Hello proventusnova,
The procedure encountering issues is detailed below:
Navigate to
Linux_for_Tegra/source/kernel/kernel-jammy-src/and execute the following commands:make ARCH=arm64 LOCALVERSION=-davey-tegra defconfig make ARCH=arm64 LOCALVERSION=-davey-tegra menuconfig make ARCH=arm64 LOCALVERSION=-davey-tegra -j8 Image make ARCH=arm64 LOCALVERSION=-davey-tegra -j8 modules sudo make modules_install INSTALL_MOD_PATH=/Linux_for_Tegra/rootfsThen, manually copy the
Imagefile into:Linux_for_Tegra/kernel/ImageLinux_for_Tegra/rootfs/boot/Image
In
Linux_for_Tegra/source/, run the following:export KERNEL_HEADERS=$PWD/kernel/kernel-jammy-src make modules export INSTALL_MOD_PATH=Linux_for_Tegra/rootfs sudo -E make modules_install -
In
Linux_for_Tegra/, execute:sudo ./tools/l4t_update_initrd.sh -
Finally, flash the device.
I based this method on a discussion from this thread.
Best regards,
Kondru Abhay
