We are facing issue with fusing Jetson AGX Orin SOM.
after fusing the device , when we read back the fuses after booting system , we see reserve_odm3 to reserve_odm7 and BootSecurityInfo values are different than what we fused.
We have seen this behaviour on all units we fused.
Behaviour is consistent with Jetpack 5.1/L4T 35.2.1 + overlay patch and Jetpack 5.1.1/L4T 35.3.1
sample fuse configuration file used to fuse:
<genericfuse MagicId="0x45535546" version="1.0.0">
<fuse name="ReservedOdm3" size="4" value="0xb81cf8ce"/>
<fuse name="OdmLock" size="4" value="0xF"/>
<fuse name="ReservedOdm4" size="4" value="0x1f72062c"/>
<fuse name="BootSecurityInfo" size="4" value="0x209"/>
<fuse name="SecurityMode" size="4" value="0x1"/>
</genericfuse>
fuse command :
./odmfuse.sh -X config.xml -i 0x23 jetson-agx-orin-devkit
--- host log confirms it is using the intended fuse values from config.xml
Existing cpubl(/home/dsteam/devel/ocb/jetpack-5.1.1/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
MagicId=0x45535546 version=0x1
node: name=ReservedOdm3 size=4
value=0xb81cf8ce
node: name=OdmLock size=4
value=0xF
node: name=ReservedOdm4 size=4
value=0x1f72062c
node: name=BootSecurityInfo size=4
value=0x209
node: name=SecurityMode size=4
value=0x1
done.
size of FSKP binary 381760
size of Fuse Blob 556
File saved as fskp_t234_updated.bin
done.
root@skye-sb-cot:~# cat /sys/devices/platform/tegra-fuse/reserved_odm3
0x5d5f123e
root@skye-sb-cot:~# cat /sys/devices/platform/tegra-fuse/reserved_odm4
0xa4e6372c
root@skye-sb-cot:~# cat /sys/devices/platform/tegra-fuse/boot_security_info
0x00000000
Could you please help us understand and fix this issue.
hello vijayaca,
could you please add --test
to an odmfuse.sh
command for verification.
you may also attach the complete fuse burning logs for reference, thanks
Hi Jerry,
Attached host and target logs for fusing, removed few entries for security reason.
fuses-burning-host.log (90.5 KB)
fuses-burning-serial-uart.log (28.8 KB)
Hi Jerry,
I get below error when I run with --test on fused system .
sudo ./odmfuse.sh --test -X ../tmp_data/SKY_TEST_01-skye-fuse.xml -k ../keys/public_key0.pem -S ../keys/sbk.key -i 0x23 jetson-agx-orin-devkit
./tegraflash.py --chip 0x23 --applet "/opt/skye-installer/Linux_for_Tegra_r35.3.1/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery" --encrypt_key "/opt/skye-installer/keys/sbk.key" --key "/opt/skye-installer/keys/public_key0.pem"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0181 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0183 ] File rcm_state open failed
[ 0.0185 ] ERROR: failed to read rcm_state
[ 0.0185 ]
[ 0.0214 ] tegrasign_v3.py --key /opt/skye-installer/keys/public_key0.pem --getmode mode.txt
[ 0.0220 ] Key size is 384 bytes
[ 0.0268 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0723 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0862 ] Parsing partition layout
[ 0.0867 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0885 ] Kernel DTB used: None
[ 0.0885 ] WARNING: dce base dtb is not provided
[ 0.0885 ] Parsing partition layout
[ 0.0889 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0895 ] Creating list of images to be encrypted and signed
[ 0.0900 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml oem-rsa
[ 0.0903 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0928 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0931 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0986 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0988 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1034 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1037 ] adding BCH for mb2_t234_aligned.bin
[ 0.1066 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1188 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1190 ] adding BCH for mb2_t234_aligned.bin
File "/opt/skye-installer/Linux_for_Tegra_r35.3.1/bootloader/./tegraflash.py", line 1383, in <module>
tegraflash_run_commands()
File "/opt/skye-installer/Linux_for_Tegra_r35.3.1/bootloader/./tegraflash.py", line 1217, in tegraflash_run_commands
interpreter.onecmd(command)
File "/usr/lib/python3.10/cmd.py", line 217, in onecmd
return func(arg)
File "/opt/skye-installer/Linux_for_Tegra_r35.3.1/bootloader/./tegraflash.py", line 855, in do_dump
self.chip_inst.tegraflash_dump(exports, args)
File "/opt/skye-installer/Linux_for_Tegra_r35.3.1/bootloader/tegraflash_impl_t234.py", line 2390, in tegraflash_dump
self.tegraflash_enc_and_sign_images()
File "/opt/skye-installer/Linux_for_Tegra_r35.3.1/bootloader/tegraflash_impl_t234.py", line 1856, in tegraflash_enc_and_sign_images
for file_nodes in xml_tree.getiterator('file'):
AttributeError: 'ElementTree' object has no attribute 'getiterator'
Reading board information failed.
hello vijayaca,
FYI,
reading fuses through /sys is not supported now.
for checking, you may using dd
utility to export the fuse values.
for example, boot_security_info
$ sudo dd if=/sys/bus/nvmem/devices/fuse/nvmem of=boot_security_info bs=4 count=1 skip=$((0x5a))
and… using hexdump
to examine the values. $ hexdump -c boot_security_info
anyways,
please expect next public release will have a new tool to read fuses.
hi Jerry,
Is it new tool? which release will have the tool?
Do you know the reason for exception we getting when we run odmfuse.sh with --test on fused device?
where can I find the mapping of nvmem to read ReservedOdm fuse values?
it’s just a sample, please wait for next public Jetpack release with tool update to read fuses.
system
Closed
August 9, 2023, 1:20am
13
