Issue with Writing to Global memory
Okay, I have an issue. I’m working on a simple raytracer, and for some reason, I can’t write to global memory. In the code below, at the end of the main global function we have:
if (hit.z != 1000.0) {
		hits[outidx] = 0;
	else {
		hits[outidx] = 1;
If I run the code below, I get a Kernel Launch error. If I change the above code to just:
hits[outidx] = 0;
It works fine…what am I missing here?
Thanks in advance for the help, and btw, here’s my code:
__device__ float4 Intersects(float3 a, float3 b, float3 c, float3 o, float3 d,
	float minT, float4 lastHit, float mat_index)
		float3 e1 = sub(b,a);
		float3 e2 = sub(c,a);
		float3 p = cross(d, e2);
		float det = dot(p, e1);
		int icrap = det > 0.00001f;
		float invdet = 1.0f / det;
		float3 tvec = sub(o,a);
		float u = dot(p, tvec) * invdet;
		float3 q = cross(tvec, e1);
		float v = dot(q, d) * invdet;
		float t = dot(q, e2) * invdet;
		icrap = (u >= 0.0f)
			&& (v >= 0.0f)
			&& (u + v <= 1.0f)
			&& (t < lastHit.z)
			&& (t >= 0.0f)
			&& (t > minT);
		float4 ret;
		ret.x = u;
		ret.y = v;
		ret.z = t;
		ret.w = mat_index;
		return (icrap ? ret : lastHit);
__device__ inline int getidx(){
	return blockIdx.x * blockDim.x + threadIdx.x;
extern "C" __global__ void raytrace (float *hits, float4 *rays, float4 *tris, uint tricount)
	uint idx = getidx()  * 2;
	uint outidx = getidx();
	float4 o = rays[idx];
	float4 d = rays[idx+1];
	float4 hit;
	hit.z = 1000.0f;
	for (int off = 0; off < tricount; off += 1){
		float4 a = tris[(off * 3)];
		float4 b = tris[(off * 3)+1];
		float4 c = tris[(off * 3)+2];
		hit = Intersects(dto3(a), dto3(b), dto3(c), dto3(o), dto3(d), 0.0001, hit, 1);
		hits[outidx] = 0;
	else {
		hits[outidx] = 1;
ROFL…it seems the profanity filter here on the forums thought that “is Hit” is a terrible variable name, so all my hit variables are now “iscrap”.
That’s just awesome…
Hehe :)
How big does outIdx get? And how do you allocate the array? I mean, is the array big enough (allocated with sizeof()), and is it certainly 100% surely allocated and passed in? I.e., i’d look at it from a pointer point of view.
From a glance at the code, the output line itself should work, as far as I can tell.
that’s what I thought at first as well, but then I wrote a second function like this:
extern "C" __global__ void test(float4 *hits, float4 *rays, float4 *tris, uint tricount)
	o.z += 1;
	//rays[idx] = o;
This code runs fine. If I uncomment the write out line the kernel will not run. So in this case it can’t be a memory overflow error, reading works fine, read/write does not. As a test, I made the above function write only…
Well I’m using the C# CUDA bindings (CUDA.NET)…and it seems I’m a total airhead… I was providing the parameter offsets into the function in the wrong way. If I’m passing in 4 paramenters the offsets are as follows:
0
IntPtr.Size
IntPtr.Size *2
IntPtr.Size *3
NOT:
0
IntPtr.Size *2
IntPtr.Size *3
IntPtr.Size *4
Well that’s fixed…
Just a note for your information that may save you several debugging headaches in the future. The CUDA compiler has a really aggressive dead code optimizer. If you comment out the global memory write like that, it notices that everything in the kernel that leads up to calculating the result (including the global memory read) is pointless and removes it. Thus you typically get a completely empty kernel if you comment out the global memory write at the end.
