Issue with UART causing system to boot into EFI Shell/UEFI during power-on
hi NV team
We are using THOR’s UART1, UART2, and UART5 to connect to peripheral devices on our custom carrier board.
We encountered an issue during power-on: the peripheral devices transmit console data to THOR while booting. When these devices are connected, THOR automatically boots into the EFI shell or UEFI setting mode instead of the OS.
However, if we disconnect the peripheral devices, THOR boots successfully. We also verified that if we connect the devices after a successful boot, the UART functions work perfectly normal.
Could you please advise on how to skip or disable UART detection/interruption during the boot sequence?
Thanks,
Hi larson2,
Please disable the serial interfaces in UEFI-DTB to prevent it interrupts the booting.
You can simply specify different DTB for UEFI(TBCDTB_FILE) and kernel(DTB_FILE) in custom board config.
