable : 0
SRAM Uncorrectable Parity : 0
SRAM Uncorrectable SEC-DED : 0
DRAM Correctable : 0
DRAM Uncorrectable : 0
Aggregate
SRAM Threshold Exceeded : No
Aggregate Uncorrectable SRAM Sources
SRAM L2 : 0
SRAM SM : 0
SRAM Microcontroller : 0
SRAM PCIE : 0
SRAM Other : 0
Channel Repair Pending : No
TPC Repair Pending : No
Unrepairable Memory : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 40 C
GPU T.Limit Temp : 48 C
GPU Shutdown T.Limit Temp : -5 C
GPU Slowdown T.Limit Temp : -2 C
GPU Max Operating T.Limit Temp : 0 C
GPU Target Temperature : N/A
Memory Current Temp : N/A
Memory Max Operating T.Limit Temp : N/A
GPU Power Readings
Average Power Draw : 83.83 W
Instantaneous Power Draw : 83.12 W
Current Power Limit : 350.00 W
Requested Power Limit : 350.00 W
Default Power Limit : 350.00 W
Min Power Limit : 100.00 W
Max Power Limit : 350.00 W
GPU Memory Power Readings
Average Power Draw : N/A
Instantaneous Power Draw : N/A
Module Power Readings
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Power Smoothing : N/A
Workload Power Profiles
Requested Profiles : N/A
Enforced Profiles : N/A
EDPp Multiplier : N/A
Clocks
Graphics : 2520 MHz
SM : 2520 MHz
Memory : 9001 MHz
Video : 1965 MHz
Applications Clocks
Graphics : Requested functionality has been deprecated
Memory : Requested functionality has been deprecated
Default Applications Clocks
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 2520 MHz
SM : 2520 MHz
Memory : 9001 MHz
Video : 1965 MHz
Max Customer Boost Clocks
Graphics : 2520 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Summary : N/A
Bandwidth : N/A
Route Recovery in progress : N/A
Route Unhealthy : N/A
Access Timeout Recovery : N/A
Incorrect Configuration : N/A
Partition Assigned : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 2769
Type : G
Name :
Used GPU Memory : 69 MiB
Process ID : 2955
Type : G
Name :
Used GPU Memory : 57 MiB
Process ID : 3202
Type : C+G
Name :
Used GPU Memory : 1365 MiB
Capabilities
EGM : disabled
2026-05-20T22:07:49Z [291ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘ubuntu’
2026-05-20T22:07:49Z [294ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘24.04.2 LTS (Noble Numbat)’
2026-05-20T22:07:49Z [297ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘24.04.2’
2026-05-20T22:07:49Z [300ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘1’
2026-05-20T22:07:49Z [302ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] primaryDisplayRes = ‘1536x688x32bit@60Hz’
2026-05-20T22:07:49Z [305ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
2026-05-20T22:07:49Z [308ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runningInContainer = ‘1’
2026-05-20T22:07:49Z [311ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_debugSymbols = ‘0’
2026-05-20T22:07:49Z [314ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIncludeOverrides = ‘0’
2026-05-20T22:07:49Z [317ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIntermediates = ‘0’
2026-05-20T22:07:49Z [320ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_obfuscateCode = ‘1’
2026-05-20T22:07:49Z [323ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_optimizationLevel = ‘1’
2026-05-20T22:07:49Z [325ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ’
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| | | | | | 26b9 | 8b39e995.. |
| | | | | | 34 | |
2026-05-20T22:07:49Z [328ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘12068389420713931693’
2026-05-20T22:07:49Z [331ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
2026-05-20T22:07:49Z [334ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamBareMetalMB = ‘127096’
2026-05-20T22:07:49Z [337ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamLimitedMB = ‘127096’
2026-05-20T22:07:49Z [339ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapBareMetalMB = ‘0’
2026-05-20T22:07:49Z [342ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapLimitedMB = ‘0’
2026-05-20T22:07:49Z [345ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’
2026-05-20T22:07:49Z [348ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/workspace/Sim-to-Real-SO-101-Workshop’
2026-05-20T22:07:49Z [350ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 37 backtrace follows:
2026-05-20T22:07:49Z [377ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (??:?)
2026-05-20T22:07:49Z [387ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: librtx.scenedb.plugin.so!void std::vector<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>, std::allocator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> > >::_M_realloc_insert<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> >(__gnu_cxx::__normal_iterator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>*, std::vector<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>, std::allocator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> > > >, std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>&&)+0x123ef (??:?)
2026-05-20T22:07:49Z [396ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: librtx.scenedb.plugin.so!void std::vector<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>, std::allocator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> > >::_M_realloc_insert<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> >(__gnu_cxx::__normal_iterator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>*, std::vector<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>, std::allocator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> > > >, std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>&&)+0x12766 (??:?)
2026-05-20T22:07:49Z [405ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: librtx.scenedb.plugin.so!void std::vector<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>, std::allocator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> > >::_M_realloc_insert<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> >(__gnu_cxx::__normal_iterator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>*, std::vector<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>, std::allocator<std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int> > > >, std::tuple<char const*, float, float, unsigned int, unsigned int, unsigned int>&&)+0x14a14 (??:?)
2026-05-20T22:07:49Z [415ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: librtx.scenedb.plugin.so!carbOnPluginStartup+0x3b4de (??:?)
2026-05-20T22:07:49Z [424ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: librtx.scenedb.plugin.so!void std::vector<int, std::allocator >::_M_realloc_insert(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator > >, int&&)+0x7ce1 (??:?)
2026-05-20T22:07:49Z [433ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libcarb.scenerenderer-rtx.plugin.so!std::unordered_map<unsigned int, unsigned int, std::hash, std::equal_to, std::allocator<std::pair<unsigned int const, unsigned int> > >::~unordered_map()+0x4655f (??:?)
2026-05-20T22:07:49Z [442ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libcarb.scenerenderer-rtx.plugin.so!std::unordered_map<unsigned int, unsigned int, std::hash, std::equal_to, std::allocator<std::pair<unsigned int const, unsigned int> > >::~unordered_map()+0x64486 (??:?)
2026-05-20T22:07:49Z [451ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libcarb.scenerenderer-rtx.plugin.so!carbOnPluginShutdown+0xe4b (??:?)
2026-05-20T22:07:49Z [458ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libomni.hydra.rtx.plugin.so!+0x4459
2026-05-20T22:07:49Z [469ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libomni.usd.so!void std::vector<unsigned long, std::allocator >::_M_realloc_insert(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator > >, unsigned long&&)+0x10da (??:?)
2026-05-20T22:07:49Z [479ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libomni.usd.so!void std::vector<unsigned long, std::allocator >::_M_realloc_insert(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator > >, unsigned long&&)+0x58ce (??:?)
2026-05-20T22:07:49Z [490ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libomni.usd.so!void std::vector<unsigned long, std::allocator >::_M_realloc_insert(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator > >, unsigned long&&)+0x5c5a (??:?)
2026-05-20T22:07:49Z [504ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(carb::tasking::Fiber*, carb::tasking::Scheduler::TrackedThread*), carb::tasking::Scheduler*, carb::tasking::Fiber*, carb::tasking::Scheduler::TrackedThread*> > >::_M_run()+0xa3a7 (??:?)
2026-05-20T22:07:49Z [518ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libcarb.tasking.plugin.so!void std::vector<int, std::allocator >::_M_realloc_insert<int const&>(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator > >, int const&)+0xb6dc (??:?)
2026-05-20T22:07:49Z [531ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libcarb.tasking.plugin.so!void std::vector<int, std::allocator >::_M_realloc_insert<int const&>(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator > >, int const&)+0xb6ff (??:?)
2026-05-20T22:07:49Z [544ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libcarb.tasking.plugin.so!make_fcontext+0x39 (??:?)
