Issue with R39.2.1 burning failure
亲爱的英伟达工程师们,你们好:
我使用的是Jetson AGX Thor Developer Kit 128GB-DRAM (P3834-0008)
我的烧录文件是:
Jetson_Linux_R39.2.1_aarch64.tbz2
Tegra_Linux_Sample-Root-Filesystem_R39.2.1_aarch64.tbz2
我的烧录流程是完全按照Quick Start来开展的:
tar xf ${L4T_RELEASE_PACKAGE}
sudo tar xpf ${SAMPLE_FS_PACKAGE} -C Linux_for_Tegra/rootfs/
cd Linux_for_Tegra/
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./apply_binaries.sh --openrm
sudo ./l4t_initrd_flash.sh jetson-agx-thor-devkit internal
为什么每次都会报错:
[flash_bsp_jetson-t264_die0]: [ListADBDevices(180)] : listing connected adb devices with sudo
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb devices -l
cwd = /home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/flash_workspace/flash-images
[flash_bsp_jetson-t264_die0]: [executeShellCommand(163)] : List of devices attached
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = timeout 5 /home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U20U50HG000000VV020 wait-for-device
[flash_bsp_jetson-t264_die0]: [executeShellCommand(171)] : shell command – timeout 5 /home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U20U50HG000000VV020 wait-for-device failed
[flash_bsp_jetson-t264_die0]: [executeShellCommand(173)] : Output:
[flash_bsp_jetson-t264_die0]: [executeShellCommand(175)] : Return code: 124
[flash_bsp_jetson-t264_die0]: [executeShellCommand(177)] : stdout: b’’
[flash_bsp_jetson-t264_die0]: [executeShellCommand(179)] : stderr: None
[flash_bsp_jetson-t264_die0]: [AdbFindDevice(203)] : the ADB device is not yet found online : 2U20U50HG000000VV020
[flash_bsp_jetson-t264_die0]: [AdbFindDevice(204)] : current totaltime in finding device online : 95
[flash_bsp_jetson-t264_die0]: [AdbFindDevice(208)] : failed to find the device :2U20U50HG000000VV020 online at the end of :100 seconds
[flash_bsp_jetson-t264_die0]: [CheckUSBServiceInit(281)] : Could not find a device online, after killing and re-starting ADBserver
File “/home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn/../bootburn_t264_py/flash_bsp_images.py”, line 119, in flash_bsp_active
bootburnThor.FlashImages(binaryLocationPath)
File “/home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn/../bootburn_t264_py/bootburn_lib.py”, line 3206, in FlashImages
adbObj.CheckUSBServiceInit(timeout, self.sudoRequired)
File “/home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn/../bootburn_t264_py/bootburn_adb.py”, line 282, in CheckUSBServiceInit
AbnormalTermination(“${s_ERROR_ADB_TIMEOUT}”, nverror.NvError_Timeout)
File “/home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn/../bootburn_t264_py/flashtools_nverror.py”, line 260, in AbnormalTermination
raise OSError(errorCode)
OSError: 5
command line used was:
[‘/home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn/flash_bsp_images.py’, ‘-b’, ‘jetson-t264’, ‘–l4t’, ‘-D’, ‘-P’, ‘/home/cpb/Linux_for_Tegra/unified_flash/out/bsp_images/flash_workspace’, ‘–l4t_boot_chain_select’, ‘A’, ‘–usb-instance’, ‘1-8’]
Exception raised in flash BSP ACTIVE
5
[flash_bsp_jetson-t264]: start time = 1786676920.5124907
[flash_bsp_jetson-t264]: end time = 1786677142.0526347
[flash_bsp_jetson-t264]: Total Time = 221.5401439666748
[flash_bsp_jetson-t264]: Image Flashing took 221.5401439666748
[flash_bsp_jetson-t264]: Flashing finished Unsuccessfully!!
Cleaning up…
You could check this image to make sure you have usb cable plugged in to the correct usb port.
the-adb-device-is-not-yet-found-online
谢谢你的回复^-^
我的硬件是没问题的,因为我之前烧录R38.4.0系统是可以正常启动的。
From your host when Thor is attached and in recovery mode
lsusb |grep “0955:7026”
Does it return anything?
我反复烧录多次,这次显示能烧录了!没有ADB超时报错了!
谢谢你的耐心回复^-^
我现在成功烧录了,但是烧写完后,内核一直在打印:
[ 143.651734] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 143.651737] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
** 1 printk messages dropped **
[ 143.671727] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 143.671730] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
** 2 printk messages dropped **
[ 143.705601] nvethernet a808a10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 143.714932] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.727726] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 143.747727] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
** 5 printk messages dropped **
[ 143.783730] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.787238] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.818755] nvethernet a808a10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 143.828085] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
** 4 printk messages dropped **
[ 143.859726] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 143.875729] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.884660] nvethernet a808e10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.895730] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.915731] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.944616] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.959745] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 143.975727] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 143.978353] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.007730] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.027727] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.027730] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.051730] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.059977] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
** 3 printk messages dropped **
[ 144.071629] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.087628] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.095699] nvethernet a808b10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.119345] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.135062] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.143727] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.150427] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.154455] nvethernet a808b10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.183725] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.195017] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.203725] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.223727] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.257865] nvethernet a808b10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.269169] nvethernet a808e10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.279729] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.284881] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.299731] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.329137] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.344252] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.359726] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.364359] nvethernet a808b10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.379628] nvethernet a808a10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.387698] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.387908] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.399702] nvethernet a808a10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.431914] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.435728] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.444483] nvethernet a808e10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.455730] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.488499] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.511726] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.531726] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.531729] nvethernet a808e10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.551729] nvethernet a808e10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.571728] nvethernet a808e10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.576144] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.596036] nvethernet a808a10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.611628] nvethernet a808b10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.615630] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.619799] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.639728] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.652033] nvethernet a808a10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.667628] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.675700] nvethernet a808a10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.675701] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.707456] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 144.711727] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 144.711730] nvethernet a808d10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
系统也无法启动,请问您知道原因吗?
当时输入命令:
lsusb
我能看到:
Bus 001 Device 036: ID 0955:7020 NVIDIA Corp. L4T (Linux for Tegra) running on Tegra
我进入到了这个界面:
我记录下了串口打印信息
打印日志.log (2.6 MB)
You could try this to see if it stops the excessive nvethernet dmesg logging.
sudo tee /etc/NetworkManager/conf.d/99-mgbe.conf <<'EOF'
   [keyfile]
   unmanaged-devices=interface-name:mgbe*
   EOF
sudo systemctl restart NetworkManager
sudo ip link set mgbe0_0 down
sudo ip link set mgbe1_0 down
sudo ip link set mgbe2_0 down
sudo ip link set mgbe3_0 down
这个命令应该是已经烧录好系统、正常启动到桌面或串口后的开发板(Jetson Thor 的 Linux 系统)终端里运行的吧?我现在无法进入系统,无法这样调试。
先把dtb裡面4組mgbe關閉… 然後重燒
非常感谢!我这就试一试
我已经按照你说的修改完了:
cpb@cpb-YangTianM4000q-33IRB:~/Linux_for_Tegra$ dtc -I dtb -O dts
kernel/dtb/tegra264-p4071-0000+p3834-0008-nv.dtb
2>/dev/null |
grep -n -A3 -E
‘ethernet@a808a10000|ethernet@a808b10000|ethernet@a808d10000|ethernet@a808e10000’
6177: ethernet@a808a10000 {
6178- compatible = “nvidia,tegra264-mgbe”;
6179- status = “disabled”;
6180- reg = <0xa8 0x8a10000 0x00 0x10000 0xa8 0x8aa0000 0x00 0x10000 0xa8 0x8ad0000 0x00 0x10000 0xa8 0x8a00000 0x00 0x10000>;
6231: ethernet@a808b10000 {
6232- compatible = “nvidia,tegra264-mgbe”;
6233- status = “disabled”;
6234- reg = <0xa8 0x8b10000 0x00 0x10000 0xa8 0x8ba0000 0x00 0x10000 0xa8 0x8bd0000 0x00 0x10000 0xa8 0x8b00000 0x00 0x10000>;
6285: ethernet@a808d10000 {
6286- compatible = “nvidia,tegra264-mgbe”;
6287- status = “disabled”;
6288- reg = <0xa8 0x8d10000 0x00 0x10000 0xa8 0x8da0000 0x00 0x10000 0xa8 0x8dd0000 0x00 0x10000 0xa8 0x8d00000 0x00 0x10000>;
6339: ethernet@a808e10000 {
6340- compatible = “nvidia,tegra264-mgbe”;
6341- status = “disabled”;
6342- reg = <0xa8 0x8e10000 0x00 0x10000 0xa8 0x8ea0000 0x00 0x10000 0xa8 0x8ed0000 0x00 0x10000 0xa8 0x8e00000 0x00 0x10000>;
我重新执行了:
为什么还是起不来?我使用命令:lsusb
仍然显示是恢复模式:Bus 001 Device 051: ID 0955:7026 NVIDIA Corp. APX
串口启动打印如下:
COM10_2026-08-14_15_04_49.log (181.3 KB)
Excuse me, do you have instructions for operating the SDK Manager software? Similar to this:
Welcome — NVIDIA Jetson Linux Developer Guide
This’s what I’m talking about:
The latest serial log shows that the error occurs before Linux starts. Please do not make further MGBE DTB changes yet. Instead, use a newly extracted, unmodified R39.2.1 BSP and reflash it with the following commands:
tar xf Jetson_Linux_R39.2.1_aarch64.tbz2
sudo tar xpf Tegra_Linux_Sample-Root-Filesystem_R39.2.1_aarch64.tbz2 \
cd Linux_for_Tegra/
sudo ./l4t_initrd_flash.sh --erase-all jetson-agx-thor-devkit internal
The --erase-all option deletes all data on the NVMe drive. Please back up any required data first.
After flashing completes, manually reboot or power-cycle the developer kit. If the unmodified BSP still does not boot, please provide the complete serial log from this test.
Official R39.2.1 flashing instructions:
Well, thank you very much.^-^
Dear Wickiu:
I have strictly followed your method, but this error still occurred:
[ 49.984082] nvethernet a808e10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 50.007713] nvethernet a808b10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 50.007716] nvethernet a808b10000.ethernet: [xpcs_lane_bring_up][782][type:0x4][loga-0x0] UPHY Rx lane bringup failed with sw override method
[ 50.027725] nvethernet a808d10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
[ 50.047719] nvethernet a808a10000.ethernet: [sw_override_method_for_uphy_rx_lane][671][type:0x4][loga-0x80000102] RX_CAL_EN polling timeout:
The specific print log is as follows:
start.log (371.2 KB)
Thanks for the log. It shows that Ubuntu mounts the root filesystem and starts NetworkManager and user sessions before the MGBE messages begin.
After waiting about two minutes, can you access the OEM setup screen, desktop, or serial login prompt despite these messages?
If not, please provide a longer serial log that continues until the board hangs or reboots.
This is the complete printed log of me from power on until it froze. Please check it.
After the system froze, it started over again, and I didn’t capture it in the logs afterwards.
Complete_printing.log (2.7 MB)
Thank you very much.^-^
我还是烧写的R38.4,解决了
你應該是在燒custom board而不是devkit吧…?
如果是的話可能要說明一下你們底板上是否沒有在使用MGBE. 沒有的話要額外改設定…
如果你今天不把這問題釐清你以後還是會再碰上
