Hi, I am trying to setup IssacSim on my remote workstation server with docker container. IssacSim is running headlessly in the docker container, and I am accessing it using Omniverse Streaming Client. I was able to run it with runheadless.native.sh
script, but I am not able to do it via Python interface. I tried running Livestream.py
example but I have errors that I don’t know how to resolve. Would you be able to help me out?
Below is part of log and I also attached the full log. Any suggestion would be greatly appreciated!
Loading user config located at: ‘/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/user.config.json’
[Info] [carb] Logging to file: /root/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.2/kit_20230207_103003.log
2023-02-07 15:30:03 [45ms] [Warning] [omni.ext.plugin] [ext: omni.drivesim.sensors.nv.lidar] Extensions config ‘extension.toml’ doesn’t exist ‘/isaac-sim/exts/omni.drivesim.sensors.nv.lidar’ or ‘/isaac-sim/exts/omni.drivesim.sensors.nv.lidar/config’
2023-02-07 15:30:03 [45ms] [Warning] [omni.ext.plugin] [ext: omni.drivesim.sensors.nv.radar] Extensions config ‘extension.toml’ doesn’t exist ‘/isaac-sim/exts/omni.drivesim.sensors.nv.radar’ or ‘/isaac-sim/exts/omni.drivesim.sensors.nv.radar/config’
[0.218s] [ext: omni.stats-0.0.0] startup
[0.246s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.257s] [ext: omni.assets.plugins-0.0.0] startup
[0.258s] [ext: omni.gpu_foundation-0.0.0] startup
2023-02-07 15:30:03 [244ms] [Warning] [carb] FrameworkImpl::setDefaultPlugin(client: omni.gpu_foundation_factory.plugin, desc : [carb::graphics::Graphics v2.11], plugin : carb.graphics-vulkan.plugin) failed. Plugin selection is locked, because the interface was previously acquired by:
[0.263s] [ext: carb.windowing.plugins-1.0.0] startup
2023-02-07 15:30:03 [245ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-02-07 15:30:03 [245ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[0.264s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-02-07 15:30:04 [300ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-02-07 15:30:04 [300ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
2023-02-07 15:30:04 [300ms] [Error] [carb.glinterop.plugin] GLInteropContext::init: carb::windowing is not available
2023-02-07 15:30:04 [616ms] [Warning] [gpu.foundation.plugin] Raytracing is not supported on GPU: 1. Skipping this device.|---------------------------------------------------------------------------------------------|
| Driver Version: 525.85.12 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA RTX A5000 | Yes: 0 | | 24810 MB | 10de | 0 |
| | | | | | 2231 | c32f96f6… |
| 1 | NVIDIA T400 4GB | | | 4342 MB | 10de | 0 |
| | | | | | 1ff2 | 7effd56f… |
| OS: Linux WS1, Version: 5.15.0-58-generic
| Processor: AMD Ryzen Threadripper PRO 5945WX 12-Cores | Cores: Unknown | Logical: 24
| Total Memory (MB): 64132 | Free Memory: 59926
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
2023-02-07 15:30:04 [722ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled. Found 62 items in /sys/kernel/iommu_groups/.
2023-02-07 15:30:04 [722ms] [Warning] [gpu.foundation.plugin] On Linux only, CUDA and the display driver does not support IOMMU-enabled bare-metal PCIe peer to peer memory copy.
However, CUDA and the display driver does support IOMMU via VM pass through. As a consequence, users on Linux,
when running on a native bare metal system, should disable the IOMMU. The IOMMU should be enabled and the VFIO driver
be used as a PCIe pass through for virtual machines.
2023-02-07 15:30:04 [722ms] [Warning] [gpu.foundation.plugin] -----------------------------------------------------------------------
2023-02-07 15:30:04 [722ms] [Warning] [gpu.foundation.plugin] !!! Local system validation failed! Incorrect configuration detected.
2023-02-07 15:30:04 [722ms] [Warning] [gpu.foundation.plugin] Summary below. Details above.
2023-02-07 15:30:04 [722ms] [Warning] [gpu.foundation.plugin] - ECC: OK
2023-02-07 15:30:04 [722ms] [Warning] [gpu.foundation.plugin] - IOMMU: FAILED
IssacSim-log-error-020723.log (49.4 KB)
