Issues in modifying deepstream_sink_bin.c in order to add support for rtmpsink
I’m trying to add support for rtmpsink on the deepstream pipeline setup on my T4 instance.
I’ve already referred to the following posts: 1 2 3
And I could successfully compile the following with deepstream-app (under the sampel_apps).
static gboolean
create_rtmpsink_bin (NvDsSinkEncoderConfig * config, NvDsSinkBinSubBin * bin)
  GstCaps *caps = NULL;
  gboolean ret = FALSE;
  gchar elem_name[50];
  gchar encode_name[50];
  uid++;
  g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin%d", uid);
  bin->bin = gst_bin_new (elem_name);
  if (!bin->bin) {
    NVGSTDS_ERR_MSG_V ("Failed to create '%s'", elem_name);
    goto done;
  g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_queue%d", uid);
  bin->queue = gst_element_factory_make (NVDS_ELEM_QUEUE, elem_name);
  if (!bin->queue) {
    goto done;
  g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_transform%d", uid);
  bin->transform = gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, elem_name);
  if (!bin->transform) {
    goto done;
  g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_cap_filter%d", uid);
  bin->cap_filter = gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, elem_name);
  if (!bin->cap_filter) {
    goto done;
  if (config->enc_type == NV_DS_ENCODER_TYPE_SW)
    caps = gst_caps_from_string ("video/x-raw, format=I420");
  else
    caps = gst_caps_from_string ("video/x-raw(memory:NVMM), format=I420");
  g_object_set (G_OBJECT (bin->cap_filter), "caps", caps, NULL);
  g_snprintf (encode_name, sizeof (encode_name), "sink_sub_bin_encoder%d", uid);
  switch (config->codec) {
    case NV_DS_ENCODER_H264:
      bin->codecparse = gst_element_factory_make ("h264parse", "h264-parser");
      bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H264_HW, encode_name);
        bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H264_SW, encode_name);
      else
      break;
    case NV_DS_ENCODER_H265:
      bin->codecparse = gst_element_factory_make ("h265parse", "h265-parser");
        bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H265_SW, encode_name);
      else
        bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H265_HW, encode_name);
      break;
    default:
      goto done;
  if (!bin->encoder) {
    NVGSTDS_ERR_MSG_V ("Failed to create '%s'", encode_name);
    goto done;
  if (config->enc_type  == NV_DS_ENCODER_TYPE_SW) {
    //bitrate is in kbits/sec for software encoder x264enc and x265enc
    g_object_set (G_OBJECT (bin->encoder), "bitrate", config->bitrate/1000, NULL);
  } else {
      g_object_set (G_OBJECT (bin->encoder), "bitrate", config->bitrate, NULL);
      g_object_set (G_OBJECT (bin->encoder), "profile", config->profile, NULL);
      g_object_set (G_OBJECT (bin->encoder), "iframeinterval", config->iframeinterval, NULL);
#ifdef IS_TEGRA
  g_object_set (G_OBJECT (bin->encoder), "preset-level", 1, NULL);
  g_object_set (G_OBJECT (bin->encoder), "insert-sps-pps", 1, NULL);
  g_object_set (G_OBJECT (bin->encoder), "bufapi-version", 1, NULL);
#else
  g_object_set (G_OBJECT (bin->transform), "gpu-id", config->gpu_id, NULL);
#endif
  bin->flvmux = gst_element_factory_make ("flvmux", elem_name);
  if (!bin->flvmux) {
    goto done;
  g_object_set (G_OBJECT (bin->flvmux), "name", "mux",  "streamable", TRUE, NULL);
  bin->sink = gst_element_factory_make ("rtmpsink", elem_name);
  if (!bin->sink) {
    goto done;
  g_object_set (G_OBJECT (bin->sink), "location", config->rtmp_location, NULL);
  g_print ("%s: DEBUGGER create_rtmp_sinkn \n", config->rtmp_location);
  gst_bin_add_many (GST_BIN (bin->bin), bin->queue, bin->transform,
      bin->encoder, bin->codecparse, bin->flvmux, bin->sink, NULL);
  NVGSTDS_LINK_ELEMENT (bin->queue, bin->transform);
  NVGSTDS_LINK_ELEMENT (bin->transform, bin->encoder);
  NVGSTDS_LINK_ELEMENT (bin->encoder, bin->codecparse);
  NVGSTDS_LINK_ELEMENT (bin->codecparse, bin->flvmux);
  NVGSTDS_LINK_ELEMENT (bin->flvmux, bin->sink);
  NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->queue, "sink");
  ret = TRUE;
  if (ret != TRUE) {
    g_print ("%s: start_rtmp_straming function failed\n", __func__);
  g_print ("%s: Started streaming RTMP\n", __func__);
done:
  if (caps) {
    gst_caps_unref (caps);
  if (!ret) {
    NVGSTDS_ERR_MSG_V ("%s failed", __func__);
  return ret;
When I start the pipeline, I get the following output:
**PERF: 29.26 (4.21)
**PERF: 0.00 (1.82)
**PERF: 0.00 (1.16)
**PERF: 0.00 (0.85)
**PERF: 0.00 (0.67)
**PERF: 0.00 (0.56)
**PERF: 0.00 (0.47)
**PERF: 0.00 (0.41)
**PERF: 0.00 (0.37)
There’s some issue with the rtmpsink as the stream can’t penetrate through the pipeline.
Any kind of help would be appreciated.
T4
• DeepStream Version
5.0
• TensorRT Version
7.0.0.11
The codes seem OK. Can you provide more information about the failure?
@Fiona.Chen Thanks for your response.
  • After making the above changes, the deepstream-app under sample_apps compiles with the following output:
$ make
cc -c -o ../../apps-common/src/deepstream_sink_bin.o -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=0 -DDS_VERSION_MAJOR=5 `pkg-config --cflags gstreamer-1.0 gstre
amer-video-1.0 x11` ../../apps-common/src/deepstream_sink_bin.c
cc -o deepstream-app deepstream_app.o deepstream_app_main.o deepstream_app_config_parser.o ../../apps-common/src/deepstream_tracker_bin.o ../../apps-common/src/deepstream_primary_gie_b
in.o ../../apps-common/src/deepstream_source_bin.o ../../apps-common/src/deepstream_c2d_msg.o ../../apps-common/src/deepstream_config_file_parser.o ../../apps-common/src/deepstream_com
mon.o ../../apps-common/src/deepstream_sink_bin.o ../../apps-common/src/deepstream_perf.o ../../apps-common/src/deepstream_dewarper_bin.o ../../apps-common/src/deepstream_dsexample.o .
./../apps-common/src/deepstream_secondary_gie_bin.o ../../apps-common/src/deepstream_tiled_display_bin.o ../../apps-common/src/deepstream_osd_bin.o ../../apps-common/src/deepstream_str
eammux.o -L/opt/nvidia/deepstream/deepstream-5.0/lib/ -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper -lnvdsgst_smartrecord -lnvds_utils -lm -lgstrtspserver-1.0 -ldl -Wl,-rpath,/opt/nvidia
/deepstream/deepstream-5.0/lib/ `pkg-config --libs gstreamer-1.0 gstreamer-video-1.0 x11`
  • Then I proceed to run the binary with the deepstream_app_config_yoloV2.txt, I get the following output:
create_rtmpsink_bin: Started streaming RTMP
Warn: 'threshold' parameter has been deprecated. Use 'pre-cluster-threshold' instead.
0:00:01.509149698  3424 0x556ce6954b00 INFO                 nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files
Loading pre-trained weights...
Loading weights of yolov2 complete!
Total Number of weights read : 50983561
Building Yolo network...
      layer               inp_size            out_size       weightPtr
(0)   conv-bn-leaky     3 x 608 x 608      32 x 608 x 608    992
(1)   maxpool          32 x 608 x 608      32 x 304 x 304    992
(2)   conv-bn-leaky    32 x 304 x 304      64 x 304 x 304    19680
(3)   maxpool          64 x 304 x 304      64 x 152 x 152    19680
(4)   conv-bn-leaky    64 x 152 x 152     128 x 152 x 152    93920
(5)   conv-bn-leaky   128 x 152 x 152      64 x 152 x 152    102368
(6)   conv-bn-leaky    64 x 152 x 152     128 x 152 x 152    176608
(7)   maxpool         128 x 152 x 152     128 x  76 x  76    176608
(8)   conv-bn-leaky   128 x  76 x  76     256 x  76 x  76    472544
(9)   conv-bn-leaky   256 x  76 x  76     128 x  76 x  76    505824
(10)  conv-bn-leaky   128 x  76 x  76     256 x  76 x  76    801760
(11)  maxpool         256 x  76 x  76     256 x  38 x  38    801760
(12)  conv-bn-leaky   256 x  38 x  38     512 x  38 x  38    1983456
(13)  conv-bn-leaky   512 x  38 x  38     256 x  38 x  38    2115552
(14)  conv-bn-leaky   256 x  38 x  38     512 x  38 x  38    3297248
(15)  conv-bn-leaky   512 x  38 x  38     256 x  38 x  38    3429344
(16)  conv-bn-leaky   256 x  38 x  38     512 x  38 x  38    4611040
(17)  maxpool         512 x  38 x  38     512 x  19 x  19    4611040
(18)  conv-bn-leaky   512 x  19 x  19    1024 x  19 x  19    9333728
(19)  conv-bn-leaky  1024 x  19 x  19     512 x  19 x  19    9860064
(20)  conv-bn-leaky   512 x  19 x  19    1024 x  19 x  19    14582752
(21)  conv-bn-leaky  1024 x  19 x  19     512 x  19 x  19    15109088
(22)  conv-bn-leaky   512 x  19 x  19    1024 x  19 x  19    19831776
(23)  conv-bn-leaky  1024 x  19 x  19    1024 x  19 x  19    29273056
(24)  conv-bn-leaky  1024 x  19 x  19    1024 x  19 x  19    38714336
(25)  route                  -            512 x  38 x  38    38714336
(26)  conv-bn-leaky   512 x  38 x  38      64 x  38 x  38    38747360
(27)  reorg            64 x  38 x  38     256 x  19 x  19    38747360
(28)  route                  -           1280 x  19 x  19    38747360
(29)  conv-bn-leaky  1280 x  19 x  19    1024 x  19 x  19    50547936
(30)  conv-linear    1024 x  19 x  19     425 x  19 x  19    50983561
(31)  region          425 x  19 x  19     425 x  19 x  19    50983561
Anchors are being converted to network input resolution i.e. Anchors x 32 (stride)
Output yolo blob names :
region_32
Total number of yolo layers: 76
Building yolo network complete!
Building the TensorRT Engine...
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: Detected 1 inputs and 1 output network tensors.
Building complete!
0:01:01.142986737  3424 0x556ce6954b00 INFO                 nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1624> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/model_b1_gpu0_fp32.engine successfully
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:34 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0   INPUT  kFLOAT data            3x608x608
1   OUTPUT kFLOAT region_32       425x19x19
0:01:01.148922390  3424 0x556ce6954b00 INFO                 nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/config_infer_primary_yoloV2.txt sucessfully
Runtime commands:
        h: Print this help
        q: Quit
        p: Pause
        r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
**PERF: 0.00 (0.00)
** INFO: <bus_callback:167>: Pipeline running
**PERF: 47.35 (3.93)
**PERF: 0.00 (1.63)
**PERF: 0.00 (1.03)
**PERF: 0.00 (0.75)
  • There’s no failure until this point, I can monitor the stream entering the system and works well if I use the rtspsink, but the above issue when run with rtmpsink. (You see the stream doesn’t penetrate through the pipeline)
  • The source config:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=2
uri=rtmp://localhost:1935/show/stream_0
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device   - Memory type Device
# (1): memtype_pinned   - Memory type Host Pinned
# (2): memtype_unified  - Memory type Unified
cudadec-memtype=0
Please have a look and let me know in case I missed something out.
@Fiona.Chen Any updates on this?
I’ve tried your code and configuration, the source is rtmp and sink is also rtmp, it seems work well.
Not sure what might have led to the issue that I’m facing. Can you share the config that you’re using? That might help I guess.
Thanks for the confirmation.
Just using the modified source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt in Deepstream-app sample. The source and sink changed as your configuraion.
I noticed after making a few changes to the config, the fps would (later)increase to come in sync with the source.
Thanks for all the help.
