Hy,
I’m using a jetson nano and a raspberry pi camera module V2 and want to run a code from a course about YOLO + object detection.
When i try to run the code with Spyder (python 3.6) this error occures:
File “/home/dlinano/Documents/Python/UdemyTrainingYOLO/activity-1/detecting-object.py”, line 44, in
frame_HSV = cv2.cvtColor(frame_BGR, cv2.COLOR_BGR2HSV)
error: OpenCV(4.1.1) /home/nvidia/host/build_opencv/nv_opencv/modules/imgproc/src/color.cpp:182: error: (-215:Assertion failed) !_src.empty() in function ‘cvtColor’
This is the program:
# Detecting Object with chosen Colour Mask
# Algorithm:
# Reading RGB image --> Converting to HSV --> Implementing Mask -->
# --> Finding Contour Points --> Extracting Rectangle Coordinates -->
# --> Drawing Bounding Box --> Putting Label
# Result:
# Window with Detected Object, Bounding Box and Label in Real Time
# Importing needed library
import cv2
# Defining lower bounds and upper bounds of founded Mask
min_blue, min_green, min_red = 21, 222, 70
max_blue, max_green, max_red = 176, 255, 255
# Getting version of OpenCV that is currently used
# Converting string into the list by dot as separator
# and getting first number
v = cv2.__version__.split('.')[0]
# Defining object for reading video from camera
camera = cv2.VideoCapture(0)
# Defining loop for catching frames
while True:
# Capture frame-by-frame from camera
_, frame_BGR = camera.read()
# Converting current frame to HSV
# Implementing Mask with founded colours from Track Bars to HSV Image
mask = cv2.inRange(frame_HSV,
(min_blue, min_green, min_red),
(max_blue, max_green, max_red))
# Showing current frame with implemented Mask
# Giving name to the window with Mask
# And specifying that window is resizable
cv2.namedWindow('Binary frame with Mask', cv2.WINDOW_NORMAL)
cv2.imshow('Binary frame with Mask', mask)
# Finding Contours
# Pay attention!
# Different versions of OpenCV returns different number of parameters
# when using function cv2.findContours()
# In OpenCV version 3 function cv2.findContours() returns three parameters:
# modified image, found Contours and hierarchy
# All found Contours from current frame are stored in the list
# Each individual Contour is a Numpy array of(x, y) coordinates
# of the boundary points of the Object
# We are interested only in Contours
# Checking if OpenCV version 3 is used
if v == '3':
_, contours, _ = cv2.findContours(mask, cv2.RETR_TREE, cv2.CHAIN_APPROX_NONE)
# In OpenCV version 4 function cv2.findContours() returns two parameters:
# found Contours and hierarchy
# Checking if OpenCV version 4 is used
else:
# Finding the biggest Contour by sorting from biggest to smallest
contours = sorted(contours, key=cv2.contourArea, reverse=True)
# Extracting Coordinates of the biggest Contour if any was found
if contours:
# Getting rectangle coordinates and spatial size from biggest Contour
# Function cv2.boundingRect() is used to get an approximate rectangle
# around the region of interest in the binary image after Contour was found
(x_min, y_min, box_width, box_height) = cv2.boundingRect(contours[0])
# Drawing Bounding Box on the current BGR frame
cv2.rectangle(frame_BGR, (x_min - 15, y_min - 15),
(x_min + box_width + 15, y_min + box_height + 15),
(0, 0, 255), 3)
# Preparing text for the Label
label = 'Detected Object'
# Putting text with Label on the current BGR frame
cv2.putText(frame_BGR, label, (x_min - 5, y_min - 25),
cv2.FONT_HERSHEY_SIMPLEX, 1.0, (0, 0, 255), 2)
# Showing current BGR frame with Detected Object
# Giving name to the window with Detected Object
cv2.namedWindow('Detected Object', cv2.WINDOW_NORMAL)
cv2.imshow('Detected Object', frame_BGR)
# Breaking the loop if 'q' is pressed
if cv2.waitKey(1) & 0xFF == ord('q'):
break
# Destroying all opened windows
cv2.destroyAllWindows()
I already checked the following things:
1.)
dlinano@jetson-nano:~$ ls -l /dev/video0
crw-rw----+ 1 root video 81, 0 Mar 21 10:56 /dev/video0
(this is fine i think)
2.)
gst-launch-1.0 nvarguscamerasrc sensor_mode=0 ! ‘video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
(everything worked fine with a good image quality)
3.)
Running the same code on my Windows 10 notebook with Spyder (python 3.6) and the notebooks onboard camera: result: everything worked fine
Someone can help me?
BR chris
