Thanks for the pointers. I tried to collect the evidence you asked for.
dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Nano Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x25f4fae98 SMBIOS=0xffff0000 SMBIOS 3.0=0x2412f0000 MEMATTR=0x240865018 ESRT=0x2408a5c18 RNG=0x264536c18 MEMRESERVE=0x24086ef18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x00000002408a5c18 to 0x00000002408a5c50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000254400000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000026fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000023bffffff]
[ 0.000000] node 0: [mem 0x000000023c000000-0x000000023e1bffff]
[ 0.000000] node 0: [mem 0x000000023e1c0000-0x000000024076ffff]
[ 0.000000] node 0: [mem 0x0000000240770000-0x000000024079ffff]
[ 0.000000] node 0: [mem 0x00000002407a0000-0x00000002407bffff]
[ 0.000000] node 0: [mem 0x00000002407c0000-0x000000024085ffff]
[ 0.000000] node 0: [mem 0x0000000240860000-0x000000024087ffff]
[ 0.000000] node 0: [mem 0x0000000240880000-0x000000024089ffff]
[ 0.000000] node 0: [mem 0x00000002408a0000-0x0000000240d27fff]
[ 0.000000] node 0: [mem 0x0000000240d28000-0x0000000240e88fff]
[ 0.000000] node 0: [mem 0x0000000240e89000-0x00000002412dffff]
[ 0.000000] node 0: [mem 0x00000002412e0000-0x00000002412fffff]
[ 0.000000] node 0: [mem 0x0000000241300000-0x000000024160ffff]
[ 0.000000] node 0: [mem 0x0000000241610000-0x000000024165ffff]
[ 0.000000] node 0: [mem 0x0000000241660000-0x000000024181ffff]
[ 0.000000] node 0: [mem 0x0000000241820000-0x00000002419fffff]
[ 0.000000] node 0: [mem 0x0000000241a00000-0x0000000241a8ffff]
[ 0.000000] node 0: [mem 0x0000000241a90000-0x0000000241c6ffff]
[ 0.000000] node 0: [mem 0x0000000241c70000-0x0000000241ccffff]
[ 0.000000] node 0: [mem 0x0000000241cd0000-0x0000000241dbffff]
[ 0.000000] node 0: [mem 0x0000000241dc0000-0x0000000241deffff]
[ 0.000000] node 0: [mem 0x0000000241df0000-0x0000000241dfffff]
[ 0.000000] node 0: [mem 0x0000000241e00000-0x0000000241eaffff]
[ 0.000000] node 0: [mem 0x0000000241eb0000-0x0000000241f4ffff]
[ 0.000000] node 0: [mem 0x0000000241f50000-0x000000024204ffff]
[ 0.000000] node 0: [mem 0x0000000242050000-0x00000002420effff]
[ 0.000000] node 0: [mem 0x00000002420f0000-0x00000002421effff]
[ 0.000000] node 0: [mem 0x00000002421f0000-0x000000024228ffff]
[ 0.000000] node 0: [mem 0x0000000242290000-0x0000000242b5ffff]
[ 0.000000] node 0: [mem 0x0000000242b60000-0x0000000242d3ffff]
[ 0.000000] node 0: [mem 0x0000000242d40000-0x00000002644effff]
[ 0.000000] node 0: [mem 0x00000002644f0000-0x000000026453ffff]
[ 0.000000] node 0: [mem 0x0000000264540000-0x0000000267ffffff]
[ 0.000000] node 0: [mem 0x0000000268200000-0x000000026860ffff]
[ 0.000000] node 0: [mem 0x000000026e000000-0x000000026fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000026fffffff]
[ 0.000000] On node 0 totalpages: 2008080
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 23552 pages used for memmap
[ 0.000000] Normal zone: 1483792 pages, LIFO batch:63
[ 0.000000] On node 0, zone Normal: 496 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] pcpu-alloc: s90200 r8192 d32680 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1976336
[ 0.000000] Kernel command line: root=PARTUUID=9aede23d-88d0-473a-8631-41806a727110 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 7237592K/8032320K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 532584K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000631] Console: colour dummy device 80x25
[ 0.000670] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000677] pid_max: default: 32768 minimum: 301
[ 0.000735] LSM: Security Framework initializing
[ 0.000756] Yama: becoming mindful.
[ 0.000774] SELinux: Initializing.
[ 0.000834] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000848] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001569] /cpus/cpu-map/cluster1: empty cluster
[ 0.001866] rcu: Hierarchical SRCU implementation.
[ 0.001948] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002364] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0003-p3768-0000-a0.dts
[ 0.002369] DTB Build time: Mar 19 2023 08:08:40
[ 0.003573] Tegra Revision: A01 SKU: 0xd5 CPU Process: 0 SoC Process: 0
[ 0.003732] Remapping and enabling EFI services.
[ 0.004948] smp: Bringing up secondary CPUs ...
[ 0.033645] Detected PIPT I-cache on CPU1
[ 0.033683] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033711] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062350] Detected PIPT I-cache on CPU2
[ 0.062360] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062375] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.090978] Detected PIPT I-cache on CPU3
[ 0.090987] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091001] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.121653] Detected PIPT I-cache on CPU4
[ 0.121678] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[ 0.121707] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.150409] Detected PIPT I-cache on CPU5
[ 0.150422] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[ 0.150438] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.150502] smp: Brought up 1 node, 6 CPUs
[ 0.150516] SMP: Total of 6 processors activated.
[ 0.150520] CPU features: detected: Privileged Access Never
[ 0.150522] CPU features: detected: LSE atomic instructions
[ 0.150523] CPU features: detected: User Access Override
[ 0.150525] CPU features: detected: 32-bit EL0 Support
[ 0.150528] CPU features: detected: Common not Private translations
[ 0.150530] CPU features: detected: RAS Extension Support
[ 0.150532] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.150534] CPU features: detected: CRC32 instructions
[ 0.150536] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.189251] CPU: All CPU(s) started at EL2
[ 0.191024] devtmpfs: initialized
[ 0.207948] Registered cp15_barrier emulation handler
[ 0.207957] Registered setend emulation handler
[ 0.207962] KASLR enabled
[ 0.208120] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.208132] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.210117] pinctrl core: initialized pinctrl subsystem
[ 0.210675] SMBIOS 3.0.0 present.
[ 0.210684] DMI: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.210967] NET: Registered protocol family 16
[ 0.211871] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.211938] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.212004] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.212033] audit: initializing netlink subsys (disabled)
[ 0.212123] audit: type=2000 audit(0.212:1): state=initialized audit_enabled=0 res=1
[ 0.212310] thermal_sys: Registered thermal governor 'step_wise'
[ 0.212313] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.212316] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.213157] cpuidle: using governor menu
[ 0.213278] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.213352] ASID allocator initialised with 32768 entries
[ 0.213459] Serial: AMBA PL011 UART driver
[ 0.215393] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.215421] Tegra reboot handler registered.
[ 0.236813] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000
[ 0.236826] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000
[ 0.236835] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000
[ 0.236846] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000
[ 0.236854] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000
[ 0.236861] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000
[ 0.236867] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000
[ 0.236875] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000
[ 0.236881] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000
[ 0.236887] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000
[ 0.236894] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000
[ 0.236901] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000
[ 0.236908] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000
[ 0.236914] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000
[ 0.236921] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000
[ 0.236927] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000
[ 0.236934] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000
[ 0.236942] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.236966] mc-err: mcerr ops are set to t23x
[ 0.237730] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 1.393354] printk: console [ttyAMA0] enabled
[ 1.402191] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.408898] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.415597] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.422294] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.430905] ACPI: Interpreter disabled.
[ 1.435190] ddr-vddq: supplied by vdd-5v
[ 1.439325] ddr-vdd2: supplied by vdd-5v
[ 1.443381] vdd-AO-1v2: supplied by vdd-5v
[ 1.447616] vdd-3v3: supplied by vdd-5v
[ 1.451660] vdd-rtc: supplied by vdd-AO-1v2
[ 1.455968] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 1.460799] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 1.465783] vdd-1v8: supplied by vdd-3v3-sys
[ 1.470173] vdd-3v3-AO: supplied by vdd-5v-sys
[ 1.474736] vdd-av10-hub: supplied by vdd-5v-sys
[ 1.479485] vdd-vbus-a: supplied by vdd-5v-sys
[ 1.484043] vdd-vbus-b: supplied by vdd-5v-sys
[ 1.488620] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 1.493432] iommu: Default domain type: Translated
[ 1.498344] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.504635] SCSI subsystem initialized
[ 1.508462] usbcore: registered new interface driver usbfs
[ 1.513958] usbcore: registered new interface driver hub
[ 1.519281] usbcore: registered new device driver usb
[ 1.524542] mc: Linux media interface: v0.10
[ 1.528819] videodev: Linux video capture interface: v2.00
[ 1.534470] pps_core: LinuxPPS API ver. 1 registered
[ 1.539433] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.548573] PTP clock support registered
[ 1.552743] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.559898] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.567595] Registered efivars operations
[ 1.571748] FPGA manager framework
[ 1.575191] Advanced Linux Sound Architecture Driver Initialized.
[ 1.581573] Bluetooth: Core ver 2.22
[ 1.585155] NET: Registered protocol family 31
[ 1.589598] Bluetooth: HCI device and connection manager initialized
[ 1.595956] Bluetooth: HCI socket layer initialized
[ 1.600831] Bluetooth: L2CAP socket layer initialized
[ 1.605890] Bluetooth: SCO socket layer initialized
[ 1.611310] camchar: rtcpu character device driver loaded
[ 1.616946] clocksource: Switched to clocksource arch_sys_counter
[ 1.819730] VFS: Disk quotas dquot_6.6.0
[ 1.823696] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.830746] pnp: PnP ACPI: disabled
[ 1.836519] la/ptsa driver initialized.
[ 1.840417] NET: Registered protocol family 2
[ 1.844913] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.854007] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 1.862555] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.870549] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.878461] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.885063] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.891873] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.899177] NET: Registered protocol family 1
[ 1.903747] RPC: Registered named UNIX socket transport module.
[ 1.909680] RPC: Registered udp transport module.
[ 1.914382] RPC: Registered tcp transport module.
[ 1.919081] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.925527] PCI: CLS 0 bytes, default 64
[ 1.929556] Trying to unpack rootfs image as initramfs...
[ 2.092746] Freeing initrd memory: 9120K
[ 2.098803] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.106716] kvm [1]: IPA Size Limit: 48 bits
[ 2.111044] kvm [1]: GICv3: no GICV resource entry
[ 2.115834] kvm [1]: disabling GICv2 emulation
[ 2.120296] kvm [1]: GIC system register CPU interface enabled
[ 2.126193] kvm [1]: vgic interrupt IRQ9
[ 2.130221] kvm [1]: VHE mode initialized successfully
[ 2.136032] Initialise system trusted keyrings
[ 2.140561] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.149518] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.155687] NFS: Registering the id_resolver key type
[ 2.160753] Key type id_resolver registered
[ 2.164933] Key type id_legacy registered
[ 2.168984] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.175691] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.183097] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.202832] NET: Registered protocol family 38
[ 2.207278] Key type asymmetric registered
[ 2.211372] Asymmetric key parser 'x509' registered
[ 2.216266] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.223725] io scheduler mq-deadline registered
[ 2.228257] io scheduler kyber registered
[ 2.236535] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.242137] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.247725] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.255933] tegra_dc_assign_hw_data: no matching compatible node
[ 2.261945] tegradccommon module_init failed
[ 2.266213] tegradc module_init failed
[ 2.270237] EINJ: ACPI disabled.
[ 2.275128] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.282008] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.287146] tegra-pmc: ### PMC reset level: L1
[ 2.291585] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.298031] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.745695] random: fast init done
[ 3.890059] printk: console [ttyTCU0] enabled
[ 3.895152] arm-smmu 12000000.iommu: probing hardware configuration...
[ 3.901856] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.906681] arm-smmu 12000000.iommu: stage 1 translation
[ 3.912220] arm-smmu 12000000.iommu: stage 2 translation
[ 3.917759] arm-smmu 12000000.iommu: nested translation
[ 3.923206] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.930612] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 3.939734] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 3.946432] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 3.953126] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 3.960678] arm-smmu 10000000.iommu: probing hardware configuration...
[ 3.967375] arm-smmu 10000000.iommu: SMMUv2 with:
[ 3.972194] arm-smmu 10000000.iommu: stage 1 translation
[ 3.977729] arm-smmu 10000000.iommu: stage 2 translation
[ 3.983271] arm-smmu 10000000.iommu: nested translation
[ 3.988726] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 3.996129] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.005311] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.012011] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.018704] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.025896] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.032499] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.037238] arm-smmu 8000000.iommu: stage 1 translation
[ 4.042689] arm-smmu 8000000.iommu: stage 2 translation
[ 4.048135] arm-smmu 8000000.iommu: nested translation
[ 4.053488] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.060809] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.069874] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.076486] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.083091] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.090381] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.100046] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.106029] tegra_profiler: auth: init
[ 4.110167] nvsciipc: loaded module
[ 4.115489] tun: Universal TUN/TAP device driver, 1.6
[ 4.121172] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.128590] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.134075] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.139162] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.145251] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.150787] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.156675] PPP generic driver version 2.4.2
[ 4.161115] PPP BSD Compression module registered
[ 4.165938] PPP Deflate Compression module registered
[ 4.171143] PPP MPPE Compression module registered
[ 4.176085] usbcore: registered new interface driver r8152
[ 4.181723] usbcore: registered new interface driver asix
[ 4.187266] usbcore: registered new interface driver ax88179_178a
[ 4.193537] usbcore: registered new interface driver cdc_ether
[ 4.199540] usbcore: registered new interface driver net1080
[ 4.205356] usbcore: registered new interface driver cdc_subset
[ 4.211433] usbcore: registered new interface driver zaurus
[ 4.217171] usbcore: registered new interface driver cdc_ncm
[ 4.222981] usbcore: registered new interface driver aqc111
[ 4.228831] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.235185] ohci-pci: OHCI PCI platform driver
[ 4.239756] ohci-platform: OHCI generic platform driver
[ 4.245452] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.251801] usbcore: registered new interface driver uas
[ 4.257280] usbcore: registered new interface driver usb-storage
[ 4.263612] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.269702] mousedev: PS/2 mouse device common for all mice
[ 4.275452] usbcore: registered new interface driver xpad
[ 4.282855] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.288352] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:26 UTC (26)
[ 4.296575] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.302985] i2c /dev entries driver
[ 4.306702] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.312494] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.318195] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.323880] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.329562] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.335240] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.340917] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.346585] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.356046] device-mapper: uevent: version 1.0.3
[ 4.360885] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.370628] sdhci: Secure Digital Host Controller Interface driver
[ 4.376976] sdhci: Copyright(c) Pierre Ossman
[ 4.381444] Synopsys Designware Multimedia Card Interface Driver
[ 4.387701] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.393868] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 4.394091] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.407311] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5
[ 4.416130] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.421776] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.432135] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.438084] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 5.531248] hid: raw HID events driver (C) Jiri Kosina
[ 5.537050] usbcore: registered new interface driver usbhid
[ 5.542780] usbhid: USB HID core driver
[ 5.547223] tegra-dce d800000.dce: Adding to iommu group 4
[ 5.554069] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.562719] tegra234-aon c000000.aon: Adding to iommu group 5
[ 5.569124] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.577873] c000000.aon:hsp: probed
[ 5.578276] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.588664] tegra234-aon c000000.aon: init done
[ 5.589081] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 5.593468] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.599573] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 5.608193] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 5.614607] tegra23x-psc e860000.psc: init done
[ 5.614823] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 5.623018] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 5.628404] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.634414] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 5.659103] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 5.667756] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 5.674478] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.683655] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.695088] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 5.706484] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 5.718179] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80[ 5.730739] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 5.743565] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 5.755650] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[ 5.762451] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.771014] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=97e50cbff52bc4b542b2989187109c001c01cf77
[ 5.784464] t19x_cache tegra-cache: probed
[ 5.788879] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 5.799369] optee: probing for conduit method.
[ 5.803961] optee: revision 3.19 (3f29c61f)
[ 5.804155] optee: dynamic shared memory is enabled
[ 5.813576] optee: initialized driver
[ 5.828722] nvpmodel: initialized successfully
[ 5.833398] tegra_hv: get_hvd: not initialized yet
[ 5.838335] user_ivc_mempool: hypervisor not present
[ 5.844070] usbcore: registered new interface driver snd-usb-audio
[ 5.851212] u32 classifier
[ 5.853994] input device check on
[ 5.857756] Actions configured
[ 5.861404] Initializing XFRM netlink socket
[ 5.866270] NET: Registered protocol family 10
[ 5.872305] Segment Routing with IPv6
[ 5.876132] NET: Registered protocol family 17
[ 5.880715] NET: Registered protocol family 15
[ 5.885338] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.899033] Bluetooth: RFCOMM socket layer initialized
[ 5.904329] Bluetooth: RFCOMM ver 1.11
[ 5.908186] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.914270] Bluetooth: HIDP socket layer initialized
[ 5.920222] 9pnet: Installing 9P2000 support
[ 5.924662] Key type dns_resolver registered
[ 5.929466] registered taskstats version 1
[ 5.933688] Loading compiled-in X.509 certificates
[ 5.948747] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[ 5.959331] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 5.972524] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 5.979757] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 5.992326] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 5.999339] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[ 6.011611] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.018459] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[ 6.030659] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 6.037713] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[ 6.063306] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.073825] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.102680] host1x 13e40000.host1x: initialized
[ 6.107735] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.115792] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.128125] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.136111] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.148445] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.156440] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.168759] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.176742] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.189045] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.197080] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.209418] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.217392] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.229696] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.237675] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.250001] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.257981] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.270304] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.278277] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.290568] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.298546] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.310836] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.318864] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.331158] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.339146] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.351466] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.359438] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.371741] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.379717] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.392021] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.400015] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.412321] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.420303] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.432637] falcon 15340000.vic: Adding to iommu group 30
[ 6.443790] falcon 15340000.vic: initialized
[ 6.448524] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.457202] falcon 15380000.nvjpg: initialized
[ 6.461924] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.470733] falcon 15540000.nvjpg1: initialized
[ 6.475549] falcon 15a50000.ofa: Adding to iommu group 33
[ 6.484720] falcon 15a50000.ofa: initialized
[ 6.489278] nvdec 15480000.nvdec: Adding to iommu group 34
[ 6.501939] nvdec 15480000.nvdec: initialized
[ 6.506577] tsec 15500000.tsec: Adding to iommu group 35
[ 6.516629] tsec 15500000.tsec: initialized
[ 6.524089] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.541798] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.557943] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.564698] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.572479] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.579926] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.586928] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.593420] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.599871] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.608164] tegra194-isp5 14800000.isp: Adding to iommu group 36
[ 6.616379] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.626033] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.632483] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.641708] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.651074] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[ 6.659253] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[ 6.667282] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.677270] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.684072] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.694068] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.700864] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.710846] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.717763] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 6.724975] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 6.732488] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.739104] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.745847] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.752499] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 6.762264] serial-tegra 3130000.serial: Adding to iommu group 2
[ 6.768813] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 6.778528] serial-tegra 3140000.serial: Adding to iommu group 2
[ 6.785099] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 6.810984] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 6.820736] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.826313] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.834972] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 6.844581] tegra-xusb 3610000.xhci: irq 219, io mem 0x03610000
[ 6.851045] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.859544] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.866970] usb usb1: Product: xHCI Host Controller
[ 6.871973] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 6.878232] usb usb1: SerialNumber: 3610000.xhci
[ 6.883739] hub 1-0:1.0: USB hub found
[ 6.887617] hub 1-0:1.0: 4 ports detected
[ 6.891996] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.897555] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.905343] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.912855] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.921366] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.928793] usb usb2: Product: xHCI Host Controller
[ 6.933796] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 6.940055] usb usb2: SerialNumber: 3610000.xhci
[ 6.945388] hub 2-0:1.0: USB hub found
[ 6.949256] hub 2-0:1.0: 4 ports detected
[ 6.971543] i2c i2c-2: Added multiplexed i2c bus 9
[ 6.976868] i2c i2c-2: Added multiplexed i2c bus 10
[ 6.981887] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 6.988863] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.010676] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1491000 KHz, changing to: 1497600 KHz
[ 7.025625] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1537000 KHz, changing to: 1510400 KHz
[ 7.037535] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 7.045060] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.047083] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.052975] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.063620] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.067432] irq: IRQ283: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.072307] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.079993] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[ 7.088612] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 8.173168] tegra194-pcie 14100000.pcie: Phy link never came up
[ 8.179355] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.186169] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.191805] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.201631] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.212455] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.220385] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.226730] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.242552] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.247944] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.257026] pcieport 0001:00:00.0: Adding to iommu group 8
[ 8.262982] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 8.269643] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 8.275658] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 8.281791] pci 0001:00:00.0: Removing from iommu group 8
[ 8.287351] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 8.295796] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.303713] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.310888] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.319574] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.328254] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.445153] tegra194-pcie 14160000.pcie: Link up
[ 8.461474] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.468277] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.473921] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.484019] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.494849] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.502771] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.509085] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.519541] pci 0004:01:00.0: [1344:5416] type 00 class 0x010802
[ 8.525898] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.534679] pci 0004:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0004:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[ 8.554690] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.562124] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.570092] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.575455] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.582804] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.591544] pci 0004:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 8.600488] pcieport 0004:00:00.0: Adding to iommu group 9
[ 8.606363] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 8.612767] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 8.618850] nvme 0004:01:00.0: Adding to iommu group 9
[ 8.624612] nvme nvme0: pci function 0004:01:00.0
[ 8.629661] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.630242] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 8.643092] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 8.650282] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 8.658963] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 8.661153] nvme nvme0: allocated 64 MiB host memory buffer.
[ 8.667653] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 8.711782] nvme nvme0: 6/0/0 default/read/poll queues
[ 8.719221] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 9.137223] tegra-xusb 3610000.xhci: entering ELPG done
[ 9.777296] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 9.783475] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 9.790278] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 9.795920] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 9.806022] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.816848] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 9.824764] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 9.831084] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 9.845885] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 9.851275] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.860273] pcieport 0007:00:00.0: Adding to iommu group 10
[ 9.866273] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 9.872674] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 9.878640] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 9.884740] pci 0007:00:00.0: Removing from iommu group 10
[ 9.890388] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 9.897977] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 9.904529] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[ 9.904796] vdd-3v3-sd: supplied by vdd-3v3
[ 9.911121] tegra194-isp5 14800000.isp: initialized
[ 9.919680] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.926136] (NULL device *): fops function table already registered
[ 9.935088] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.942235] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.942371] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 9.954058] irq: IRQ291: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.962532] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[ 10.069899] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 10.077076] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 10.085759] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 10.094437] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 10.209107] tegra194-pcie 140a0000.pcie: Link up
[ 10.216829] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 10.223649] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 10.229290] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 10.239405] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.250233] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 10.258152] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.264470] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 10.275040] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 10.281362] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 10.287274] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 10.294376] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 10.302391] pci 0008:01:00.0: supports D1 D2
[ 10.306784] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 10.318695] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 10.326123] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 10.332839] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 10.340804] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 10.348770] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 10.355428] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 10.360802] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 10.367435] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 10.374788] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 10.383527] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 10.392482] pcieport 0008:00:00.0: Adding to iommu group 11
[ 10.398475] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 10.404867] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 10.411993] irq: IRQ293: trimming hierarchy from :pmc@c360000
[ 10.417987] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.425714] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 10.433459] tegra-se-nvhost 15810000.se: Adding to iommu group 39
[ 10.440103] tegra-se-nvhost 15810000.se: initialized
[ 10.446914] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.453347] tegra-se-nvhost 15820000.se: Adding to iommu group 40
[ 10.459921] tegra-se-nvhost 15820000.se: initialized
[ 10.468237] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.474647] tegra-se-nvhost 15840000.se: Adding to iommu group 41
[ 10.481228] tegra-se-nvhost 15840000.se: initialized
[ 10.491653] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.498676] tegra_actmon d230000.actmon: in actmon_register()...
[ 10.505035] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.511243] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.519654] hvc_sysfs: hypervisor is not present
[ 10.560846] ALSA device list:
[ 10.563905] No soundcards found.
[ 10.568262] Freeing unused kernel memory: 3968K
[ 10.573002] Run /init as init process
[ 10.576762] with arguments:
[ 10.576763] /init
[ 10.576764] with environment:
[ 10.576765] HOME=/
[ 10.576766] TERM=linux
[ 10.576768] mminit_loglevel=4
[ 10.592993] Root device found: PARTUUID=9aede23d-88d0-473a-8631-41806a727110
[ 10.864156] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.876258] Rootfs mounted over PARTUUID=9aede23d-88d0-473a-8631-41806a727110
[ 10.893417] Switching from initrd to actual rootfs
[ 10.939380] systemd[1]: System time before build time, advancing clock.
[ 10.987187] systemd[1]: systemd 245.4-4ubuntu3.24 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 11.010915] systemd[1]: Detected architecture arm64.
[ 11.024910] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 11.069434] systemd[1]: Set hostname to <torsacamera>.
[ 11.075509] systemd[1]: Hardware watchdog 'Tegra WDT', version 1
[ 11.081706] tegra_wdt_t18x 2190000.watchdog: Watchdog(0): wdt timeout set to 60 sec
[ 11.089600] systemd[1]: Set hardware watchdog to 1min.
[ 11.235627] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.244149] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.251120] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 11.264142] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 11.274219] systemd[1]: Created slice system-modprobe.slice.
[ 11.293042] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.300332] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 11.321430] systemd[1]: Created slice User and Session Slice.
[ 11.341073] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.365313] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.389067] systemd[1]: Reached target Slices.
[ 11.404993] systemd[1]: Reached target Mounting snaps.
[ 11.424984] systemd[1]: Reached target Mounted snaps.
[ 11.444990] systemd[1]: Reached target Swap.
[ 11.461298] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 11.481118] systemd[1]: Listening on Syslog Socket.
[ 11.501111] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 11.525054] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.545250] systemd[1]: Listening on Journal Audit Socket.
[ 11.565101] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.585134] systemd[1]: Listening on Journal Socket.
[ 11.605138] systemd[1]: Listening on udev Control Socket.
[ 11.625069] systemd[1]: Listening on udev Kernel Socket.
[ 11.646565] systemd[1]: Mounting Huge Pages File System...
[ 11.666429] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.690343] systemd[1]: Mounting RPC Pipe File System...
[ 11.710436] systemd[1]: Mounting Kernel Debug File System...
[ 11.730404] systemd[1]: Mounting Kernel Trace File System...
[ 11.750779] systemd[1]: Starting Journal Service...
[ 11.771042] systemd[1]: Starting Set the console keyboard layout...
[ 11.795237] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 11.822363] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 11.845020] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 11.854813] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 11.874335] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 11.894209] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 11.914308] systemd[1]: Starting Load Kernel Module ramoops...
[ 11.934426] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 11.958449] systemd[1]: Started Nameserver information manager.
[ 11.977191] systemd[1]: Reached target Network (Pre).
[ 11.997412] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 12.006805] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 12.018018] systemd[1]: Starting Load Kernel Modules...
[ 12.032178] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 12.039708] nvmap_page_pool_init: Total RAM pages: 1878206
[ 12.045368] nvmap_page_pool_init: nvmap page pool size: 234775 pages (917 MB)
[ 12.052995] nvmap_background_zero_thread: PP zeroing thread starting.
[ 12.062788] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.078635] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 12.091013] systemd[1]: Starting udev Coldplug all Devices...
[ 12.095732] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 12.131650] systemd[1]: Started Journal Service.
[ 12.870160] systemd-journald[242]: Received client request to flush runtime journal.
[ 12.912435] nvidia: loading out-of-tree module taints kernel.
[ 12.928682] nv_platform 13800000.display: Adding to iommu group 42
[ 12.932330] platform 13800000.display:nvdisplay-niso: Adding to iommu group 43
[ 12.937289] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.3.1 Release Build (buildbrain@mobile-u64-6289-d7000) Sun Mar 19 08:09:33 PDT 2023
[ 12.962738] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 12.971959] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 13.001521] r8169 0008:01:00.0: Adding to iommu group 11
[ 13.001929] r8169 0008:01:00.0: enabling device (0000 -> 0003)
[ 13.020699] tegra-hda 3510000.hda: Adding to iommu group 44
[ 13.023268] r8169 0008:01:00.0 eth0: RTL8168h/8111h, 3c:6d:66:0d:52:6f, XID 541, IRQ 295
[ 13.023276] r8169 0008:01:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 13.023682] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 13.026828] nvadsp 2993000.adsp: Adding to iommu group 45
[ 13.026962] nvadsp 2993000.adsp: in probe()...
[ 13.027373] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 13.034886] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 13.039906] random: crng init done
[ 13.046002] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.057705] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 13.070376] irq: IRQ296: trimming hierarchy from :pmc@c360000
[ 13.074248] cpu-throttle-alert cooling device registered.
[ 13.074250] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[ 13.074338] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[ 13.074422] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[ 13.074498] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[ 13.074634] gpu-throttle-alert cooling device registered.
[ 13.074978] cv0-throttle-alert cooling device registered.
[ 13.075207] imx219 9-0010: board setup failed
[ 13.075357] cv1-throttle-alert cooling device registered.
[ 13.080226] imx219: probe of 9-0010 failed with error -121
[ 13.080298] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 45
[ 13.085935] cv2-throttle-alert cooling device registered.
[ 13.086395] fusb301 1-0025: failed to read device id, err : 0xffffff87
[ 13.087861] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 13.089034] tegra210_adsp_audio_probe: platform probe started
[ 13.089504] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 13.089847] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 13.090177] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 13.090505] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 13.090828] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 13.091170] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 13.091174] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 13.091175] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 13.091239] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 13.096979] fusb301 1-0025: fusb301 not support
[ 13.103434] fusb301: probe of 1-0025 failed with error -22
[ 13.105880] soc0-throttle-alert cooling device registered.
[ 13.111334] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 13.112258] soc1-throttle-alert cooling device registered.
[ 13.138648] soc2-throttle-alert cooling device registered.
[ 13.145011] hot-surface-alert cooling state: 0 -> 1
[ 13.164909] hot-surface-alert cooling device registered.
[ 13.180043] imx219 10-0010: board setup failed
[ 13.192426] tegra-asoc: sound: Adding to iommu group 45
[ 13.196889] imx219: probe of 10-0010 failed with error -121
[ 13.338679] cryptd: max_cpu_qlen set to 1000
[ 13.481961] tegra210-adsp tegra210-adsp: Loaded app wire
[ 13.481969] tegra210-adsp tegra210-adsp: Loaded app apm
[ 13.481971] tegra210-adsp tegra210-adsp: Loaded app adma
[ 13.481973] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 13.481977] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 0000000082dab66c
[ 13.511157] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 14.112078] using random self ethernet address
[ 14.118812] using random host ethernet address
[ 16.172978] Generic FE-GE Realtek PHY r8169-8-100:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-8-100:00, irq=IGNORE)
[ 16.357113] r8169 0008:01:00.0 eth0: Link is Down
[ 17.911678] pstore: Using crash dump compression: deflate
[ 17.911704] printk: console [ramoops-1] enabled
[ 17.911707] pstore: Registered ramoops as persistent store backend
[ 17.911709] ramoops: using 0x200000@0x268000000, ecc: 0
[ 17.951322] zram: Added device: zram0
[ 17.951529] zram: Added device: zram1
[ 17.952676] zram: Added device: zram2
[ 17.952970] zram: Added device: zram3
[ 17.955042] zram: Added device: zram4
[ 17.955472] zram: Added device: zram5
[ 17.979698] zram0: detected capacity change from 0 to 641093632
[ 17.996126] nvgpu: 17000000.ga10b gk20a_scale_init:539 [INFO] enabled scaling for GPU
[ 18.006454] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 18.009090] Adding 626064k swap on /dev/zram0. Priority:5 extents:1 across:626064k SS
[ 18.013574] zram1: detected capacity change from 0 to 641093632
[ 18.053110] Adding 626064k swap on /dev/zram1. Priority:5 extents:1 across:626064k SS
[ 18.054364] zram2: detected capacity change from 0 to 641093632
[ 18.080980] Adding 626064k swap on /dev/zram2. Priority:5 extents:1 across:626064k SS
[ 18.082120] zram3: detected capacity change from 0 to 641093632
[ 18.117038] Adding 626064k swap on /dev/zram3. Priority:5 extents:1 across:626064k SS
[ 18.118241] zram4: detected capacity change from 0 to 641093632
[ 18.156975] Adding 626064k swap on /dev/zram4. Priority:5 extents:1 across:626064k SS
[ 18.158289] zram5: detected capacity change from 0 to 641093632
[ 18.189030] Adding 626064k swap on /dev/zram5. Priority:5 extents:1 across:626064k SS
[ 19.987806] r8169 0008:01:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 19.987936] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 134.980382] nvgpu: 17000000.ga10b railgate_enable_store:323 [INFO] railgate is disabled.
This is the info I have on the system.
If the pinmux (MB1) configuration is correct, my understanding is I still need a kernel DT overlay to enable the intended SPI controller(s) in Linux. Could you help me create such an overlay, at least one working example, so I can understand the right way to define it and enable it on the /boot/extlinux/extlinux.conf file.
Thanks for all of your support.
