Issue with NoneType object returned for get_navmesh()
[Issue with NoneType object returned for get_navmesh()]
start_navmesh_baking is SUCCESS but get_navmesh is None.
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: 4090D
  • Driver Version: 570.86.16
Topic Description
import isaacsim
from omni.isaac.kit import SimulationApp
import os
pwd = os.getcwd()
CONFIG = {
    "width": 1280,
    "height": 720,
    "headless": True,
    "renderer": "PathTracing",
    # "samples_per_pixel_per_frame": 16,
    "multi_gpu": True,
kit = SimulationApp(launch_config=CONFIG)
import omni
omni.usd.get_context().open_stage(os.path.join(pwd, "my.usd"))
from isaacsim.core.api import World
from omni.isaac.core.utils.stage import is_stage_loading
import omni.anim.navigation.core as nav
world = World(
    stage_units_in_meters=1.0,
    physics_dt=1.0 / 60.0,
    rendering_dt=1 / 10.0
while is_stage_loading():
    kit.update()
world.play()
inav = nav.acquire_interface()
baking_status = inav.start_navmesh_baking()
if baking_status:
    print("baking success")
else:
    print("baking failed")
inav_i = 0
while inav.get_navmesh() is None and inav_i <50:
    kit.update()
    print("is none" + str(inav_i))
    inav_i += 1
if inav.get_navmesh() is not None:
    print("suceess get navmesh")
else:
    print("failed get navmesh after update 50iter")
Log
[5.350s] [ext: omni.kit.property.material-1.10.17] startup
[5.359s] [ext: omni.isaac.core_nodes-2.0.2] startup
2025-08-01 05:48:18 [5,350ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[5.360s] [ext: isaacsim.replicator.behavior-1.0.8] startup
[5.362s] [ext: omni.kit.property.physx-106.5.7] startup
[5.380s] [ext: omni.kit.property.audio-1.0.16] startup
[5.383s] [ext: omni.kit.property.camera-1.0.9] startup
[5.384s] [ext: omni.hydra.scene_api-0.1.2] startup
[5.390s] [ext: omni.kit.property.geometry-1.3.3] startup
[5.394s] [ext: omni.kit.property.light-1.0.11] startup
[5.396s] [ext: isaacsim.app.about-2.0.7] startup
[5.398s] [ext: omni.kit.property.render-1.1.3] startup
[5.399s] [ext: isaacsim.simulation_app-2.4.2] startup
[5.400s] [ext: omni.kit.property.transform-1.5.10] startup
[5.403s] [ext: omni.physx.demos-106.5.7] startup
[5.416s] [ext: isaacsim.gui.property-1.0.4] startup
[5.417s] [ext: omni.isaac.window.about-2.0.2] startup
2025-08-01 05:48:18 [5,408ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-08-01 05:48:18 [5,408ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[5.418s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[5.420s] [ext: omni.isaac.kit-2.0.3] startup
[5.421s] [ext: omni.kit.property.bundle-1.3.2] startup
[5.421s] [ext: omni.physx.vehicle-106.5.7] startup
[5.433s] [ext: omni.kit.property.isaac-1.0.2] startup
2025-08-01 05:48:18 [5,425ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-08-01 05:48:18 [5,425ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
[5.436s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[5.446s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[5.447s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[5.452s] [ext: isaacsim.replicator.domain_randomization-1.0.2] startup
[5.457s] [ext: omni.physx.camera-106.5.7] startup
[5.478s] [ext: omni.kit.window.toolbar-1.6.2] startup
[5.484s] [ext: omni.physx.cct-106.5.7] startup
[5.499s] [ext: isaacsim.cortex.framework-1.0.2] startup
[5.500s] [ext: omni.isaac.universal_robots-1.0.2] startup
2025-08-01 05:48:18 [5,492ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,493ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,494ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[5.504s] [ext: isaacsim.replicator.writers-1.0.1] startup
[5.529s] [ext: omni.physx.graph-106.5.7] startup
[5.556s] [ext: omni.physx.supportui-106.5.7] startup
[5.577s] [ext: omni.isaac.utils-2.0.2] startup
[5.580s] [ext: omni.isaac.cortex-1.0.2] startup
2025-08-01 05:48:18 [5,571ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
[5.581s] [ext: omni.physx.telemetry-106.5.7] startup
[5.584s] [ext: isaacsim.replicator.examples-1.1.2] startup
[5.585s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[5.595s] [ext: omni.rtx.window.settings-0.6.17] startup
[5.600s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[5.617s] [ext: omni.kit.window.status_bar-0.1.7] startup
[5.620s] [ext: omni.physx.bundle-106.5.7] startup
[5.620s] [ext: omni.replicator.isaac-2.0.3] startup
2025-08-01 05:48:18 [5,611ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[5.621s] [ext: omni.replicator.replicator_yaml-2.0.10] startup
[5.630s] [ext: omni.rtx.settings.core-0.6.3] startup
[5.632s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[5.636s] [ext: isaacsim.cortex.behaviors-2.0.3] startup
[5.637s] [ext: omni.isaac.version-2.0.2] startup
2025-08-01 05:48:18 [5,629ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[5.639s] [ext: semantics.schema.editor-0.3.10] startup
[5.644s] [ext: omni.kit.ui.actions-1.0.2] startup
[5.646s] [ext: semantics.schema.property-1.0.5] startup
[5.647s] [ext: omni.isaac.wheeled_robots-3.0.3] startup
2025-08-01 05:48:18 [5,638ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,638ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,638ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,638ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,639ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,639ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,639ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,639ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,639ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,639ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,639ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-01 05:48:18 [5,639ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[5.649s] [ext: omni.isaac.cortex.sample_behaviors-2.0.2] startup
2025-08-01 05:48:18 [5,641ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[5.651s] [ext: omni.anim.curve.core-1.2.0] startup
[5.663s] [ext: isaacsim.asset.importer.mjcf-2.3.3] startup
[5.673s] [ext: omni.kit.menu.common-1.1.9] startup
[5.676s] [ext: isaacsim.exp.base-4.5.0] startup
[5.677s] [ext: isaacsim.exp.base.python-4.5.0] startup
[5.679s] Simulation App Starting
[5.973s] app ready
2025-08-01 05:48:19 [6,017ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7508933632
2025-08-01 05:48:19 [6,017ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-08-01 05:48:19 [6,017ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7433845248
2025-08-01 05:48:19 [6,017ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9574251 (slope: 447, intercept: 13179904)
2025-08-01 05:48:19 [6,017ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287216384
2025-08-01 05:48:19 [6,017ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
2025-08-01 05:48:19 [6,120ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults-transient/meshlights/forceDisable'
2025-08-01 05:48:19 [6,154ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults/post/dlss/execMode'
[8.472s] Simulation App Startup Complete
2025-08-01 05:48:21 [8,508ms] [Warning] [omni.usd] Unexpected reference count of 2 for UsdStage 'anon:0x6266b89ab490:World0.usd' while being closed in UsdContext (this may indicate it is still resident in memory).
2025-08-01 05:48:21 [8,571ms] [Warning] [omni.usd] Warning: in _GetOrderedXformOps at line 521 of /builds/omniverse/usd-ci/USD/pxr/usd/usdGeom/xformable.cpp -- Unable to get attribute associated with the xformOp 'xformOp:scale', on the prim at path </OmniverseKit_Persp>. Skipping xformOp in the computation of the local transformation at prim.
2025-08-01 05:48:21 [8,572ms] [Warning] [omni.usd] Warning: in _GetOrderedXformOps at line 521 of /builds/omniverse/usd-ci/USD/pxr/usd/usdGeom/xformable.cpp -- Unable to get attribute associated with the xformOp 'xformOp:scale', on the prim at path </OmniverseKit_Front>. Skipping xformOp in the computation of the local transformation at prim.
2025-08-01 05:48:21 [8,573ms] [Warning] [omni.usd] Warning: in _GetOrderedXformOps at line 521 of /builds/omniverse/usd-ci/USD/pxr/usd/usdGeom/xformable.cpp -- Unable to get attribute associated with the xformOp 'xformOp:scale', on the prim at path </OmniverseKit_Top>. Skipping xformOp in the computation of the local transformation at prim.
2025-08-01 05:48:21 [8,573ms] [Warning] [omni.usd] Warning: in _GetOrderedXformOps at line 521 of /builds/omniverse/usd-ci/USD/pxr/usd/usdGeom/xformable.cpp -- Unable to get attribute associated with the xformOp 'xformOp:scale', on the prim at path </OmniverseKit_Right>. Skipping xformOp in the computation of the local transformation at prim.
2025-08-01 05:48:21 [8,583ms] [Warning] [omni.isaac.core.utils.stage] omni.isaac.core.utils.stage has been deprecated in favor of isaacsim.core.utils.stage. Please update your code accordingly.
2025-08-01 05:48:21 [8,741ms] [Warning] [omni.usd] Warning: in _GetOrderedXformOps at line 521 of /builds/omniverse/usd-ci/USD/pxr/usd/usdGeom/xformable.cpp -- Unable to get attribute associated with the xformOp 'xformOp:scale', on the prim at path </OmniverseKit_Front>. Skipping xformOp in the computation of the local transformation at prim.
2025-08-01 05:48:23 [10,046ms] [Warning] [omni.usd] Warning: in AppendProperty at line 858 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Can only append a property 'physics:rigidBodyEnabled' to a prim path (/)
baking success
is none0
is none1
is none2
is none3
is none4
is none5
is none6
is none7
is none8
is none9
is none10
is none11
is none12
is none13
is none14
is none15
is none16
is none17
is none18
is none19
is none20
is none21
is none22
is none23
is none24
is none25
is none26
is none27
is none28
is none29
is none30
is none31
is none32
is none33
is none34
is none35
is none36
is none37
is none38
is none39
is none40
is none41
is none42
is none43
is none44
is none45
is none46
is none47
is none48
is none49
Can you please reference the file extscache/omni.anim.navigation.core-106.4.0+106.4.0.lx64.r.cp310/omni/anim/navigation/core/tests/test_navmesh.py for further debugging?
Hello!
Best regards,
