We are using a Jetson Orin NX 16GB module with a custom carrier board that we designed ourselves. I’m encountering some difficulties with detecting I2C devices connected to the board.
When I run i2cdetect -y, I see a list of I2C devices on the bus, but I’m unable to communicate with the hardware we’ve connected. Specifically, when I try i2cdetect -y 2, I still can’t establish communication.
here is the detail output of i2c detect i2c_check.txt (20.1 KB)
Additionally, could someone explain where I can find the base addresses for the I2C1 or SPI peripherals on the SOM module?
And how can I reduce the flashing time ? for each flash it takes around 60 minutes .
Any help or guidance would be greatly appreciated!
We are modifying the dts file to integrate the audio codec.
Also, I am facing issues writing a node for the audio codec. If you have a sample node for the audio codec, that would be helpful.
And are we modifying only hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3767-common-audio.dtsi? Is this the correct file to modify?
