Issues in the one click deployment
Hey there!
We are deploying one-click deployment script on AWS. We are using the p4d.24xlarge (8 X A100) ubuntu instance.
We followed all the steps given in this documentation Amazon Web Services (AWS) — Video Search and Summarization Agent
We were able to successfully run the OneClick script, and the node was created as expected. However, at the end of the script’s execution, the following error was displayed.
After running the script, we executed the following commands to verify the deployment:
  1. We ran the following command to get the frontend URL:
ubuntu@ip-xxx-xx-xx-xx:~/dist$ ./envbuild.sh -f config.yml info
Output:
preparing artifacts
access_urls:
app:
backend: http://x.xx.xxx.xxx:30081/
frontend: http://x.xx.xxx.xxx:30082/
ssh_command:
app:
master: ssh -i /home/ubuntu/.ssh/id_rsa -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null ubuntu@x.xx.xxx.xxx
  1. As per the instructions in the blog, we SSH’d into the instance and ran the following command to list the pods. However, only one pod is listed.
ubuntu@ip-10-0-0-28:~$ kubectl get pod
Output:
NAME READY STATUS RESTARTS AGE
dnsutils 1/1 Running 0 35m
  1. When attempting to access the frontend URL in the browser, we are unable to reach it.
I am attaching the error message as well as the config file
Also I have mentioned the availability zones in the config.yml file as us-east-2a and us-east-2b respectively, but getting the same issue every time.
config.yml.txt (2.9 KB)
Same with the 326536
