Hello shgarg,
Thanks for your reply.
My purpose is to use CAN bus module in SPE. My platform is Jetson AGX Xavier.
I did as what you said, but there still some unknown issues.
To make it clear, I want to describe what I did step by step.
step 1: I modified the device tree tegra194-p2888-0001-p2822-0000-common.dtsi in the path ~/public_sources/Linux_for_Tegra/source/public/kernel_src/hardware/nvidia/platform/t19x/galen/kernel-dts/common
mttcan@c310000 {
status = “disabled”;
mttcan@c320000 {
step 2: I compiled the source and got the output files.
step 3: I replaced the files in the release ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel as below:
–> Replace <release_packagep>/Linux_for_Tegra/kernel/Image with a copy of:
$TEGRA_KERNEL_OUT/arch/arm64/boot/Image
–> Replace the contents of Linux_for_Tegra/kernel/dtb/ with the contents of:
$TEGRA_KERNEL_OUT/arch/arm64/boot/dts/
step 4: I modified the SCR setting tegra194-mb1-bct-scr-cbb-mini.cfg in release ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT as below:
scr.378.4 = 0x1a0034ff; # CLK_RST_CONTROLLER_AON_SCR_CAN_0
scr.407.4 = 0x1a0034ff; # CLK_RST_CONTROLLER_CAN1_SCR_FMON_0
scr.408.4 = 0x1a0034ff; # CLK_RST_CONTROLLER_CAN2_SCR_FMON_0
scr.2602.6 = 0x19003232; # AON_NOC_CAN1_BLF_CONTROL_REGISTER_0
scr.2603.6 = 0x19003232; # AON_NOC_CAN2_BLF_CONTROL_REGISTER_0
step 5: I modified the pinmux setting tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg in release ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT as below:
pinmux.0x0c303000 = 0x00000400; # can1_dout_paa0: rsvd1, pull-down, tristate-enable, input-enable
pinmux.0x0c303008 = 0x00000458; # can1_din_paa1: rsvd1, pull-down, tristate-enable, input-enable
pinmux.0x0c303010 = 0x00000400; # can0_dout_paa2: rsvd1, pull-up, tristate-enable, input-enable
pinmux.0x0c303018 = 0x00000458; # can0_din_paa3: rsvd1, pull-up, tristate-enable, input-enable
For SPE:
step 6: I enabled the CAN application ~/l4t_rt_aux_cpu_src/l4t-rt/rt-aux-cpu-demo/soc/t19x/target_specific.mk as below:
Enable = 1/Disable = 0 CAN sample app
ENABLE_CAN_APP := 1
step 7: compiled the l4t_rt_aux_cpu_src and got the output files.
there is spe.bin in path ~/l4t_rt_aux_cpu_src/l4t-rt/out
step 8: remove spe.bin and spe_t194.bin in path ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader
step 9: copy spe.bin in ~/l4t_rt_aux_cpu_src/l4t-rt/out to ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader and rename it as spe_t194.bin
step 10: flash the whole board via the command:
sudo ./flash.sh jetson-xavier mmcblk0p1
in the path ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
but finally it failed.
the log information shown as below:
haoye@haoye-Latitude-5300:~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra$ sudo ./flash.sh jetson-xavier mmcblk0p1
L4T BSP Information:
R32 , REVISION: 4.3
Target Board Information:
Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
OpMode: production, Boot Authentication: NS,
copying soft_fuses(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
./tegraflash.py --chip 0x19 --applet “/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0032 ] Generating RCM messages
[ 0.0040 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0046 ] Header already present for /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0077 ]
[ 0.0083 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0089 ] Assuming zero filled SBK key
[ 0.0089 ]
[ 0.0096 ] tegrasign_v2 --key None --file /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0101 ] Assuming zero filled SBK key
[ 0.0105 ]
[ 0.0111 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0143 ]
[ 0.0151 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0158 ]
[ 0.0165 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0172 ] RCM 0 is saved as rcm_0.rcm
[ 0.0200 ] RCM 1 is saved as rcm_1.rcm
[ 0.0200 ] RCM 2 is saved as rcm_2.rcm
[ 0.0200 ] List of rcm files are saved in rcm_list.xml
[ 0.0200 ]
[ 0.0200 ] Signing RCM messages
[ 0.0217 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0233 ] Assuming zero filled SBK key
[ 0.0239 ]
[ 0.0239 ] Copying signature to RCM mesages
[ 0.0247 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0258 ]
[ 0.0259 ] Boot Rom communication
[ 0.0265 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0271 ] RCM version 0X190001
[ 0.0282 ] Boot Rom communication completed
[ 1.0441 ]
[ 2.0484 ] tegrarcm_v2 --isapplet
[ 2.0510 ] Applet version 01.00.0000
[ 2.0542 ]
[ 2.0568 ] tegrarcm_v2 --ismb2
[ 2.0756 ]
[ 2.0786 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.0819 ]
[ 2.0857 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.0885 ] adding BCH for nvtboot_applet_t194.bin
[ 2.1134 ]
[ 2.1178 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.1204 ] Assuming zero filled SBK key
[ 2.1214 ]
[ 2.1268 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.1348 ]
[ 2.1376 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.1401 ] Applet version 01.00.0000
[ 2.1597 ] Sending mb2
[ 2.1600 ] […] 100%
[ 2.1731 ]
[ 2.1760 ] tegrarcm_v2 --boot recovery
[ 2.1798 ] Applet version 01.00.0000
[ 2.1991 ]
[ 3.2024 ] tegrarcm_v2 --isapplet
[ 3.2068 ]
[ 3.2090 ] tegrarcm_v2 --ismb2
[ 3.2110 ] MB2 Applet version 01.00.0000
[ 3.2282 ]
[ 3.2310 ] tegrarcm_v2 --ismb2
[ 3.2336 ] MB2 Applet version 01.00.0000
[ 3.2762 ]
[ 3.2790 ] Retrieving EEPROM data
[ 3.2793 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cvm.bin
[ 3.2817 ] MB2 Applet version 01.00.0000
[ 3.3184 ] Saved platform info in /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cvm.bin
[ 3.3534 ]
[ 3.3535 ] Rebooting to recovery mode
[ 3.3558 ] tegrarcm_v2 --ismb2
[ 3.3585 ] MB2 Applet version 01.00.0000
[ 3.3755 ]
[ 3.3756 ] Rebooting to recovery mode
[ 3.3783 ] tegrarcm_v2 --reboot recovery
[ 3.3811 ] MB2 Applet version 01.00.0000
[ 3.4077 ]
Board ID(2888) version(400) sku(0004) revision(L.0)
copying bctfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)… done.
copying bctfile1(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)… done.
copying uphy_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)… done.
copying device_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)… done.
copying misc_cold_boot_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)… done.
copying misc_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)… done.
copying pinmux_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)… done.
copying gpioint_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)… done.
copying pmic_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)… done.
copying pmc_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)… done.
copying prod_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)… done.
copying scr_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)… done.
copying scr_cold_boot_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)… done.
copying bootrom_config(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)… done.
copying dev_params(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)… done.
Existing bootloader(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
version 1.0.0
[ 0.0030 ] Generating signature
[ 0.0038 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0045 ] Assuming zero filled SBK key
[ 0.0047 ]
[ 0.0048 ] header_magic: 405614
[ 0.0057 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0066 ]
[ 0.0075 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
[ 0.0084 ] adding BCH for 1_Image
[ 0.6591 ]
[ 0.6600 ] tegrasign_v2 --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.6606 ] Assuming zero filled SBK key
[ 0.6973 ]
[ 0.6989 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 3.0694 ]
[ 3.1014 ] Signed file: /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/Image_sigheader.encrypt
Generate header for Image_sigheader.encrypt
Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
Remove temporary file
done.
populating initrd to rootfs… done.
populating /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to rootfs… done.
Making Boot image… done.
Existing sosfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)… done.
Existing scefile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing drameccfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing wb0boot(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)… done.
Copying nv_boot_control.conf to rootfs
version 1.0.0
[ 0.0029 ] Generating signature
[ 0.0037 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0043 ] Assuming zero filled SBK key
[ 0.0046 ]
[ 0.0046 ] header_magic: d00dfeed
[ 0.0053 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0060 ]
[ 0.0067 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0073 ] adding BCH for 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0130 ]
[ 0.0138 ] tegrasign_v2 --key --list 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0144 ] Assuming zero filled SBK key
[ 0.0147 ]
[ 0.0160 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0195 ]
[ 0.0198 ] Signed file: /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate header for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate 16-byte-size-aligned base file for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
Making system.img…
populating rootfs from /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs … done.
populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)… done.
copying cfgfile(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml… done.
Existing flasher(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd “flash; reboot” --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin “mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb”
saving flash command in /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0024 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0031 ] Assuming zero filled SBK key
[ 0.0087 ]
[ 0.0088 ] Generating RCM messages
[ 0.0136 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0146 ] Header already present for mb1_t194_prod.bin
[ 0.0231 ]
[ 0.0239 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0246 ] Assuming zero filled SBK key
[ 0.0252 ]
[ 0.0260 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0267 ] Assuming zero filled SBK key
[ 0.0281 ]
[ 0.0289 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0339 ]
[ 0.0367 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0459 ]
[ 0.0489 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0497 ] RCM 0 is saved as rcm_0.rcm
[ 0.0538 ] RCM 1 is saved as rcm_1.rcm
[ 0.0538 ] RCM 2 is saved as rcm_2.rcm
[ 0.0538 ] List of rcm files are saved in rcm_list.xml
[ 0.0538 ]
[ 0.0539 ] Signing RCM messages
[ 0.0546 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0554 ] Assuming zero filled SBK key
[ 0.0559 ]
[ 0.0559 ] Copying signature to RCM mesages
[ 0.0567 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0582 ]
[ 0.0583 ] Parsing partition layout
[ 0.0673 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0740 ]
[ 0.0742 ] Creating list of images to be signed
[ 0.0772 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.0798 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.0820 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.0864 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.0985 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.0995 ] adding BCH for spe_t194.bin
[ 0.1078 ] adding BCH for spe_t194.bin
[ 0.1124 ] adding BCH for nvtboot_t194.bin
[ 0.1201 ] adding BCH for nvtboot_t194.bin
[ 0.1242 ] Header already present for preboot_c10_prod_cr.bin
[ 0.1308 ] Header already present for preboot_c10_prod_cr.bin
[ 0.1310 ] Header already present for mce_c10_prod_cr.bin
[ 0.1373 ] Header already present for mce_c10_prod_cr.bin
[ 0.1392 ] adding BCH for mts_c10_prod_cr.bin
[ 0.1652 ] adding BCH for mts_c10_prod_cr.bin
[ 0.2340 ] adding BCH for cboot_t194.bin
[ 0.3041 ] adding BCH for cboot_t194.bin
[ 0.3122 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.3211 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.3262 ] adding BCH for tos-trusty_t194.img
[ 0.3342 ] adding BCH for tos-trusty_t194.img
[ 0.3416 ] adding BCH for eks.img
[ 0.3495 ] adding BCH for eks.img
[ 0.3496 ] adding BCH for bpmp_t194.bin
[ 0.3542 ] adding BCH for bpmp_t194.bin
[ 0.3718 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.3940 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.4085 ] adding BCH for camera-rtcpu-rce.img
[ 0.4261 ] adding BCH for camera-rtcpu-rce.img
[ 0.4312 ] adding BCH for adsp-fw.bin
[ 0.5504 ] adding BCH for adsp-fw.bin
[ 0.5598 ] Header already present for warmboot_t194_prod.bin
[ 0.7961 ] Header already present for warmboot_t194_prod.bin
[ 0.7991 ] adding BCH for boot.img
[ 0.9138 ] adding BCH for boot.img
[ 1.6618 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 2.5051 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 2.5313 ]
[ 2.5314 ] Filling MB1 storage info
[ 2.5314 ] Generating br-bct
[ 2.5322 ] Performing cfg overlay
[ 2.5322 ] [‘tegra194-mb1-bct-memcfg-p2888.cfg’, ‘tegra194-memcfg-sw-override.cfg’]
[ 2.5330 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21.cfg
[ 2.6774 ]
[ 2.6775 ] Updating dev and MSS params in BR BCT
[ 2.6776 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 2.7211 ]
[ 2.7212 ] Updating bl info
[ 2.7225 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 2.7241 ]
[ 2.7242 ] Generating signatures
[ 2.7248 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 2.7254 ] Assuming zero filled SBK key
[ 2.8567 ]
[ 2.8567 ] Generating br-bct
[ 2.8575 ] Performing cfg overlay
[ 2.8575 ] [’/home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21.cfg’]
[ 2.8575 ] Updating dev and MSS params in BR BCT
[ 2.8575 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 2.9020 ]
[ 2.9021 ] Updating bl info
[ 2.9028 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 2.9047 ]
[ 2.9047 ] Updating smd info
[ 2.9053 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 2.9061 ]
[ 2.9061 ] Updating Odmdata
[ 2.9067 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 2.9075 ]
[ 2.9075 ] Get Signed section of bct
[ 2.9081 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 2.9088 ]
[ 2.9095 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 2.9100 ] Assuming zero filled SBK key
[ 2.9103 ]
[ 2.9104 ] Updating BCT with signature
[ 2.9109 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 2.9117 ]
[ 2.9117 ] Generating coldboot mb1-bct
[ 2.9131 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 2.9138 ] MB1-BCT version: 0x1
[ 2.9140 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 2.9143 ] Added Platform Config 0 data with size :- 3008
[ 2.9159 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 2.9163 ] Added Platform Config 1 data with size :- 19640
[ 2.9266 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 2.9271 ] Added Platform Config 2 data with size :- 24
[ 2.9274 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 2.9279 ] Added Platform Config 4 data with size :- 348
[ 2.9281 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 2.9286 ] Added Platform Config 3 data with size :- 92
[ 2.9288 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 2.9290 ] Added Platform Config 5 data with size :- 56
[ 2.9290 ]
[ 2.9290 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 2.9290 ] Added Platform Config 7 data with size :- 392
[ 2.9290 ]
[ 2.9290 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 2.9290 ] Added Platform Config 8 data with size :- 12
[ 2.9291 ]
[ 2.9291 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 2.9291 ] Added Platform Config 9 data with size :- 32
[ 2.9291 ]
[ 2.9291 ] Updating mb1-bct with firmware information
[ 2.9298 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.9303 ] MB1-BCT version: 0x1
[ 2.9306 ]
[ 2.9306 ] Updating mb1-bct with storage information
[ 2.9312 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 2.9317 ] MB1-BCT version: 0x1
[ 2.9320 ]
[ 2.9326 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 2.9331 ]
[ 2.9338 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 2.9344 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 2.9351 ]
[ 2.9358 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 2.9364 ] Assuming zero filled SBK key
[ 2.9366 ]
[ 2.9375 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 2.9385 ]
[ 2.9386 ] Generating recovery mb1-bct
[ 2.9392 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 2.9399 ] MB1-BCT version: 0x1
[ 2.9401 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 2.9404 ] Added Platform Config 0 data with size :- 3008
[ 2.9414 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 2.9416 ] Added Platform Config 1 data with size :- 19640
[ 2.9516 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 2.9520 ] Added Platform Config 2 data with size :- 24
[ 2.9522 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 2.9526 ] Added Platform Config 4 data with size :- 348
[ 2.9526 ]
[ 2.9526 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 2.9526 ] Added Platform Config 3 data with size :- 92
[ 2.9526 ]
[ 2.9526 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 2.9526 ] Added Platform Config 5 data with size :- 56
[ 2.9526 ]
[ 2.9526 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 2.9527 ] Added Platform Config 7 data with size :- 392
[ 2.9527 ]
[ 2.9527 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 2.9527 ] Added Platform Config 8 data with size :- 12
[ 2.9527 ]
[ 2.9527 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 2.9527 ] Added Platform Config 9 data with size :- 32
[ 2.9527 ]
[ 2.9527 ] Updating mb1-bct with firmware information
[ 2.9535 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.9541 ] MB1-BCT version: 0x1
[ 2.9545 ]
[ 2.9545 ] Updating mb1-bct with storage information
[ 2.9552 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 2.9565 ] MB1-BCT version: 0x1
[ 2.9570 ]
[ 2.9578 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 2.9584 ]
[ 2.9591 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 2.9596 ] adding BCH for mb1_bct_MB1.bct
[ 2.9603 ]
[ 2.9610 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 2.9615 ] Assuming zero filled SBK key
[ 2.9618 ]
[ 2.9626 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 2.9635 ]
[ 2.9635 ] Generating coldboot mem-bct
[ 2.9641 ] tegrabct_v2 --chip 0x19 0 --sdram /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21.cfg --membct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_1.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_2.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_3.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_4.bct
[ 2.9646 ] Packing sdram param for instance[0]
[ 3.0078 ] Packing sdram param for instance[1]
[ 3.0080 ] Packing sdram param for instance[2]
[ 3.0081 ] Packing sdram param for instance[3]
[ 3.0081 ] Packing sdram param for instance[4]
[ 3.0081 ] Packing sdram param for instance[5]
[ 3.0081 ] Packing sdram param for instance[6]
[ 3.0081 ] Packing sdram param for instance[7]
[ 3.0081 ] Packing sdram param for instance[8]
[ 3.0081 ] Packing sdram param for instance[9]
[ 3.0081 ] Packing sdram param for instance[10]
[ 3.0081 ] Packing sdram param for instance[11]
[ 3.0081 ] Packing sdram param for instance[12]
[ 3.0081 ] Packing sdram param for instance[13]
[ 3.0081 ] Packing sdram param for instance[14]
[ 3.0081 ] Packing sdram param for instance[15]
[ 3.0081 ]
[ 3.0082 ] Getting sector size from pt
[ 3.0089 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 3.0095 ]
[ 3.0096 ] BlockSize read from layout is 200
[ 3.0102 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_1.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_2.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_3.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_4.bct
[ 3.0107 ] adding BCH for /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_1.bct
[ 3.0127 ]
[ 3.0133 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 3.0140 ]
[ 3.0146 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 3.0152 ] Header already present for mem_coldboot.bct
[ 3.0154 ]
[ 3.0162 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.0169 ] Assuming zero filled SBK key
[ 3.0172 ]
[ 3.0181 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 3.0190 ]
[ 3.0191 ] Generating recovery mem-bct
[ 3.0198 ] tegrabct_v2 --chip 0x19 0 --sdram /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21.cfg --membct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_1.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_2.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_3.bct /home/haoye/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/6304/tmpjb9Rp21_4.bct
[ 3.0204 ] Packing sdram param for instance[0]
[ 3.0628 ] Packing sdram param for instance[1]
[ 3.0630 ] Packing sdram param for instance[2]
[ 3.0632 ] Packing sdram param for instance[3]
[ 3.0635 ] Packing sdram param for instance[4]
[ 3.0635 ] Packing sdram param for instance[5]
[ 3.0635 ] Packing sdram param for instance[6]
[ 3.0635 ] Packing sdram param for instance[7]
[ 3.0635 ] Packing sdram param for instance[8]
[ 3.0635 ] Packing sdram param for instance[9]
[ 3.0635 ] Packing sdram param for instance[10]
[ 3.0635 ] Packing sdram param for instance[11]
[ 3.0635 ] Packing sdram param for instance[12]
[ 3.0635 ] Packing sdram param for instance[13]
[ 3.0635 ] Packing sdram param for instance[14]
[ 3.0635 ] Packing sdram param for instance[15]
[ 3.0635 ]
[ 3.0646 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 3.0653 ]
[ 3.0659 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 3.0665 ] adding BCH for mem_rcm.bct
[ 3.0677 ]
[ 3.0687 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.0694 ] Assuming zero filled SBK key
[ 3.0698 ]
[ 3.0712 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 3.0737 ]
[ 3.0738 ] Copying signatures
[ 3.0748 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 6.1183 ]
[ 6.1183 ] Boot Rom communication
[ 6.1190 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 6.1197 ] BR_CID: 0x8802191164705706240000000c028100
[ 6.1204 ] RCM version 0X190001
[ 6.1385 ] Boot Rom communication completed
[ 7.1562 ]
[ 8.1603 ] tegrarcm_v2 --isapplet
[ 8.1626 ] Applet version 01.00.0000
[ 8.1655 ]
[ 8.1656 ] Sending BCTs
[ 8.1680 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 8.1703 ] Applet version 01.00.0000
[ 8.1891 ] Sending bct_bootrom
[ 8.1898 ] […] 100%
[ 8.1913 ] Sending bct_mb1
[ 8.1948 ] […] 100%
[ 8.1989 ] Sending bct_mem
[ 8.2444 ] […] 100%
[ 8.3270 ]
[ 8.3271 ] Generating blob
[ 8.3303 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 8.3327 ]
[ 8.3352 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 8.3377 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 8.3584 ]
[ 8.3618 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.3648 ] Assuming zero filled SBK key
[ 8.3662 ]
[ 8.3687 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 8.3762 ]
[ 8.3776 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 8.3786 ]
[ 8.3796 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 8.3806 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 8.3848 ]
[ 8.3859 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.3867 ] Assuming zero filled SBK key
[ 8.3870 ]
[ 8.3883 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 8.3909 ]
[ 8.3919 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 8.3929 ]
[ 8.3941 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 8.3949 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 8.3952 ]
[ 8.3960 ] tegrasign_v2 --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.3966 ] Assuming zero filled SBK key
[ 8.3968 ]
[ 8.3978 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 8.3988 ]
[ 8.3995 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 8.4002 ]
[ 8.4009 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 8.4015 ] Header already present for blob_mce_c10_prod_cr.bin
[ 8.4031 ]
[ 8.4039 ] tegrasign_v2 --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.4046 ] Assuming zero filled SBK key
[ 8.4051 ]
[ 8.4065 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 8.4089 ]
[ 8.4097 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 8.4103 ]
[ 8.4109 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 8.4115 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 8.4771 ]
[ 8.4781 ] tegrasign_v2 --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.4787 ] Assuming zero filled SBK key
[ 8.4818 ]
[ 8.4829 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 8.5194 ]
[ 8.5203 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 8.5210 ]
[ 8.5220 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader blob_bpmp_t194.bin zerosbk
[ 8.5230 ] adding BCH for blob_bpmp_t194.bin
[ 8.5395 ]
[ 8.5414 ] tegrasign_v2 --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.5429 ] Assuming zero filled SBK key
[ 8.5438 ]
[ 8.5452 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 8.5549 ]
[ 8.5557 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04.dtb
[ 8.5563 ]
[ 8.5568 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader blob_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[ 8.5573 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04.dtb
[ 8.5730 ]
[ 8.5742 ] tegrasign_v2 --key None --list blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.5749 ] Assuming zero filled SBK key
[ 8.5756 ]
[ 8.5766 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[ 8.5847 ]
[ 8.5855 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 8.5861 ]
[ 8.5867 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader blob_spe_t194.bin zerosbk
[ 8.5872 ] adding BCH for blob_spe_t194.bin
[ 8.5896 ]
[ 8.5903 ] tegrasign_v2 --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.5909 ] Assuming zero filled SBK key
[ 8.5911 ]
[ 8.5919 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 8.5938 ]
[ 8.5945 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[ 8.5951 ]
[ 8.5957 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader blob_tos-trusty_t194.img zerosbk
[ 8.5963 ] adding BCH for blob_tos-trusty_t194.img
[ 8.6038 ]
[ 8.6055 ] tegrasign_v2 --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.6064 ] Assuming zero filled SBK key
[ 8.6069 ]
[ 8.6078 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[ 8.6123 ]
[ 8.6130 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 8.6136 ]
[ 8.6142 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader blob_eks.img zerosbk
[ 8.6148 ] adding BCH for blob_eks.img
[ 8.6148 ]
[ 8.6156 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.6162 ] Assuming zero filled SBK key
[ 8.6163 ]
[ 8.6172 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 8.6179 ]
[ 8.6186 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[ 8.6193 ]
[ 8.6199 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 8.6205 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[ 8.6260 ]
[ 8.6269 ] tegrasign_v2 --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.6275 ] Assuming zero filled SBK key
[ 8.6279 ]
[ 8.6290 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 8.6330 ]
[ 8.6341 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 8.6347 ] number of images in blob are 11
[ 8.6349 ] blobsize is 6368328
[ 8.6350 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 258144
[ 8.6370 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 129936
[ 8.6376 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 8.6383 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 142592
[ 8.6389 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430800
[ 8.6400 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856112
[ 8.6408 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 747008
[ 8.6414 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 120496
[ 8.6417 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 373696
[ 8.6422 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 8.6425 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 280208
[ 8.6440 ]
[ 8.6441 ] Sending bootloader and pre-requisite binaries
[ 8.6449 ] tegrarcm_v2 --download blob blob.bin
[ 8.6455 ] Applet version 01.00.0000
[ 8.6645 ] Sending blob
[ 8.6646 ] […] 100%
[ 9.5991 ]
[ 9.6020 ] tegrarcm_v2 --boot recovery
[ 9.6046 ] Applet version 01.00.0000
[ 9.6124 ]
[ 10.6164 ] tegrarcm_v2 --isapplet
[ 10.6192 ] USB communication failed.Check if device is in recovery
[ 10.8549 ]
[ 10.8579 ] tegrarcm_v2 --ismb2
the flash process stops (or died) here and never go on.
Do you know what might be the issue?
And how can I solve it?
below is what I guess might be the point of the issue, but I still don’t know why and how to solve it.
If i comment the mttcan_transfer(ttcan, fd) in can-app.c as below, it can be flashed succesfully. but if so, the CAN module can not work.
static void can_test_transmit(struct mttcanfd_frame *fd,
struct ttcan_controller *ttcan, bool is_xtd,
bool is_can_fd, bool is_brs)
if (is_xtd)
fd->payload.frame.can_id |= (CAN_FMT);
else
fd->payload.frame.can_id &= ~(CAN_FMT);
if (is_can_fd && is_brs)
fd->payload.frame.flags |= (CAN_FD_FLAG) | (CAN_BRS_FLAG);
else if (is_can_fd)
fd->payload.frame.flags |= (CAN_FD_FLAG);
else
fd->payload.frame.flags &= ~((CAN_FD_FLAG) | (CAN_BRS_FLAG));
fd->payload.frame.tstamp = tegra_tke_get_usec();
//mttcan_transfer(ttcan, fd);
printf("Transmited message from CAN %lu\r\n", ttcan->id);
vTaskDelay(CAN_TEST_DELAY);
I’m looking forward to your reply.
Thank you.
BR
Hao Ye
