Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
I’m having issues adding opencv in nvmedia, I’ve been trying adding Cflags and LDLIBs with pkg-config command to add libraries and include path, but I got errors of incompatibility, which seems to be caused by cross-compilation. Is there any way to solve that?
Dear @bohan.zhang,
We don’t officially support opencv with DRIVEOS and hence never tested compilation/running opencv. You may have to try seeking help from the community or other discussion forums.
May I know what functionality that is missing nvmedia/driveworks and made you to use openCV library? It helps to provide appropriate guidance for your use case.
Yeah, we’re converting generated buffer for yuv file into rgb, and wanna display the real-time video on nvsipl. We’re also looking for outputting buffer for other use
@SivaRamaKrishnaNV@VickNV Would that be any solution for this question? Coz I’m having the same issues as well. I’m also wondering is that possible to add a shared library in make file in line:
$(TARGETS): $(OBJS)
$(LD) $(LDFLAGS) -o $@ $^ $(LDLIBS)
Would that work if we make stuff like:
$(TARGETS): $(OBJS)
$(LD) $(LDFLAGS) -o $@ $^ $(LDLIBS) -share ourlibs.so
