Hello!
The jetson runs a dual camera program (imx219) using threading.
Example code - CSI-Camera/dual_camera.py at master · JetsonHacksNano/CSI-Camera · GitHub
It runs perfectly fine on vscode, but when I try to run it through a script I get an error which says it can’t identify the cameras.
Where the line174 in the error msg is equivalent to line 162 on the github code.
File "/home/user1/record_dual_cam_noimshow.py", line 239, in <module>
run_cameras()
File "/home/user1/record_dual_cam_noimshow.py", line 174, in run_cameras
success , left_image = left_camera.read() #ISSUE HERE
File "/path/to/record_dual_cam_noimshow.py", line 85, in read
frame = self.frame.copy()
AttributeError: 'NoneType' object has no attribute 'copy'
This is what my script file (mything.sh) looks like in /usr/local/bin
#!/bin/bash
#!/usr/bin/env python3
python3 /home/user1/record_dual_cam_noimshow.py
I also have a service file to autorun it in in /etc/systemd/system as mything.service
[Unit]
Description=mything: do my own thing
After=multi-user.target
[Service]
ExecStart=/usr/local/bin/mything.sh
StartLimitInterval=10
RestartSec=10
[Install]
WantedBy=multi-user.target
The autorun script itself works with a simple print current time program but not the opencv which is due to the system not finding the cameras which is where I am mainly stuck at.
