Hi, maybe instead present myself, (I’m on this forum about few minutes, Debian also know from yesterday) I am try to present my problem.
Well, I decided to install Linux. The choice fell on unless of course the most known of this system - Debian (Wheezy). So, my problem is that, after doing all of this guide, Wheezy, and more specifically the nVidia driver set the screen resolution 1368x768 instead of 1366x768.
Below I’m put the xorg logs from start the computer, maybe they can help.
Xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 304.48 (buildd@murphy) Wed Sep 12 11:32:28 UTC 2012
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Xorg.0.log:
[ 27.734]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 27.734] X Protocol Version 11, Revision 0
[ 27.734] Build Operating System: Linux 2.6.32-5-amd64 i686 Debian
[ 27.734] Current Operating System: Linux user31-231 3.2.0-4-686-pae #1 SMP Debian 3.2.35-2 i686
[ 27.734] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-686-pae root=UUID=fa3a2ec7-1f4d-46a0-8866-9d5e295cd786 ro quiet
[ 27.734] Build Date: 29 November 2012 08:52:43PM
[ 27.734] xorg-server 2:1.12.4-4 (Julien Cristau )
[ 27.734] Current version of pixman: 0.26.0
[ 27.734] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 27.734] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 27.734] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 6 20:27:39 2013
[ 27.754] (==) Using config file: "/etc/X11/xorg.conf"
[ 27.754] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 27.780] (==) ServerLayout "Layout0"
[ 27.780] (**) |-->Screen "Screen0" (0)
[ 27.780] (**) | |-->Monitor "Monitor0"
[ 27.792] (**) | |-->Device "Device0"
[ 27.792] (**) |-->Input Device "Keyboard0"
[ 27.793] (**) |-->Input Device "Mouse0"
[ 27.793] (==) Automatically adding devices
[ 27.793] (==) Automatically enabling devices
[ 27.827] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 27.827] Entry deleted from font path.
[ 27.856] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 27.856] Entry deleted from font path.
[ 27.856] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 27.857] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 27.857] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 27.857] (WW) Disabling Keyboard0
[ 27.857] (WW) Disabling Mouse0
[ 27.857] (II) Loader magic: 0xb770d5a0
[ 27.857] (II) Module ABI versions:
[ 27.857] X.Org ANSI C Emulation: 0.4
[ 27.857] X.Org Video Driver: 12.1
[ 27.857] X.Org XInput driver : 16.0
[ 27.857] X.Org Server Extension : 6.0
[ 27.858] (--) PCI:*(0:1:0:0) 10de:00f1:1682:2119 rev 162, Mem @ 0xfa000000/16777216, 0xe0000000/268435456, 0xfb000000/16777216, BIOS @ 0x????????/131072
[ 27.858] (II) Open ACPI successful (/var/run/acpid.socket)
[ 27.858] (II) LoadModule: "extmod"
[ 27.979] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 27.994] (II) Module extmod: vendor="X.Org Foundation"
[ 27.994] compiled for 1.12.4, module version = 1.0.0
[ 27.994] Module class: X.Org Server Extension
[ 27.994] ABI class: X.Org Server Extension, version 6.0
[ 27.994] (II) Loading extension SELinux
[ 27.994] (II) Loading extension MIT-SCREEN-SAVER
[ 27.994] (II) Loading extension XFree86-VidModeExtension
[ 27.994] (II) Loading extension XFree86-DGA
[ 27.994] (II) Loading extension DPMS
[ 27.994] (II) Loading extension XVideo
[ 27.994] (II) Loading extension XVideo-MotionCompensation
[ 27.994] (II) Loading extension X-Resource
[ 27.994] (II) LoadModule: "dbe"
[ 27.995] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 28.011] (II) Module dbe: vendor="X.Org Foundation"
[ 28.011] compiled for 1.12.4, module version = 1.0.0
[ 28.011] Module class: X.Org Server Extension
[ 28.011] ABI class: X.Org Server Extension, version 6.0
[ 28.011] (II) Loading extension DOUBLE-BUFFER
[ 28.011] (II) LoadModule: "glx"
[ 28.011] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[ 29.462] (II) Module glx: vendor="NVIDIA Corporation"
[ 29.462] compiled for 4.0.2, module version = 1.0.0
[ 29.462] Module class: X.Org Server Extension
[ 29.462] (II) NVIDIA GLX Module 304.64 Tue Oct 30 11:31:18 PDT 2012
[ 29.462] (II) Loading extension GLX
[ 29.462] (II) LoadModule: "record"
[ 29.463] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 29.520] (II) Module record: vendor="X.Org Foundation"
[ 29.520] compiled for 1.12.4, module version = 1.13.0
[ 29.520] Module class: X.Org Server Extension
[ 29.520] ABI class: X.Org Server Extension, version 6.0
[ 29.520] (II) Loading extension RECORD
[ 29.520] (II) LoadModule: "dri"
[ 29.520] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 29.533] (II) Module dri: vendor="X.Org Foundation"
[ 29.533] compiled for 1.12.4, module version = 1.0.0
[ 29.533] ABI class: X.Org Server Extension, version 6.0
[ 29.533] (II) Loading extension XFree86-DRI
[ 29.533] (II) LoadModule: "dri2"
[ 29.533] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 29.534] (II) Module dri2: vendor="X.Org Foundation"
[ 29.534] compiled for 1.12.4, module version = 1.2.0
[ 29.534] ABI class: X.Org Server Extension, version 6.0
[ 29.534] (II) Loading extension DRI2
[ 29.534] (II) LoadModule: "nvidia"
[ 29.535] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 29.609] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 29.609] compiled for 4.0.2, module version = 1.0.0
[ 29.609] Module class: X.Org Video Driver
[ 29.913] (II) NVIDIA dlloader X Driver 304.64 Tue Oct 30 11:11:05 PDT 2012
[ 29.913] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 29.945] (++) using VT number 7
[ 29.987] (II) Loading sub module "fb"
[ 29.987] (II) LoadModule: "fb"
[ 29.988] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 30.014] (II) Module fb: vendor="X.Org Foundation"
[ 30.014] compiled for 1.12.4, module version = 1.0.0
[ 30.014] ABI class: X.Org ANSI C Emulation, version 0.4
[ 30.014] (II) Loading sub module "wfb"
[ 30.014] (II) LoadModule: "wfb"
[ 30.014] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 30.031] (II) Module wfb: vendor="X.Org Foundation"
[ 30.031] compiled for 1.12.4, module version = 1.0.0
[ 30.031] ABI class: X.Org ANSI C Emulation, version 0.4
[ 30.031] (II) Loading sub module "ramdac"
[ 30.031] (II) LoadModule: "ramdac"
[ 30.031] (II) Module "ramdac" already built-in
[ 30.102] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 30.102] (==) NVIDIA(0): RGB weight 888
[ 30.102] (==) NVIDIA(0): Default visual is TrueColor
[ 30.102] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 30.103] (**) NVIDIA(0): Enabling 2D acceleration
[ 31.594] (II) NVIDIA(GPU-0): Display (BenQ G925HDA (CRT-0)) does not support NVIDIA 3D
[ 31.594] (II) NVIDIA(GPU-0): Vision stereo.
[ 31.621] (II) NVIDIA(0): NVIDIA GPU GeForce 6600 GT (NV43) at PCI:1:0:0 (GPU-0)
[ 31.621] (--) NVIDIA(0): Memory: 131072 kBytes
[ 31.621] (--) NVIDIA(0): VideoBIOS: 05.43.02.36.00
[ 31.621] (II) NVIDIA(0): Detected AGP rate: 8X
[ 31.621] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[ 31.621] (--) NVIDIA(0): Valid display device(s) on GeForce 6600 GT at PCI:1:0:0
[ 31.622] (--) NVIDIA(0): BenQ G925HDA (CRT-0) (connected)
[ 31.622] (--) NVIDIA(0): CRT-1
[ 31.622] (--) NVIDIA(0): TV-0
[ 31.622] (--) NVIDIA(0): DFP-0
[ 31.622] (--) NVIDIA(0): DFP-1
[ 31.622] (--) NVIDIA(0): BenQ G925HDA (CRT-0): 400.0 MHz maximum pixel clock
[ 31.622] (--) NVIDIA(0): CRT-1: 400.0 MHz maximum pixel clock
[ 31.622] (--) NVIDIA(0): TV-0: 400.0 MHz maximum pixel clock
[ 31.622] (--) NVIDIA(0): TV encoder: (null)
[ 31.622] (--) NVIDIA(0): DFP-0: 155.0 MHz maximum pixel clock
[ 31.622] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 31.622] (--) NVIDIA(0): DFP-1: 155.0 MHz maximum pixel clock
[ 31.622] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 31.622] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 31.622] (**) NVIDIA(0): device BenQ G925HDA (CRT-0) (Using EDID frequencies has
[ 31.622] (**) NVIDIA(0): been enabled on all display devices.)
[ 31.622] (==) NVIDIA(0):
[ 31.622] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 31.622] (==) NVIDIA(0): will be used as the requested mode.
[ 31.623] (II) NVIDIA(0): Validated MetaModes:
[ 31.623] (II) NVIDIA(0): "CRT-0:nvidia-auto-select"
[ 31.623] (II) NVIDIA(0): Virtual screen size determined to be 1368 x 768
[ 31.624] (WW) NVIDIA(0): Unable to support custom viewPortOut 1365 x 768 +1 +0
[ 31.625] (--) NVIDIA(0): DPI set to (84, 84); computed from "UseEdidDpi" X config
[ 31.625] (--) NVIDIA(0): option
[ 31.625] (--) Depth 24 pixmap format is 32 bpp
[ 31.634] (II) NVIDIA(0): Setting mode "CRT-0:nvidia-auto-select"
[ 31.736] (II) Loading extension NV-GLX
[ 31.802] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 31.802] (==) NVIDIA(0): Backing store disabled
[ 31.802] (==) NVIDIA(0): Silken mouse enabled
[ 31.802] (**) NVIDIA(0): DPMS enabled
[ 31.802] (II) Loading extension NV-CONTROL
[ 31.803] (II) Loading extension XINERAMA
[ 31.803] (II) Loading sub module "dri2"
[ 31.803] (II) LoadModule: "dri2"
[ 31.803] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 31.803] (II) Module dri2: vendor="X.Org Foundation"
[ 31.803] compiled for 1.12.4, module version = 1.2.0
[ 31.803] ABI class: X.Org Server Extension, version 6.0
[ 31.803] (II) NVIDIA(0): [DRI2] Setup complete
[ 31.804] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 31.804] (--) RandR disabled
[ 31.804] (II) Initializing built-in extension Generic Event Extension
[ 31.804] (II) Initializing built-in extension SHAPE
[ 31.804] (II) Initializing built-in extension MIT-SHM
[ 31.804] (II) Initializing built-in extension XInputExtension
[ 31.804] (II) Initializing built-in extension XTEST
[ 31.804] (II) Initializing built-in extension BIG-REQUESTS
[ 31.804] (II) Initializing built-in extension SYNC
[ 31.804] (II) Initializing built-in extension XKEYBOARD
[ 31.804] (II) Initializing built-in extension XC-MISC
[ 31.804] (II) Initializing built-in extension SECURITY
[ 31.804] (II) Initializing built-in extension XINERAMA
[ 31.804] (II) Initializing built-in extension XFIXES
[ 31.804] (II) Initializing built-in extension RENDER
[ 31.804] (II) Initializing built-in extension RANDR
[ 31.804] (II) Initializing built-in extension COMPOSITE
[ 31.804] (II) Initializing built-in extension DAMAGE
[ 31.804] (II) SELinux: Disabled on system
[ 31.809] (II) Initializing extension GLX
[ 32.166] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[ 32.166] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 32.166] (II) LoadModule: "evdev"
[ 32.167] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 32.180] (II) Module evdev: vendor="X.Org Foundation"
[ 32.180] compiled for 1.12.1, module version = 2.7.0
[ 32.180] Module class: X.Org XInput Driver
[ 32.180] ABI class: X.Org XInput driver, version 16.0
[ 32.180] (II) Using input driver 'evdev' for 'Power Button'
[ 32.180] (**) Power Button: always reports core events
[ 32.180] (**) evdev: Power Button: Device: "/dev/input/event5"
[ 32.180] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 32.180] (--) evdev: Power Button: Found keys
[ 32.180] (II) evdev: Power Button: Configuring as keyboard
[ 32.180] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input5/event5"
[ 32.180] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 32.180] (**) Option "xkb_rules" "evdev"
[ 32.181] (**) Option "xkb_model" "pc105"
[ 32.181] (**) Option "xkb_layout" "pl"
[ 32.229] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 32.229] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 32.229] (II) Using input driver 'evdev' for 'Power Button'
[ 32.229] (**) Power Button: always reports core events
[ 32.229] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 32.229] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 32.229] (--) evdev: Power Button: Found keys
[ 32.229] (II) evdev: Power Button: Configuring as keyboard
[ 32.229] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input3/event3"
[ 32.229] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 32.229] (**) Option "xkb_rules" "evdev"
[ 32.229] (**) Option "xkb_model" "pc105"
[ 32.230] (**) Option "xkb_layout" "pl"
[ 32.230] (II) config/udev: Adding input device Sleep Button (/dev/input/event4)
[ 32.230] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 32.231] (II) Using input driver 'evdev' for 'Sleep Button'
[ 32.231] (**) Sleep Button: always reports core events
[ 32.231] (**) evdev: Sleep Button: Device: "/dev/input/event4"
[ 32.231] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 32.231] (--) evdev: Sleep Button: Found keys
[ 32.231] (II) evdev: Sleep Button: Configuring as keyboard
[ 32.231] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input4/event4"
[ 32.231] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 32.231] (**) Option "xkb_rules" "evdev"
[ 32.231] (**) Option "xkb_model" "pc105"
[ 32.231] (**) Option "xkb_layout" "pl"
[ 32.232] (II) config/udev: Adding input device USB USB Keykoard (/dev/input/event0)
[ 32.232] (**) USB USB Keykoard: Applying InputClass "evdev keyboard catchall"
[ 32.232] (II) Using input driver 'evdev' for 'USB USB Keykoard'
[ 32.232] (**) USB USB Keykoard: always reports core events
[ 32.232] (**) evdev: USB USB Keykoard: Device: "/dev/input/event0"
[ 32.232] (--) evdev: USB USB Keykoard: Vendor 0x1a2c Product 0x23
[ 32.232] (--) evdev: USB USB Keykoard: Found keys
[ 32.232] (II) evdev: USB USB Keykoard: Configuring as keyboard
[ 32.232] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:10.0/usb2/2-1/2-1:1.0/input/input0/event0"
[ 32.232] (II) XINPUT: Adding extended input device "USB USB Keykoard" (type: KEYBOARD, id 9)
[ 32.232] (**) Option "xkb_rules" "evdev"
[ 32.232] (**) Option "xkb_model" "pc105"
[ 32.232] (**) Option "xkb_layout" "pl"
[ 32.233] (II) config/udev: Adding input device USB USB Keykoard (/dev/input/event1)
[ 32.233] (**) USB USB Keykoard: Applying InputClass "evdev keyboard catchall"
[ 32.233] (II) Using input driver 'evdev' for 'USB USB Keykoard'
[ 32.234] (**) USB USB Keykoard: always reports core events
[ 32.234] (**) evdev: USB USB Keykoard: Device: "/dev/input/event1"
[ 32.234] (--) evdev: USB USB Keykoard: Vendor 0x1a2c Product 0x23
[ 32.234] (--) evdev: USB USB Keykoard: Found 1 mouse buttons
[ 32.234] (--) evdev: USB USB Keykoard: Found scroll wheel(s)
[ 32.234] (--) evdev: USB USB Keykoard: Found relative axes
[ 32.234] (II) evdev: USB USB Keykoard: Forcing relative x/y axes to exist.
[ 32.234] (--) evdev: USB USB Keykoard: Found absolute axes
[ 32.234] (II) evdev: USB USB Keykoard: Forcing absolute x/y axes to exist.
[ 32.234] (--) evdev: USB USB Keykoard: Found keys
[ 32.234] (II) evdev: USB USB Keykoard: Configuring as mouse
[ 32.234] (II) evdev: USB USB Keykoard: Configuring as keyboard
[ 32.234] (II) evdev: USB USB Keykoard: Adding scrollwheel support
[ 32.234] (**) evdev: USB USB Keykoard: YAxisMapping: buttons 4 and 5
[ 32.234] (**) evdev: USB USB Keykoard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 32.234] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:10.0/usb2/2-1/2-1:1.1/input/input1/event1"
[ 32.234] (II) XINPUT: Adding extended input device "USB USB Keykoard" (type: KEYBOARD, id 10)
[ 32.234] (**) Option "xkb_rules" "evdev"
[ 32.234] (**) Option "xkb_model" "pc105"
[ 32.234] (**) Option "xkb_layout" "pl"
[ 32.234] (II) evdev: USB USB Keykoard: initialized for relative axes.
[ 32.235] (WW) evdev: USB USB Keykoard: ignoring absolute axes.
[ 32.235] (**) USB USB Keykoard: (accel) keeping acceleration scheme 1
[ 32.235] (**) USB USB Keykoard: (accel) acceleration profile 0
[ 32.235] (**) USB USB Keykoard: (accel) acceleration factor: 2.000
[ 32.235] (**) USB USB Keykoard: (accel) acceleration threshold: 4
[ 32.236] (II) config/udev: Adding input device USB Mouse (/dev/input/event2)
[ 32.236] (**) USB Mouse : Applying InputClass "evdev pointer catchall"
[ 32.236] (II) Using input driver 'evdev' for 'USB Mouse '
[ 32.236] (**) USB Mouse : always reports core events
[ 32.236] (**) evdev: USB Mouse : Device: "/dev/input/event2"
[ 32.236] (--) evdev: USB Mouse : Vendor 0x5e3 Product 0x1205
[ 32.236] (--) evdev: USB Mouse : Found 9 mouse buttons
[ 32.236] (--) evdev: USB Mouse : Found scroll wheel(s)
[ 32.236] (--) evdev: USB Mouse : Found relative axes
[ 32.236] (--) evdev: USB Mouse : Found x and y relative axes
[ 32.236] (II) evdev: USB Mouse : Configuring as mouse
[ 32.236] (II) evdev: USB Mouse : Adding scrollwheel support
[ 32.236] (**) evdev: USB Mouse : YAxisMapping: buttons 4 and 5
[ 32.236] (**) evdev: USB Mouse : EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 32.236] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.0/input/input2/event2"
[ 32.236] (II) XINPUT: Adding extended input device "USB Mouse " (type: MOUSE, id 11)
[ 32.236] (II) evdev: USB Mouse : initialized for relative axes.
[ 32.237] (**) USB Mouse : (accel) keeping acceleration scheme 1
[ 32.237] (**) USB Mouse : (accel) acceleration profile 0
[ 32.237] (**) USB Mouse : (accel) acceleration factor: 2.000
[ 32.237] (**) USB Mouse : (accel) acceleration threshold: 4
[ 32.237] (II) config/udev: Adding input device USB Mouse (/dev/input/mouse0)
[ 32.237] (II) No input driver specified, ignoring this device.
[ 32.237] (II) This device may have been added with another device file.
[ 32.238] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 32.238] (II) No input driver specified, ignoring this device.
[ 32.238] (II) This device may have been added with another device file.
[ 32.432] (II) NVIDIA(GPU-0): Display (BenQ G925HDA (CRT-0)) does not support NVIDIA 3D
[ 32.433] (II) NVIDIA(GPU-0): Vision stereo.
[ 32.433] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 32.433] (**) NVIDIA(0): device BenQ G925HDA (CRT-0) (Using EDID frequencies has
[ 32.433] (**) NVIDIA(0): been enabled on all display devices.)
[ 35.361] (II) NVIDIA(GPU-0): Display (BenQ G925HDA (CRT-0)) does not support NVIDIA 3D
[ 35.361] (II) NVIDIA(GPU-0): Vision stereo.
[ 35.361] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 35.361] (**) NVIDIA(0): device BenQ G925HDA (CRT-0) (Using EDID frequencies has
[ 35.361] (**) NVIDIA(0): been enabled on all display devices.)
[ 47.698] (II) NVIDIA(GPU-0): Display (BenQ G925HDA (CRT-0)) does not support NVIDIA 3D
[ 47.698] (II) NVIDIA(GPU-0): Vision stereo.
[ 47.698] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 47.698] (**) NVIDIA(0): device BenQ G925HDA (CRT-0) (Using EDID frequencies has
[ 47.698] (**) NVIDIA(0): been enabled on all display devices.)
[ 50.146] (II) NVIDIA(GPU-0): Display (BenQ G925HDA (CRT-0)) does not support NVIDIA 3D
[ 50.146] (II) NVIDIA(GPU-0): Vision stereo.
[ 50.146] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 50.146] (**) NVIDIA(0): device BenQ G925HDA (CRT-0) (Using EDID frequencies has
[ 50.146] (**) NVIDIA(0): been enabled on all display devices.)
[ 52.307] (II) NVIDIA(GPU-0): Display (BenQ G925HDA (CRT-0)) does not support NVIDIA 3D
[ 52.307] (II) NVIDIA(GPU-0): Vision stereo.
[ 52.307] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 52.307] (**) NVIDIA(0): device BenQ G925HDA (CRT-0) (Using EDID frequencies has
[ 52.307] (**) NVIDIA(0): been enabled on all display devices.)
How can I fix my problem?
