Issue with running setup.py after cloning NVIDIA-AI-IOT/trt_pose
Hello, I am trying to get the trt_pose_hand installed in the jetson inference container. I followed the steps on the website and all of these commands seem to work:
git clone GitHub - NVIDIA-AI-IOT/torch2trt: An easy to use PyTorch to TensorRT converter
pip3 install pillow==8.4.0
cd torch2trt
python3 setup.py install --plugins
cd …
pip3 install tqdm cython pycocotools
git clone GitHub - NVIDIA-AI-IOT/trt_pose: Real-time pose estimation accelerated with NVIDIA TensorRT
cd trt_pose
However, when I tried running this
sudo python3 setup.py install
My jetson nano froze for an extended period of time at
/jetson-inference/trt_pose/trt_pose/parse/munkres.cpp:135:31: warning: ‘min’ may be used uninitialized in this function [-Wmaybe-uninitialized]
cost_graph[i * M + j] += min;
with the ram at ~99% usage
Then it threw me this error:
FAILED: /jetson-inference/trt_pose/build/temp.linux-aarch64-3.6/trt_pose/plugins.o
c++ -MMD -MF /jetson-inference/trt_pose/build/temp.linux-aarch64-3.6/trt_pose/plugins.o.d -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/local/lib/python3.6/dist-packages/torch/include -I/usr/local/lib/python3.6/dist-packages/torch/include/torch/csrc/api/include -I/usr/local/lib/python3.6/dist-packages/torch/include/TH -I/usr/local/lib/python3.6/dist-packages/torch/include/THC -I/usr/include/python3.6m -c -c /jetson-inference/trt_pose/trt_pose/plugins.cpp -o /jetson-inference/trt_pose/build/temp.linux-aarch64-3.6/trt_pose/plugins.o -DTORCH_API_INCLUDE_EXTENSION_H ‘-DPYBIND11_COMPILER_TYPE=“_gcc”’ ‘-DPYBIND11_STDLIB=“_libstdcpp”’ ‘-DPYBIND11_BUILD_ABI=“_cxxabi1011”’ -DTORCH_EXTENSION_NAME=plugins -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
/jetson-inference/trt_pose/trt_pose/plugins.cpp: In function ‘std::vectorat::Tensor find_peaks_torch(at::Tensor, float, int, int)’:
/jetson-inference/trt_pose/trt_pose/plugins.cpp:45:13: warning: unused variable ‘H’ [-Wunused-variable]
const int H = input.size(2);
/jetson-inference/trt_pose/trt_pose/plugins.cpp:46:13: warning: unused variable ‘W’ [-Wunused-variable]
const int W = input.size(3);
/jetson-inference/trt_pose/trt_pose/plugins.cpp: In function ‘std::vectorat::Tensor connect_parts_torch(at::Tensor, at::Tensor, at::Tensor, int)’:
/jetson-inference/trt_pose/trt_pose/plugins.cpp:186:9: warning: unused variable ‘K’ [-Wunused-variable]
int K = topology.size(0);
/jetson-inference/trt_pose/trt_pose/plugins.cpp:188:9: warning: unused variable ‘M’ [-Wunused-variable]
int M = connections.size(3);
c++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-7/README.Bugs> for instructions.
[7/8] c++ -MMD -MF /jetson-inference/trt_pose/build/temp.linux-aarch64-3.6/trt_pose/train/generate_cmap.o.d -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/local/lib/python3.6/dist-packages/torch/include -I/usr/local/lib/python3.6/dist-packages/torch/include/torch/csrc/api/include -I/usr/local/lib/python3.6/dist-packages/torch/include/TH -I/usr/local/lib/python3.6/dist-packages/torch/include/THC -I/usr/include/python3.6m -c -c /jetson-inference/trt_pose/trt_pose/train/generate_cmap.cpp -o /jetson-inference/trt_pose/build/temp.linux-aarch64-3.6/trt_pose/train/generate_cmap.o -DTORCH_API_INCLUDE_EXTENSION_H ‘-DPYBIND11_COMPILER_TYPE=“_gcc”’ ‘-DPYBIND11_STDLIB=“_libstdcpp”’ ‘-DPYBIND11_BUILD_ABI=“_cxxabi1011”’ -DTORCH_EXTENSION_NAME=plugins -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
/jetson-inference/trt_pose/trt_pose/train/generate_cmap.cpp: In function ‘at::Tensor trt_pose::train::generate_cmap(at::Tensor, at::Tensor, int, int, float, int)’:
/jetson-inference/trt_pose/trt_pose/train/generate_cmap.cpp:16:9: warning: unused variable ‘M’ [-Wunused-variable]
int M = peaks.size(2);
[8/8] c++ -MMD -MF /jetson-inference/trt_pose/build/temp.linux-aarch64-3.6/trt_pose/train/generate_paf.o.d -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/local/lib/python3.6/dist-packages/torch/include -I/usr/local/lib/python3.6/dist-packages/torch/include/torch/csrc/api/include -I/usr/local/lib/python3.6/dist-packages/torch/include/TH -I/usr/local/lib/python3.6/dist-packages/torch/include/THC -I/usr/include/python3.6m -c -c /jetson-inference/trt_pose/trt_pose/train/generate_paf.cpp -o /jetson-inference/trt_pose/build/temp.linux-aarch64-3.6/trt_pose/train/generate_paf.o -DTORCH_API_INCLUDE_EXTENSION_H ‘-DPYBIND11_COMPILER_TYPE=“_gcc”’ ‘-DPYBIND11_STDLIB=“_libstdcpp”’ ‘-DPYBIND11_BUILD_ABI=“_cxxabi1011”’ -DTORCH_EXTENSION_NAME=plugins -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
ninja: build stopped: subcommand failed.
File “/usr/local/lib/python3.6/dist-packages/torch/utils/cpp_extension.py”, line 1723, in _run_ninja_build
env=env)
File “/usr/lib/python3.6/subprocess.py”, line 438, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command ‘[‘ninja’, ‘-v’]’ returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File “setup.py”, line 28, in
install_requires=[
File “/usr/local/lib/python3.6/dist-packages/setuptools/init.py”, line 153, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.6/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.6/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.6/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install.py”, line 74, in run
self.do_egg_install()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install.py”, line 116, in do_egg_install
self.run_command(‘bdist_egg’)
File “/usr/lib/python3.6/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/bdist_egg.py”, line 164, in run
cmd = self.call_command(‘install_lib’, warn_dir=0)
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/bdist_egg.py”, line 150, in call_command
self.run_command(cmdname)
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install_lib.py”, line 11, in run
self.build()
File “/usr/lib/python3.6/distutils/command/install_lib.py”, line 109, in build
self.run_command(‘build_ext’)
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/build_ext.py”, line 79, in run
_build_ext.run(self)
File “/usr/local/lib/python3.6/dist-packages/Cython/Distutils/old_build_ext.py”, line 186, in run
_build_ext.build_ext.run(self)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 339, in run
self.build_extensions()
File “/usr/local/lib/python3.6/dist-packages/torch/utils/cpp_extension.py”, line 735, in build_extensions
build_ext.build_extensions(self)
File “/usr/local/lib/python3.6/dist-packages/Cython/Distutils/old_build_ext.py”, line 195, in build_extensions
_build_ext.build_ext.build_extensions(self)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 448, in build_extensions
self._build_extensions_serial()
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 473, in _build_extensions_serial
self.build_extension(ext)
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/build_ext.py”, line 202, in build_extension
_build_ext.build_extension(self, ext)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 533, in build_extension
depends=ext.depends)
File “/usr/local/lib/python3.6/dist-packages/torch/utils/cpp_extension.py”, line 565, in unix_wrap_ninja_compile
with_cuda=with_cuda)
File “/usr/local/lib/python3.6/dist-packages/torch/utils/cpp_extension.py”, line 1404, in _write_ninja_file_and_compile_objects
error_prefix=‘Error compiling objects for extension’)
File “/usr/local/lib/python3.6/dist-packages/torch/utils/cpp_extension.py”, line 1733, in _run_ninja_build
raise RuntimeError(message) from e
RuntimeError: Error compiling objects for extension
Killed usually indicates running out of memory.
Could you add some swap and install it again?
