Issues in Installing Jetpack 4.6 With SeeedStudio J202
Hi Team,
we have issues in flashing jetpack with 4.6 in SeedStudio J202 Carrier Board in External SSD. I believe We have earlier done this. But Unfortunately, We stuck here now.
Hi aswinkumar777,
It seems you are using the custom carrier board for Xavier NX.
You should use custom BSP package from your vendor with the command to flash your board instead of using SDKM, which is used for the devkit only.
Hi Kevin,
Thanks for the reply. This is almost a complete clone of Xavier NX Dev Kit. And i can successfully able to install JP 4.6.1 in the same board.
There is a export logs button on sdkmanager GUI, click that and share log first.
