Issue with Sending Custom Events Using Python
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• Issue Type( questions, new requirements, bugs) questions
I am working on dynamically changing the inference interval of nvinfer using Python and have encountered some challenges.
I referred to the latest documentation on how to send custom events from Python to downstream elements (link). I’m trying to apply this to the function gst_nvevent_infer_interval_update located at /opt/nvidia/deepstream/deepstream-7.0/sources/libs/gstnvdscustomhelper/gst-nvdscustomevent.c.
I successfully obtained the Python bindings on my x86 machine and followed an implementation similar to what was suggested in this forum post (link), implementing it identically in bindfunctions.cpp.
However, I am unsure how to use this bound function in Python. When calling the function, the size_t gst_element in C++ corresponds to an int in Python, but I can only obtain the Python object corresponding to pgie.
What should I pass in Python? Does this int value correspond to the address of pgie in C++? The function in the documentation example seems to have the same issue. Is there an official implementation or recommended usage? I need a Python usage example, not just a binding example.
pyds-1.1.11-py3-none-linux_x86_64.zip (602.6 KB)
Can an implementation be made based on deepstream-test1?
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2019-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import threading
import sys
sys.path.append('../')
import os
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from common.platform_info import PlatformInfo
from common.bus_call import bus_call
import pyds
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_BATCH_TIMEOUT_USEC = 33000
def osd_sink_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    num_rects=0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
            #source_id = frame_meta.source_id
            #print("source_id: ", source_id)
        except StopIteration:
            break
        #Intiallizing object counter with 0.
        obj_counter = {
            PGIE_CLASS_ID_VEHICLE:0,
            PGIE_CLASS_ID_PERSON:0,
            PGIE_CLASS_ID_BICYCLE:0,
            PGIE_CLASS_ID_ROADSIGN:0
        frame_number=frame_meta.frame_num
        num_rects = frame_meta.num_obj_meta
        l_obj=frame_meta.obj_meta_list
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            obj_counter[obj_meta.class_id] += 1
            obj_meta.rect_params.border_color.set(0.0, 0.0, 1.0, 0.8) #0.8 is alpha (opacity)
            try:
                l_obj=l_obj.next
                break
        # Acquiring a display meta object. The memory ownership remains in
        # the C code so downstream plugins can still access it. Otherwise
        # the garbage collector will claim it when this probe function exits.
        display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        # Setting display text to be shown on screen
        # Note that the pyds module allocates a buffer for the string, and the
        # memory will not be claimed by the garbage collector.
        # Reading the display_text field here will return the C address of the
        # allocated string. Use pyds.get_string() to get the string content.
        py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_VEHICLE], obj_counter[PGIE_CLASS_ID_PERSON])
        # Now set the offsets where the string should appear
        py_nvosd_text_params.x_offset = 10
        py_nvosd_text_params.y_offset = 12
        # Font , font-color and font-size
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        # set(red, green, blue, alpha); set to White
        py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
        # Text background color
        py_nvosd_text_params.set_bg_clr = 1
        # set(red, green, blue, alpha); set to Black
        py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
        # Using pyds.get_string() to get display_text as string
        print(pyds.get_string(py_nvosd_text_params.display_text))
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
def callback():
    global pgie
    interval = 10
    pyds.gst_element_send_nvevent_interval_update(pgie, '0', interval)
def main(args):
    global pgie
    # Check input arguments
    if len(args) != 2:
        sys.stderr.write("usage: %s <media file or uri>\n" % args[0])
        sys.exit(1)
    platform_info = PlatformInfo()
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    # Source element for reading from the file
    print("Creating Source \n ")
    source = Gst.ElementFactory.make("filesrc", "file-source")
    if not source:
        sys.stderr.write(" Unable to create Source \n")
    # Since the data format in the input file is elementary h264 stream,
    # we need a h264parser
    print("Creating H264Parser \n")
    h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
    if not h264parser:
        sys.stderr.write(" Unable to create h264 parser \n")
    # Use nvdec_h264 for hardware accelerated decode on GPU
    print("Creating Decoder \n")
    decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
    if not decoder:
        sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    # Use nvinfer to run inferencing on decoder's output,
    # behaviour of inferencing is set through config file
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    # Use convertor to convert from NV12 to RGBA as required by nvosd
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    # Create OSD to draw on the converted RGBA buffer
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    # Finally render the osd output
    if platform_info.is_integrated_gpu():
        print("Creating nv3dsink \n")
        sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
        if not sink:
            sys.stderr.write(" Unable to create nv3dsink \n")
    else:
        if platform_info.is_platform_aarch64():
        else:
            print("Creating EGLSink \n")
            sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
        if not sink:
            sys.stderr.write(" Unable to create egl sink \n")
    print("Playing file %s " %args[1])
    source.set_property('location', args[1])
    if os.environ.get('USE_NEW_NVSTREAMMUX') != 'yes': # Only set these properties if not using new gst-nvstreammux
        streammux.set_property('width', 1920)
        streammux.set_property('height', 1080)
        streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
    streammux.set_property('batch-size', 1)
    pgie.set_property('config-file-path', "dstest1_pgie_config.txt")
    print("Adding elements to Pipeline \n")
    pipeline.add(source)
    pipeline.add(h264parser)
    pipeline.add(decoder)
    pipeline.add(streammux)
    pipeline.add(pgie)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(sink)
    # we link the elements together
    # file-source -> h264-parser -> nvh264-decoder ->
    # nvinfer -> nvvidconv -> nvosd -> video-renderer
    print("Linking elements in the Pipeline \n")
    source.link(h264parser)
    h264parser.link(decoder)
    sinkpad = streammux.request_pad_simple("sink_0")
    if not sinkpad:
        sys.stderr.write(" Unable to get the sink pad of streammux \n")
    srcpad = decoder.get_static_pad("src")
    if not srcpad:
        sys.stderr.write(" Unable to get source pad of decoder \n")
    srcpad.link(sinkpad)
    streammux.link(pgie)
    pgie.link(nvvidconv)
    nvvidconv.link(nvosd)
    nvosd.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    # Lets add probe to get informed of the meta data generated, we add probe to
    # the sink pad of the osd element, since by that time, the buffer would have
    # had got all the metadata.
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        sys.stderr.write(" Unable to get sink pad of nvosd \n")
    osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
    # start play back and listen to events
    print("Starting pipeline \n")
    pipeline.set_state(Gst.State.PLAYING)
    t = threading.Timer(10, callback)
    t.start()
    try:
        loop.run()
    except:
        pass
    # cleanup
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    sys.exit(main(sys.argv))
cmd:
/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1$ python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-7.0/samples/streams/sample_720p.h264
I am getting an error:
Frame Number=284 Number of Objects=29 Vehicle_count=24 Person_count=5
Frame Number=285 Number of Objects=28 Vehicle_count=22 Person_count=6
Exception in thread Thread-1:
  File "/usr/lib/python3.10/threading.py", line 1016, in _bootstrap_inner
    self.run()
  File "/usr/lib/python3.10/threading.py", line 1378, in run
    self.function(*self.args, **self.kwargs)
  File "/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/deepstream_test_1.py", line 134, in callback
TypeError: gst_element_send_nvevent_interval_update(): incompatible function arguments. The following argument types are supported:
    1. (arg0: int, arg1: str, arg2: int) -> int
Invoked with: <__gi__.GstNvInfer object at 0x7f59f818e5c0 (GstNvInfer at 0x55e9edc47ad0)>, '0', 10
Frame Number=286 Number of Objects=28 Vehicle_count=23 Person_count=5
Frame Number=287 Number of Objects=30 Vehicle_count=24 Person_count=6
This is a complex problem, involving pygobject and GIL.
For more information about Python’s meta function hash, please refer to the following link
Details of GIL
I will give some sample patchs, I have tried them in DS-7.0, they can work.
for deepstream_test_1.py
diff --git a/apps/deepstream-test1/deepstream_test_1.py b/apps/deepstream-test1/deepstream_test_1.py
index 1367fb4..8ff4f6f 100755
--- a/apps/deepstream-test1/deepstream_test_1.py
+++ b/apps/deepstream-test1/deepstream_test_1.py
@@ -18,6 +18,7 @@
 import sys
+import threading
 import os
 import gi
@@ -68,6 +69,8 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
+        source_id = frame_meta.source_id
+        print("source_id: ", source_id)
             try:
@@ -119,8 +122,15 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
+def callback():
+    global pgie
+    interval = 13
+    print(f"Send NvDsEventIntervalUpdate type {pgie.__class__} {hash(pgie)}")
+    pyds.gst_element_send_nvevent_interval_update(hash(pgie), '0', interval)
+    return True
 def main(args):
+    global pgie
     if len(args) != 2:
@@ -191,7 +201,8 @@ def main(args):
         else:
-            sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
+            sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
+            sink.set_property('sync', True)
         if not sink:
@@ -252,6 +263,11 @@ def main(args):
+    GLib.timeout_add(5000, callback)
+    # t = threading.Timer(5, callback)
+    # t.start()
     try:
         loop.run()
     except:
for the python bindings.
diff --git a/bindings/CMakeLists.txt b/bindings/CMakeLists.txt
index 7b01fb2..abe5042 100644
--- a/bindings/CMakeLists.txt
+++ b/bindings/CMakeLists.txt
@@ -98,7 +98,7 @@ function(add_ds_lib libname)
         target_link_libraries(pyds ${libname})
 endfunction()
-foreach(nvds_lib nvds_osd nvds_meta nvds_infer nvdsgst_meta nvbufsurface nvbufsurftransform nvdsgst_helper)
+foreach(nvds_lib nvds_osd nvds_meta nvds_infer nvdsgst_meta nvbufsurface nvbufsurftransform nvdsgst_helper nvdsgst_customhelper)
         add_ds_lib(${nvds_lib})
 endforeach()
diff --git a/bindings/src/bindfunctions.cpp b/bindings/src/bindfunctions.cpp
index cc2c9cc..6879e04 100644
--- a/bindings/src/bindfunctions.cpp
+++ b/bindings/src/bindfunctions.cpp
@@ -17,6 +17,7 @@
 #include "bind_string_property_definitions.h"
 #include "bindfunctions.hpp"
+#include "gst-nvdscustomevent.h"
 namespace py = pybind11;
 using namespace std;
@@ -797,6 +798,20 @@ namespace pydeepstream {
               pydsdoc::methodsDoc::gst_element_send_nvevent_new_stream_reset);
+        m.def("gst_element_send_nvevent_interval_update",
+            [](size_t gst_element, char* stream_id, int interval) {
+                  bool ret = false;
+                  auto *element = reinterpret_cast<GstElement *>(gst_element);
+                  auto *event = gst_nvevent_infer_interval_update(stream_id, interval);
+                  std::cout << "Reached gst_nvevent_infer_interval_update " << element << std::endl;
+                  Py_BEGIN_ALLOW_THREADS;
+                  ret = gst_element_send_event(element, event);
+                  Py_END_ALLOW_THREADS;
+                  std::cout << "Reached gst_element_send_nvevent_interval_update " << ret << std::endl;
+                  return ret;
+            "pydsdoc::methodsDoc::gst_element_send_nvevent_interval_update");
Great job! That was a perfect answer. I believe your response will be helpful to many others as well. Thank you very much for your insightful contribution!
I hope I can ask an additional question: Why does the documentation not consider the GIL issue for the binding of gst_nvevent_new_stream_reset , whereas gst_nvevent_infer_interval_update must take it into account? The difference in handling here is confusing to me.
In fact, this is a case by case bindings. Depending on the specific needs, gst_nvevent_infer_interval_update may cause blocking so that the GIL needs to be explicitly released.
Got it, thank you once again for your detailed answer.
