Hi all,
I’m working on a Speech-to-Text project on a Jetson Orin Nano Super running JetPack 6.2. My goal is to run a custom Whisper-based STT model that has been fine-tuned. The project involves real-time transcription of incoming audio (aviation communication) and leveraging GPU acceleration for low-latency inference.
My Setup:
Device: NVIDIA Jetson Orin nano super
JetPack Version: 6.2
Python Version: 3.10.12
PyTorch: I installed a GPU-enabled PyTorch wheel provided by NVIDIA for JetPack 6.1/6.2: torch-2.5.0a0+872d972e41.nv24.08-cp310-cp310-linux_aarch64.whl -This version correctly enables CUDA (verified via torch.cuda.is_available()
torchaudio: I need torchaudio to handle audio input in my STT pipeline. However, when I try to install torchaudio (using the pre-built wheels from PyPI or otherwise), it pulls in a CPU-only version of torch or builds against a different ABI. I then get the error when I run my code:
OSError: /home/Orin/.local/lib/python3.10/site-packages/torchaudio/lib/libtorchaudio.so: undefined symbol: _ZNK5torch8autograd4Node4nameEv
This error indicates that the torchaudio wheel I installed is not ABI-compatible with my GPU-enabled PyTorch build. I’ve attempted the following:
- Installed the specific GPU-enabled torch (2.5.0a0+872d972e41.nv24.08) manually.
- Tried installing torchaudio from available wheels (e.g.,
torchaudio-2.5.0-cp310-cp310-linux_aarch64.whl
) with the--no-deps
flag, but the resulting torchaudio still fails to load due to the undefined symbol error.
What I Need Help With:
- Is there an official GPU-enabled torchaudio wheel (or recommended build) that matches my GPU-enabled torch (2.5.0a0+872d972e41.nv24.08) for Jetson Orin running JP6.2?
- If not, what is the best practice for building torchaudio from source on this platform so that it is ABI-compatible with the torch version I’m using?
- Any additional tips for setting up a stable environment for running my custom Whisper STT model on Jetson Orin would be greatly appreciated.
I have verified that torch runs with CUDA support (using the GPU-enabled torch wheel) when torchaudio is not present. The issue arises only when torchaudio is installed and imported.
Thanks in advance for your assistance!
Best regards,
Samuel
